Error HVars - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Error HVars (/thread-9959.html) |
Error HVars - Tyann - 01-18-2018 05:14 AM Bonjour Suite à un bug dans un programme, je me suis aperçu que si vous appelez une variable inexistante avec HVars : Vous obtenez un message : Erreur donnés stat insuff. Hello Following a bug in a program, I realized that if you call a non-existent variable with HVars: You get a message: Error insufficient statistics data. RE: Error HVars - Giancarlo - 01-18-2018 03:22 PM Hello Tyann, Does it works to trap the error with an IFERR test? Just guessing a solution Giancarlo RE: Error HVars - Tim Wessman - 01-18-2018 05:05 PM Thank you. It was definitely returning the wrong error here - or at least the message was later changed to be more specific with stats and this case was missed being changed to something else. RE: Error HVars - Tyann - 01-18-2018 07:19 PM (01-18-2018 03:22 PM)Giancarlo Wrote: Hello Tyann, Bonjour Oui, on peut aussi utiliser : IF NOT POS(HVars,"nomvar") THEN Hello Yes, we can also use: IF NOT POS (HVars, "nomvar") THEN |
