GRAPH 3D v2.425 (20-FEB-2017) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP Prime Software Library (/forum-15.html) +--- Thread: GRAPH 3D v2.425 (20-FEB-2017) (/thread-95.html) |
RE: GRAPH 3D v2.421 (Updated 19-DEC-2014) - akmon - 12-21-2014 02:13 PM Tried your new versión and zooming has improved a lot. It´s true that some movements aren´t 100% accurate, but is enough for doing basical rotations. By the way, when I select panning mode, it still rotate the figure instead of panning it, perhaps I´m not doing it well. By the way. A suggestion. Is it posible to draw the XYZ axis to know which axis is in every moment? With so many rotations you get los thow is oriented the frame. Tahnk you, and keep on doing like this. RE: GRAPH 3D v2.421 (Updated 19-DEC-2014) - Han - 12-21-2014 02:29 PM The way rotation works is based on the viewing angles. There isn't much code in terms of trying to guess where you are grabbing. Instead, grab the top-most or bottom-most corners to rotate and it will generally guess right. It also bases the motion on whether or not the back area is visible. For panning, just keep your two fingers the same distance apart as you move them both up and down or left and right. RE: GRAPH 3D v2.421 (Updated 19-DEC-2014) - Han - 12-21-2014 10:16 PM (12-21-2014 02:13 PM)akmon Wrote: By the way. A suggestion. Is it posible to draw the XYZ axis to know which axis is in every moment? With so many rotations you get los thow is oriented the frame. Tahnk you, and keep on doing like this. As a temporary workaround, you can change the following line (inside the setdefault() function): blines:={#A0A0A0h,{1,2},{2,4},{4,3},{3,1},{5,6},{6,8},{8,7},{7,5},{1,5},{2,6},{3,7},{4,8}}; to blines:={#A0A0A0h,{1,2,#8822h},{2,4},{4,3},{3,1,#FF0000h},{5,6},{6,8},{8,7},{7,5},{1,5,#FFh},{2,6},{3,7},{4,8}}; The green, red, and blue lines are parallel to the z, x, and y directions (all located at the xmin,ymin,zmin corner) I didn't include the axes because sometimes the viewing window may not even include the origin. If you have trace mode on, it should be clear as soon as you tap left/right (x-direction) and up/down (y-direction). The right arrow always move toward xmax, and the up arrow always moves toward ymax. The z=zmin plane should be obvious from the grey square at the "bottom" of the viewing box. RE: GRAPH 3D v2.422 (21-DEC-2014) - marcusnicolas1 - 12-24-2014 03:57 AM I downloaded the Graph3D 2.42 version. It seems as though I can not longer plot the function of square root of -X^2 -Y^2, It gives me a box with nothing inside of it. Also, I have been trying to plot a sphere and can not do so. Can anyone help me with this please? THank you. RE: GRAPH 3D v2.422 (21-DEC-2014) - Han - 12-24-2014 04:31 AM (12-24-2014 03:57 AM)marcusnicolas1 Wrote: I downloaded the Graph3D 2.42 version. It seems as though I can not longer plot the function of square root of -X^2 -Y^2, It gives me a box with nothing inside of it. Also, I have been trying to plot a sphere and can not do so. Can anyone help me with this please? THank you. Well, the f(X,Y)=(-X^2-Y^2)^(1/2) is defined only when X=Y=0. For any other values of X and Y, f(X,Y) is a complex value. The equation of a sphere is X^2+Y^2+Z^2=R^2 where R is the radius. So if you wanted to graph half a sphere, you should be graphing f(X,Y)=sqrt(R^2-X^2-Y^2) -- presumably R>0, too. RE: GRAPH 3D v2.422 (21-DEC-2014) - akmon - 12-25-2014 09:06 PM (12-21-2014 10:16 PM)Han Wrote:(12-21-2014 02:13 PM)akmon Wrote: By the way. A suggestion. Is it posible to draw the XYZ axis to know which axis is in every moment? With so many rotations you get los thow is oriented the frame. Tahnk you, and keep on doing like this. Thank you for your advises. Yes, in trace mode it´s easy to identify the axis. RE: GRAPH 3D v2.422 (21-DEC-2014) - mikerovak - 01-12-2015 04:42 AM Have you guys ever seen the n-dimensional plotting capability that Vaagmaer wrote for the Zaurus line of linux-based devices a few years ago? You just type in an equation and it implicitly creates the graph regardless of how many dimensions. Example photo of screen with 4-D torus and some portions transparent attached. Would LOVE to see HP put this kind of functionality into this calc. Your competition would absolutely cry. [attachment=1436] RE: GRAPH 3D v2.422 (21-DEC-2014) - LCieParagon - 01-25-2015 04:00 AM Hello. I'm a Calculus III / Differential Equations teacher. I purchased my HP Prime today and I really enjoy. Your app for 3D Graphing is incredible. I have a couple of questions though. Is there any way I can see the values on the box? For instance, if I graph an upper cone: f(x,y) = sqrt(x^2 + y^2), I see the wonderful drawing, but I do not see any values for where they intersect the box. Is there a way I can view