Prime Unit Conversion - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Prime Unit Conversion (/thread-9780.html) |
Prime Unit Conversion - lrdheat - 12-26-2017 04:53 AM On the beta version, in viscosity, (m^2)/s and St conversion attempts to P both produce an inconsistent units error RE: Prime Unit Conversion - roadrunner - 12-26-2017 12:50 PM They are different units. One is kinematic viscosity and one is dynamic viscosity. Maybe they will add a kg/(m.s) choice to the list in a future release. edit: lbm/(ft.hr) and ft^2/s would also be nice -road RE: Prime Unit Conversion - lrdheat - 12-26-2017 02:15 PM It then appears as if there is no conversion choice for P... RE: Prime Unit Conversion - JMB - 12-26-2017 09:43 PM (12-26-2017 02:15 PM)lrdheat Wrote: It then appears as if there is no conversion choice for P... You can convert between P (poise) and Pa·s (pascal·second): 1 P = 0.1 Pa·s For example, CONVERT(15_P, 1_Pa*s) returns 1.5_Pa*s RE: Prime Unit Conversion - lrdheat - 12-27-2017 12:45 AM On my beta 13011 version OS, I only have a viscosity choice of (m^2)/s, St, and P (choices 4,7,8 no other options are shown) RE: Prime Unit Conversion - Arno K - 12-27-2017 11:02 AM You must enter it yourself, convert(15_P,1_Pa*s), P, Pa and s are available, so you enter the first part until 1_Pa, go back into the brackets and key in *s. For me that works and is the usual way I use to convert to combined units. Arno |
