Multiple Curve Fitting Program HP-41 - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Multiple Curve Fitting Program HP-41 (/thread-9911.html) Pages: 1 2 |
RE: Multiple Curve Fitting Program HP-41 - PedroLeiva - 12-11-2021 12:52 PM Try this, for HP97, 218 PGRM steps: https://openprairie.sdstate.edu/do/search/?q=Linear%20regression%20analysis%20with%20pocket%20calculator&start=0&context=7231697&facet= RE: Multiple Curve Fitting Program HP-41 - floppy - 12-11-2021 02:07 PM (01-12-2018 05:39 AM)Graan Wrote: HelloCan you give us the link to your PDF? Or send it via message? My idea: perhaps a converting PDF to TEXT processor can extract the lines (I will have to search which one in Linux or Windows), then cleaning up, perhaps we can come to a proper TXT file you can further use and avoid you to make a finger line by line coding. RE: Multiple Curve Fitting Program HP-41 - Eric Rechlin - 12-11-2021 11:49 PM (12-11-2021 02:07 PM)floppy Wrote: Can you give us the link to your PDF? Or send it via message? I don't know about his PDF, but my PDF is probably higher quality (400 dpi 4-bit grayscale): https://literature.hpcalc.org/items/1516 The OCR is unfortunately far from perfect. The "printer" font tends to give the algorithm problems. RE: Multiple Curve Fitting Program HP-41 - MNH - 12-12-2021 02:10 AM (12-11-2021 12:52 PM)PedroLeiva Wrote: Try this, for HP97, 218 PGRM steps: https://openprairie.sdstate.edu/do/search/?q=Linear%20regression%20analysis%20with%20pocket%20calculator&start=0&context=7231697&facet= Thank you for posting this! RE: Multiple Curve Fitting Program HP-41 - MNH - 12-12-2021 02:16 AM (12-11-2021 11:49 PM)Eric Rechlin Wrote: I don't know about his PDF, but my PDF is probably higher quality (400 dpi 4-bit grayscale): Thank you for posting this! RE: Multiple Curve Fitting Program HP-41 - Felix Gross - 12-12-2021 01:58 PM Is this what you are looking for: https://openprairie.sdstate.edu/cgi/viewcontent.cgi?article=1052&context=agexperimentsta_tb Felix RE: Multiple Curve Fitting Program HP-41 - MNH - 12-12-2021 02:28 PM (12-12-2021 01:58 PM)Felix Gross Wrote: Is this what you are looking for: Yes. It was already posted. Thanks for your effort, though! |
