tsimplify problem - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: tsimplify problem (/thread-9547.html) |
tsimplify problem - webmasterpdx - 11-21-2017 04:10 PM With the beta v2, I tried: tsimplify(atan(cot(pi*x))) which returned -pi*x-(1/2)*pi ...which isn't correct to the best of my knowledge (doesn't plot the same). RE: tsimplify problem - parisse - 11-21-2017 04:24 PM tsimplify replaces trig expressions with exp and inverse trig with ln then it does simplifications without taking care of complex ln branches, the result is not necessarily valid on the whole complex plane. RE: tsimplify problem - webmasterpdx - 11-21-2017 05:45 PM That doesn't look like what it did here...??? I mean the results are not equivalent to the input function. RE: tsimplify problem - AlexFekken - 11-22-2017 10:26 AM Perhaps Parisse should not have said "complex" because (unlike e.g. exp) tan is already periodic on the real line, and so atan has real branches there, separated by multiples of pi. So the "simplified" answer is correct, up to a multiple pi, which in my opinion is probably as much as you should expect when you are using variable arguments (as opposed to an explicit numerical argument that would allow you to obtain a "principal value"). RE: tsimplify problem - webmasterpdx - 11-23-2017 03:24 AM True... Thx RE: tsimplify problem - webmasterpdx - 11-23-2017 03:30 AM It's actually valid for x in [-1,0], and y in [-1.5,1.5] approx. -Donald |
