Summation based benchmark for calculators
08-26-2018, 07:44 PM
Post: #121
RE: Summation based benchmark for calculators
Planning to do just that. I should get my Prime G2 on Tuesday or Wednesday.
08-26-2018, 10:15 PM
Post: #122
Casio fx-4000P
n=1000
t~388s
Result=1395.346288
I used this Dsz loop program which prompts for the number of iterations. The stopwatch was started when the number of iterations was entered at the prompt, '?':
Rad : ? → A : 0 : Lbl 1 : Ans + ∛ e sin tan⁻¹ A : Dsz A : Goto 1
— Ian Abbott
08-28-2018, 07:51 PM
Post: #123
Updated until post #122. If someone finds missing results, please report them!
Also some versioning is here: http://www.wiki4hp.com/doku.php?id=bench...g_exp_root
08-28-2018, 08:21 PM
Post: #124
Results from a Casio fx-720P with this program:
10 T=0
20 FOR X=1 TO 10:T=T+( EXP SIN ATNX)^(1/3): NEXT X
30 PRINT X
~4 sec. to produce 13.7118350167 for X=1 to 10
~43 sec. to produce 139.297187038 for X=1 to 100
08-28-2018, 08:21 PM (This post was last modified: 08-29-2018 07:45 AM by StephenG1CMZ.)
Post: #125
I have written a Savage benchmark for the Prime, which provides results for both approximate and exact (CAS) mode.
But I use an Android emulator and have no hardware to time results on.
http://www.hpmuseum.org/forum/thread-9626.html
Update: Anders has reported timings for Prime C and Prime G2 here:
http://www.hpmuseum.org/forum/thread-11202-page-3.html
Stephen Lewkowicz (G1CMZ)
08-28-2018, 09:28 PM (This post was last modified: 08-28-2018 09:52 PM by ijabbott.)
Post: #126
HP-27S
n=1000
t∼120s
Result=1395.3462877
BENCH=Σ(X:1:1000:1:EXP(SIN(ATAN(X)))^.333333333333)
Surprisingly fast compared to HP-42S.
(I originally used 'INV(3)' instead of '.333333333333', but it was slower due to the extra function overhead. The calculator has no cube root or nth root function.)
— Ian Abbott
08-29-2018, 04:19 AM (This post was last modified: 08-29-2018 04:22 AM by Tim Wessman.)
Post: #127
PrimeG2: ~7.22_s with run of 10 average.
SUM function, 100000
TW
08-29-2018, 06:17 AM (This post was last modified: 08-29-2018 06:18 AM by pier4r.)
Post: #128
Wow, before it was 19 seconds . Is the g2 version optimized or is it clocked at 800+ MHz?
The thingy starts to be golden in term of power expressiveness of HP ppl.
It is faster than an iPhone and that's not trivial to achieve.
I still have to put the results on the first page though.
08-31-2018, 07:53 PM
Post: #129
Updated up to post #127
09-05-2018, 05:36 AM (This post was last modified: 09-05-2018 11:52 AM by Gene.)
Post: #130
Casio fx-92+ Spéciale Collège
n=1000
t~163 s.
result=1395,346288
0->A
0->B
Répétez jusqu'a A=1000
A+1->A
B+3V(e^(sin(Arcttan(A))))->B
Afficher résult B
Gene: Translation below from Google.
Casio fx-92 + Special College
n = 1000
t ~ 163 s.
result = 1395.346288
0-> A
0-> B
Repeat until A = 1000
A + 1> A
B + 3V (e ^ (sin (Arcttan (A)))) -> B
Show result B
09-05-2018, 10:34 AM
Post: #131
Regarding the original summation test, I decided to feed it through my copy of x48-0.6.4. I got some slightly strange results, which seem to be dependent upon the machine that x48's running on, so I'm interested in knowing if anyone's done the test on a real 48SX, as I haven't seen one in pier4r's list of results. My program's below, but it's pretty much the sum from 1 to n for the original formula.
