I'm having some problems with integer definitions... - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: I'm having some problems with integer definitions... (/thread-9494.html) |
I'm having some problems with integer definitions... - webmasterpdx - 11-15-2017 07:43 AM I'm using the Beta, but I suspect these issues are not release based. The rules for specifying values in different bases are not consistent. e.g. To specify a number in hex, octal, decimal and binary are #0h, #0o, #0d and #0b respectively. From the command line, the lower case letters are used, but in programs, you need to use Upper case letters to define the base. Also, I can't seem to specify the number of bits. I thought it was #0d32, but from the command line this is getting converted to #0d*32 and in programs it's getting converted to the hex number d32 (I think hex is in my settings somewhere).... So, how do I specify the number of bits. I did see in the user manual #0:b in one spot, but I tried the colon and it didn't seem to work (from the command line). help??? Thx RE: I'm having some problems with integer definitions... - webmasterpdx - 11-15-2017 07:54 AM OK, I've figured out the upper/lower case issues. The base is always in lower case (in programs and in command line). I was confused with that because the # went to my default base of hex, which needed an upper case D to define the integer. So, values are always using upper case letters in hex. e.g. #19d is 19 decimal, but #19Dh is 19D hex. However, I still don't know how to specify the number of bits in the integer. I know I can use SETBITS, but I need to know how to express it in the integer value, like #19h32. RE: I'm having some problems with integer definitions... - Stevetuc - 11-15-2017 08:04 AM #19:16d 19 decimal 16bits #19D:16h 19D hex 16bits RE: I'm having some problems with integer definitions... - webmasterpdx - 11-15-2017 08:40 AM That works! Also, you cannot use #19D:h. You must put a number before the base if using the : Thank you! -Donald RE: I'm having some problems with integer definitions... - Carlos295pz - 11-16-2017 03:12 AM It is in Spanish but can serve: https://carlos-icg.blogspot.pe/2017/09/entero-tipo-hp-prime.html |
