Area by Quadratic Splines - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP Prime Software Library (/forum-15.html) +--- Thread: Area by Quadratic Splines (/thread-9689.html) |
Area by Quadratic Splines - Eddie W. Shore - 12-13-2017 01:42 PM Introduction The program QUADSUM calculates the area under the curve described by the set of points (x_n, y_n). The points are connected, in groups of three, by quadratic splines. Thus, points (x1, y1), (x2, y2), and (x3, y3) are connected by a quadratic spline, (x3, y3), (x4, y4), (x5, y5) are connected by another quadratic spline, and so on. The number of points for QUADSUM must be odd. HP Prime Program QUADSUM Code:
Example Find the area under the curve with these points connected by quadratic splines: (0,2), (1,1), (2,2), (3,6), (4,4) Note that the point (2,2) ends the first spline and starts the second. QUADSUM({0,1,2,3,4}, {2,1,2,6,4}) returns 12.6666666667 FYI: The polynomial described would be the piecewise equation: y = { x^2 -2x + 2 for 0 < x ≤ 2, -3x^2 + 19x – 24 for 2 < x ≤ 4 RE: Area by Quadratic Splines - AlexFekken - 12-14-2017 06:57 AM Doesn't this mean you are basically doing a repeated Simpson's rule, but with more work? https://en.wikipedia.org/wiki/Simpson%27s_rule RE: Area by Quadratic Splines - AlexFekken - 12-20-2017 05:03 AM (12-14-2017 06:57 AM)AlexFekken Wrote: Doesn't this mean you are basically doing a repeated Simpson's rule, but with more work? Actually no, not if the points aren't equidistant of course... |