Quote:%And yes, you'll have to type in that sum symbol yourself (Right-Shift-U for the 48SX/GX)
\<< \-> CNT
\<< TICKS '\(\sum\)(X=1,CNT,XROOT(3,EXP(SIN(ATAN(X)))))' EVAL SWAP TICKS SWAP -
8192 /
Oh, and I finally managed to find a PDF manual for the SX; as most of you know, there are quite a few differences between the SX and GX and they were doing my head in. I still don't know how to do certain things I take for granted on my 50G, but things are considerably more spartan on the SX.
(Post 274)
Regards, BrickViking
09-05-2018, 10:36 AM
Post: #132
also anyone else with the prime G2 ?
09-05-2018, 10:41 AM (This post was last modified: 09-05-2018 10:54 AM by grsbanks.)
Post: #133
(09-05-2018 10:36 AM)pier4r Wrote:  also anyone else with the prime G2 ?
I have one. Just need 5 minutes to run the tests and report back!
Edit: Here's a screenshot of a bunch of tests...
[Image: screenshot_prime_g2.png]
09-05-2018, 12:23 PM
Post: #134
n=1000
t~163s
Result=1395.346288
With "Algorithmique" feature[/php]
09-05-2018, 02:26 PM
Post: #135
(09-05-2018 10:34 AM)brickviking Wrote:  Regarding the original summation test, I decided to feed it through my copy of x48-0.6.4. I got some slightly strange results, which seem to be dependent upon the machine that x48's running on, so I'm interested in knowing if anyone's done the test on a real 48SX, as I haven't seen one in pier4r's list of results. My program's below, but it's pretty much the sum from 1 to n for the original formula.
\<< \-> CNT
8192 /
(Post 274)
Using a slightly modified program (since I have TEVAL already built) my results for a real 48SX are:
n=1000
t=95.5s
Result=1395.3462877
09-06-2018, 09:30 PM
Post: #136
a different result for NUMWORKS (Python script)
Someone posted that 100000 iterations would take 84sec. My script does it within 68sec. Perhaps I made a mistake? I'm not at all experienced with Python.
So here is the short script
from math import *
x=0
for i in range(1,100001):
 x=x+pow(exp(sin(atan(i))),1/3)
print(x)
Result is 139560.97614110521
Günter
09-06-2018, 09:46 PM
Post: #137
(09-06-2018 09:30 PM)Guenter Schink Wrote:  a different result for NUMWORKS (Python script)
from math import *
x=0
print(x)
Günter
As was pointed out to me over in this thread, you can significantly speed up Micro Python code by doing the work inside a function.
This version runs in about 57 seconds on my Casio fx-CG50, producing 139560.9761410521:
from math import *
def RunTest():
  x=0
  print(x)
RunTest()
09-06-2018, 10:12 PM (This post was last modified: 09-06-2018 10:13 PM by Guenter Schink.)
Post: #138
from math import *
x=0
print(x)
Günter
from math import *
def RunTest():
  x=0
  print(x)
RunTest()
Thanks Dave,
I applied the changes as above, making it a function. The difference however is marginal, 65sec instead of 68. Seems to depend on the implementation of Python. But it's an improvement still.
Regards, Günter
edit: typo
09-06-2018, 10:23 PM
Post: #139
from math import *
def RunTest():
  x=0
  print(x)
RunTest()
Hi, Dave Britten
Does Micro Python support default arguments, like regular Python ?
If Yes, changing def RunTest() to def RunTest(pow=pow, exp=exp, sin=sin, atan=atan) should be faster.
Now, all variables are locals (pow, exp, sin, atan are variables too)
09-06-2018, 11:28 PM (This post was last modified: 09-06-2018 11:37 PM by ijabbott.)
Post: #140
(09-06-2018 10:23 PM)Albert Chan Wrote:  Does Micro Python support default arguments, like regular Python ?
You could assign those as variables within RunTest() itself.
import math
def RunTest(n):
  pow=math.pow
  exp=math.exp
  sin=math.sin
  atan=math.atan
  x=0
  for i in range(1,n+1):
  print(x)
RunTest(100000)
Finishes in ~53 seconds on fx-CG50.
— Ian Abbott
