Increasing the resolution of the screen on the HP28 or HP48. Possible ? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Increasing the resolution of the screen on the HP28 or HP48. Possible ? (/thread-9561.html) |
Increasing the resolution of the screen on the HP28 or HP48. Possible ? - Alejandro Paz(Germany) - 11-23-2017 09:00 AM Have someone tried any inroads into increasing the resolution of any of these machines ? Any ideas if the amount of code to change is that large and/or that complicated, I mean there are 128..256 kBytes of mixed code, enough for a lifetime of searching, I think . RE: Increasing the resolution of the screen on the HP28 or HP48. Possible ? - rprosperi - 11-23-2017 01:56 PM (11-23-2017 09:00 AM)Alejandro Paz(Germany) Wrote: Have someone tried any inroads into increasing the resolution of any of these machines ? Any ideas if the amount of code to change is that large and/or that complicated, I mean there are 128..256 kBytes of mixed code, enough for a lifetime of searching, I think . I think the most cost-effective (and time-effective) answer would be to simply get a 50g. Same RPL, higher-res LCD. RE: Increasing the resolution of the screen on the HP28 or HP48. Possible ? - Alejandro Paz(Germany) - 11-23-2017 06:57 PM Quote:I think the most cost-effective (and time-effective) answer would be to simply get a 50g. Same RPL, higher-res LCD. I'm not talking about the real HW, my target would be say EMU48 or my own re-implementation of the Saturn chipset with a bigger display: I ask specifically about the SW running on the Machine. When the target is EMU48 (or any other emulator) it is a matter of using a bigger bitmap to display on the PC screen. Sorry for the possible confusion. RE: Increasing the resolution of the screen on the HP28 or HP48. Possible ? - cyrille de brébisson - 11-24-2017 06:07 AM Hello, Unfortunately, most of the 28/48 SW is unable to cope with a different resoltution screen. Prety much all the UI code is very, very resolution dependent. The 50G series is a little bit more tolerant of height resolution change and might mostly work with a higher screen, but this is as far as you can go. Cyrille RE: Increasing the resolution of the screen on the HP28 or HP48. Possible ? - Alejandro Paz(Germany) - 11-24-2017 06:30 AM Quote:Unfortunately, most of the 28/48 SW is unable to cope with a different resolution screen. That, I feared. Thanks for the answer. |
