(11C) Digit Sum - Printable Version
+--- Forum: General Software Library (/forum-13.html)
+--- Thread: (11C) Digit Sum (/thread-9948.html)
(11C) Digit Sum - Gamo - 01-16-2018 08:52 AM
In mathematics, the digit sum of a given integer is the sum of all its digits
The digit sum of 84001 is calculated as 8+4+0+0+1 = 13
LBL A
0
STO 1
R↓
LBL 1
1
0
FRAC
STO+1
LSTx
INT
X≠0
GTO 1
10^x
10^x
RCL 1
x
RTN
Gamo
RE: (11C) Digit Sum - Dieter - 01-16-2018 07:16 PM
Gamo, this is one of your best-coded programs. And it uses a clever algorithm: it sums 1/10 of the digits and finally multiplies the result by 10. Which is obtained by two consecutive 10x commands (0 → 1 → 10).
I like such little tricks (altough a plain 10 is faster and doesn't require more steps). Let me add one more: If you want to zero data register 1 without affecting the stack, a simple STO 1 STO–1 does it. Saves one step here.
By the way...
(01-16-2018 08:52 AM)Gamo Wrote:  In mathematics, the digit sum of a given integer is the sum of all its digits
And the digit sum of this (the digital root) is 4 (simply run the program once more).
But you can calculate this directly, it's simply n mod 9. Or 9 if this yields zero (and n≠0).
Dieter
RE: (11C) Digit Sum - wawa - 01-20-2018 08:14 AM
I like this program very much too.
I've made a little modification to operate only in the stack, avoiding the use of the register 1.
LBL A
0
X<>Y
LBL 0
1
0
FRAC
LST X
R↓
R^
INT
X̣!=0?
GTO 0
R↓
1
0
x
RTN
and here is a HP42s version of this program with a little modification in the way I use the stack
00 { 38-Byte Prgm }
01▸LBL "SumDg"
02 0
03 10
04▸LBL 00
05 STO÷ ST Z
06 RCL ST Z
07 IP
08 X=0?
09 GTO 01
10 X<> ST T
11 FP
12 STO+ ST Z
13 R↓
14 GTO 00
15▸LBL 01
16 R↓
17 X<> ST Z
18 +
19 ×
20 RTN
21 END
RE: (11C) Digit Sum - Dieter - 01-20-2018 09:23 AM
(01-20-2018 08:14 AM)wawa Wrote:  and here is a HP42s version of this program with a little modification in the way I use the stack
This one is shorter and requires less stack acrobatics. Works on the 41 and the 42s and also preserves Y.
01 LBL"DSUM"
02 0
03 X<>Y
04 LBL 01
05 10
06 /
07 FRC
08 ST+ Y
09 X<> L
10 INT
11 X≠0?
12 GTO 01
13 +
14 10
15 *
16 END
Note for 42s users: Y and L are stack registers (ST Y and ST L).
Dieter
RE: (11C) Digit Sum - Gamo - 01-20-2018 10:10 AM
Here is a "4 Digits Random Number to the Digit Sum" for Practice adding digits.
To Run:
Press A and calculator briefly show 4 digits number then return 0.
Try to add the digits in your head and check to see the number and answer.
Press R/S shown number and X<>Y show answer. Press X<>Y again will cycle to number and answer.
Program:
LBL A
FIX 0
RAN#
EEX
4
x
INT
STO 0
PSE
CLx
RCL 0
0
STO 1
Roll Down
LBL 1
10
FRAC
STO+1
LSTx
INT
X≠0 (TEST 0)
GTO 1
10^x
10^x
RCL 1
x
STO 2
CLx
R/S
RCL 2
RCL 0
R/S
Gamo
RE: (11C) Digit Sum - Dieter - 01-20-2018 05:21 PM
(01-20-2018 10:10 AM)Gamo Wrote:  Press A and calculator briefly show 4 digits number ...
The program generates a number between 0 and 9999, so this number may have one, two, three or four digits. A four-digit number, i.e. between 1000 and 9999, is generated this way:
RAN#
9
EEX
3
x
INT
EEX
3
Also, why do you waste another register (R2) for the digit sum? It is already stored in R1 (OK, 1/10 of it).
GTO 1
1
0
ST0x1
CLx
R/S
RCL 1
RCL 0
RTN
Every byte counts. ;-)
Dieter
