Programming Challenge: Palindromic Numbers on HP 50g - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Programming Challenge: Palindromic Numbers on HP 50g (/thread-9922.html) Pages: 1 2 |
RE: Programming Challenge: Palindromic Numbers on HP 50g - Gerald H - 01-14-2018 04:41 PM As the weekend draws to a close (here in Vienna) I post my attempt at answering the challenge. The programme takes about half the time needed by NNTOK above. The poetic name of the programme is A002113.USR Code: « DUP 2. < RE: Programming Challenge: Palindromic Numbers on HP 50g - John Keith - 01-14-2018 07:50 PM (01-14-2018 03:51 PM)Gilles59 Wrote: To edit a program I press : The way I do it: RightShift Program name softkey DownArrow Then when done editing: Enter LeftShift Program name softkey. RE: Programming Challenge: Palindromic Numbers on HP 50g - Thomas Okken - 01-14-2018 09:14 PM (01-14-2018 04:10 PM)Gilles59 Wrote: Now i have do understand_why_ this works I approached it like this: Palindromes with an odd number of digits have the form ABCDCBA Palindtomes with an even number of digits have the form ABCDDCBA therefore There are 10 1-digit palindromes, 0-9. There are 9 2-digit palindromes, 11-99. There are 90 3-digit palindromes, 101-999. There are 90 4-digit palindromes, 1001-9999. There are 900 5-digit palindromes, 10001-99999. There are 900 6-digit palindromes, 100001-999999. etc. So, adding up these numbers, the pattern is clear: The first 1-digit palindrome is #1 (counting from 1, an arbitrary but convenient choice) The first 2-digit palindrome is #11 The first 3-digit palindrome is #20 The first 4-digit palindrome is #110 The first 5-digit palindrome is #200 The first 6-digit palindrome is #1100 The first 7-digit palindrome is #2000 etc. Once you see the pattern, the code practically writes itself. RE: Programming Challenge: Palindromic Numbers on HP 50g - Thomas Okken - 01-15-2018 01:17 AM (01-14-2018 07:50 PM)John Keith Wrote:(01-14-2018 03:51 PM)Gilles59 Wrote: To edit a program I press : Very useful tips, thank you! I also noticed that RightArrow is SWAP, like on the 48G -- except on the 48G, it actually says so on the keyboard. Are these shortcuts documented anywhere? RE: Programming Challenge: Palindromic Numbers on HP 50g - rprosperi - 01-15-2018 02:18 AM (01-15-2018 01:17 AM)Thomas Okken Wrote: I also noticed that RightArrow is SWAP, like on the 48G -- except on the 48G, it actually says so on the keyboard. Are these shortcuts documented anywhere? Appendix G in the 50g User's Guide is probably the best single source, but Appendix G in the 50g AUR also includes some useful shortcuts that go beyond simple key assignments. The 50g User's Manual by contrast doesn't provide much useful info of this type, it's more focused on the math applications in the machine. I assume you have these PDF Docs, but I'd suggest you get the versions with the index integrated into the PDF, it makes them much more useful. |
