Sad day for HP-41C - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Sad day for HP-41C (/thread-9692.html) Pages: 1 2 |
RE: Sad day for HP-41C - Nate Martin - 12-16-2017 02:26 AM I think the message here is "don't just throw it away". It is likely possible to rebuild with some care, and some replacement parts exist. If it appears in too bad of shape or beyond you capability, many of the parts can be used as spares to keep other 41's going. RE: Sad day for HP-41C - aurelio - 12-16-2017 07:12 PM (12-14-2017 10:00 PM)Raymond Del Tondo Wrote:That's the first thing I thought when I saw it in the pictures(12-14-2017 12:19 PM)Massimo Gnerucci Wrote: Then use one of these.Hi, RE: Sad day for HP-41C - aurelio - 12-16-2017 07:18 PM (12-14-2017 01:03 AM)larthurl Wrote: This is my original HP-41C that I bought in 1980. I used it heavily and then about 1990, it went into storage. I re-discovered it about a decade later and saw that it had battery damage from leaking cells. then sorry for the healt of your 41 this is a bad situation but if this can help you i succeded in cleaning the board after a vinegrad bath and a flat screw driver job as Jose already suggested then you 'll need to replace the blocks. Diego's rsources could help in that. good luck |
