HP 86/87 Matrix Rom Manual - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP 86/87 Matrix Rom Manual (/thread-958.html) |
HP 86/87 Matrix Rom Manual - Michael Fehlhammer - 03-22-2014 06:11 PM Obviously the HP 86/87 version of the matrix rom is essentially different from the HP 85 version, as it is composed of two ROM chips ( matrix 1 and 2; just one matrix ROM for the HP 85). Therefore I assume that the HP 86/87 matrix ROM is more powerful and has more BASIC keywords than the HP 85 version. On the internet only the HP 85 matrix ROM manual is available ( e.g. at series80.org, or hpmuseum.net ). Does anyone know details about the additional functions in the HP 86/87 ROM, or even better, can anyone point me to a source for the manual? RE: HP 86/87 Matrix Rom Manual - Raymond Del Tondo - 03-22-2014 08:19 PM Hi Michael, the HPMuseum DVD contains a "Series 80 Matrix ROM Manual", maybe this could be of help? Cheers RE: HP 86/87 Matrix Rom Manual - Michael Fehlhammer - 03-22-2014 09:57 PM Thanks Ray, but unfortunately this manual also covers the HP 85 version of the matrix ROM ( only ). Perhaps there is kind of an addendum for the additional functions in the HP 86/87 matrix 2 ROM, or I would need the HP 86/87 manual version - or my assumption was wrong that there are additional functions. But what else should be included in the second ROM ? RE: HP 86/87 Matrix Rom Manual - Marcus von Cube - 03-22-2014 09:58 PM You can download the ROM images from seris80.org. I did out of curiosity. The keywords start at 78h in the 85 ROM and at 82h in the first 87 ROM. I tried to extract the strings from both. If I'm not mistaken the lists look fairly identical. RE: HP 86/87 Matrix Rom Manual - Raymond Del Tondo - 03-22-2014 10:09 PM So maybe the 87 version could contain some bug fixes and/or adaptions for the wide-screen CRT of the HP-87, which would possibly explain the need for a 2nd ROM chip. Tony? RE: HP 86/87 Matrix Rom Manual - Michael Fehlhammer - 03-23-2014 04:34 PM (03-22-2014 09:58 PM)Marcus von Cube Wrote: You can download the ROM images from seris80.org. I did out of curiosity. The keywords start at 78h in the 85 ROM and at 82h in the first 87 ROM. I tried to extract the strings from both. If I'm not mistaken the lists look fairly identical.Thank you for checking that, Marcus! Bug fixes and wide screen support - yes, Raymond, maybe that is the secret of the second ROM. Anyone out there who has got the HP 86/87 Matrix ROM manual and can tell exactly? RE: HP 86/87 Matrix Rom Manual - patrice - 03-23-2014 06:54 PM As far as I remember. There is a set of ROMs for HP 83 and 85 and a set of ROMs for HP 85B, 86 and 87. The main reason of those 2 sets of ROMs is that the 83/85 have 16 bits memory address space and the CPU can access everywhere. Contrary, the 85B/86/87 have 24 bits memory address space and access of memory above the first 64KB is done with 2 special pointers. the difference between direct memory access and pointer memory access takes a small amount of space in CPU code to do the same thing. That small amount over a ROM can be enough to make that the code don't fit in the 8KB of the ROM, thus needing 2 ROMs. RE: HP 86/87 Matrix Rom Manual - Michael Fehlhammer - 03-23-2014 08:27 PM (03-23-2014 06:54 PM)patrice Wrote: That small amount over a ROM can be enough to make that the code don't fit in the 8KB of the ROM, thus needing 2 ROMs.Sounds logical. In combination with Marcus' finding ( no additional keywords in the 86/87 version ) it is unlikely that there are any differences concerning functionality, so the HP 85 Matrix ROM manual will suffice. Thank you! |
