string() function reverse - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: string() function reverse (/thread-9207.html) |
string() function reverse - primer - 10-01-2017 12:46 PM Hello, let's say I perform a STRING command to an objet (like a list, a matrix... for example). how can I transform it to its original form ? in other word, what is the reverse function of STRING ? Thank you. RE: string() function reverse - DrD - 10-01-2017 01:39 PM Do you mean a string relationship like quote() is to eval()? (A specific example would be helpful). RE: string() function reverse - Didier Lachieze - 10-01-2017 01:43 PM EXPR: Parses a string into a number or expression and returns the result evaluated. For ex: Code: L1:={2,4,6,8,10} RE: string() function reverse - primer - 10-01-2017 01:54 PM (10-01-2017 01:43 PM)Didier Lachieze Wrote: EXPR: Parses a string into a number or expression and returns the result evaluated. Yes, thank you Dider, that's exactly that. BTW, I found that Connectivity Kit can not save/export user variables, if you want to export your variable, you have to use built in ones (L0 to L9 for lists) or use Notes trick, see below : for example : Notes("myList_saved"):=STRING(mylist); -- Notes can be exported to windows with CK... and then EXPR is needed to recover mylist:=EXPR(Notes("mylist_saved")); |
