Spreadsheet App Crashes & Buggy
09-02-2018, 07:24 PM
While trying to make Direct Step and Standard Step methods on the Spreadsheet App, it continually crashes and I loose work. I am trying to use the connectivity kit to set up the spreadsheets but it is causing me a lot of grief! Is anyone else having the same issues? I think I have the latest update so I am not sure how to fix.
09-02-2018, 08:43 PM
RE: Spreadsheet App Crashes & Buggy
(09-02-2018 07:24 PM)Kiyan Wrote: While trying to make Direct Step and Standard Step methods on the Spreadsheet App, it continually crashes and I loose work. I am trying to use the connectivity kit to set up the spreadsheets but it is causing me a lot of grief! Is anyone else having the same issues? I think I have the latest update so I am not sure how to fix. I guess it will help if you show exactly what you are inputting. — Ian Abbott |
09-02-2018, 10:34 PM
The spreadsheet app sometimes crashes on me too. The bigger the spreadsheet the more likely it is to crash. Turning the calculator off and back on often helps reduce data loss.
-road |
09-03-2018, 04:24 AM
Please provide some samples of these problematic spreadsheets when you have them as this is the first I've ever heard of similar things....