this? Additionally, do you know any Apps that would graph solutions for Differential Equations (similar to that on the TI-89)? Thanks so much. RE: GRAPH 3D v2.422 (21-DEC-2014) - Han - 01-25-2015 03:50 PM (01-25-2015 04:00 AM)LCieParagon Wrote: Hello. I'm a Calculus III / Differential Equations teacher. Would the trace feature do? Press the [.] key (or tap the screen and select trace mode). You can use the arrow keys to move the point to find the x,y,z values. Or is this not what you meant? RE: GRAPH 3D v2.422 (21-DEC-2014) - Didiron - 02-05-2015 06:28 PM Hey people. I installed this app and it h been working fine. But I ahve some problems when I put a function like this (that I saw in a youtube video): 1 - (cos(x^2 + y^2))/(x^2+y^2). Accordng to the vdeo the graph should appear this way: ![]() But it has been showed this: ![]() Apparently, a part of the graph is not being showed. Someone know whats's wrong with it? Thank you. RE: GRAPH 3D v2.422 (21-DEC-2014) - Han - 02-05-2015 08:35 PM (02-05-2015 06:28 PM)Didiron Wrote: Hey people. You are using the default -10..10 range for X and Y. With those values, the fractional part of the formula is relatively small, so that you are mostly seeing a flat plane. If you set the X and Y range to be, say, from -4 to 4 (each), then you will see more details. RE: GRAPH 3D v2.422 (21-DEC-2014) - Didiron - 02-05-2015 10:46 PM Thank, it worked now. I have just one more question. Sometime a function has values that are not real (complex values), but this values are not showed in the graphic, right? Because, If I put a function of an sphere, it is showed only a part of it. Is this right? Thank you. RE: GRAPH 3D v2.422 (21-DEC-2014) - Han - 02-05-2015 10:48 PM (02-05-2015 10:46 PM)Didiron Wrote: Thank, it worked now. Correct, it only graphs real-valued functions \( f:\mathbb{R}^2 \to \mathbb{R} \) RE: GRAPH 3D v2.422 (21-DEC-2014) - Dean1980 - 02-27-2015 09:31 PM Great App Thanks for sharing it with the World. I am a long time HP 50g user. Maybe the HP Prime will encroach on the TI Market. Dean RE: GRAPH 3D v2.422 (21-DEC-2014) - Jedidiah Smith - 03-07-2015 11:12 PM Hi Han, thank you for this great program. I finally had some time to install and tinker with it a little on my daughter's HP Prime. Then we compared it to plot times with the Wireframe Plot setting on my HP RPN graphing calcs. All running latest firmware where applicable. Equation & plot window setup from the Wireframe example in the HP48G Manual: X^3*Y-X*Y^3. 0.1 Sec = HP Prime running Han's program Ver 2.422 3 sec = Samsung NoteII (ARM A9 quad core 1.6GHz) go48g emulator at 10X speed 4.3 sec = Samsung NoteII (ARM Cortex A9 quad core 1.6GHz) Droid48 emulator 6 sec = Motorola Atrix HD (Snapdragon S4 Krait dual core 1.5GHz) Droid48 emulator 23 sec = HP 50G 23 sec = HP 49G+ 25 sec = HP 48GII (Second version) 61 sec = HP 48G+ 78 sec = HP 49G Amazing result. As an HP48G series diehard, I am now thinking of getting the Prime for myself. If I do that, the others are just going to sit there though...one could get used to this speed! ;-) RE: GRAPH 3D v2.422 (21-DEC-2014) - Archanus - 06-05-2015 02:46 AM Hey Dear Han ![]() You Graph3D App works like a charm in new firmware 7820 ![]() In the Calculator when I go to Plot Setup (Shift+Plot), I can configure the kind of plot, their limits and I can choose if I want surface or contour. But in Emulator I cannot go to Plot Setup :/ I gen an error and the emulator crashes :/ Please can you fix it? ![]() RE: GRAPH 3D v2.422 (21-DEC-2014) - Tim Wessman - 06-05-2015 09:40 PM (06-05-2015 02:46 AM)Archanus Wrote: Please can you fix it? Don't think he can as it was an issue with the chooser in input. Should be resolved when/if there is another update released. RE: GRAPH 3D v2.422 (21-DEC-2014) - Archanus - 06-07-2015 02:21 AM (06-05-2015 09:40 PM)Tim Wessman Wrote: Don't think he can as it was an issue with the chooser in input. Should be resolved when/if there is another update released. Oh, Ok Tim ![]() ![]() ![]() Do you know when a possible firmware can be released? ![]() RE: GRAPH 3D v2.422 (21-DEC-2014) - debrouxl - 06-07-2015 06:51 AM Quote:So the bug will be fixed when/if a new firmware is released?From their posts, we gather that Tim, Cyrille and other HP staff cannot commit to whether any future release of the firmware contains any particular change, or when said release is going to occur. They can, however, state something along the lines of "this is / looks like a bug, will put on the list of things to investigate". RE: GRAPH 3D v2.422 (21-DEC-2014) - mullersk - 06-11-2015 03:27 AM (12-16-2014 01:49 PM)Han Wrote: Here's a new beta for those who have to have touchscreen input. You will need at least firmware 6940. Han, Thank you so very much for your job. It works pretty well! |
