Battery for HP-IL Peripherals
09-21-2018, 02:45 PM
I found this battery on Amazon
AGM Ct 3-6/6 V 3Ah lead acid battery And mounted it in 9114 and 3468. Works really well. Here the details on the Battery Manufacturer CTM Berlin System Lead non-woven battery (PB) Model: CT 3 – 6 Rated voltage: 6 V Nominal Capacity: 3 Ah (20hr) Pole 4.8 mm Length: 66 mm, width: 33 mm, height: 97 mm, Total height: 103 mm Weight: 590 g |
09-21-2018, 04:27 PM
RE: Battery for HP-IL Peripherals
(09-21-2018 02:45 PM)KimH Wrote: I found this battery on AmazonAmazon reports: "We found 0 results for "AGM Ct 3-6/6 V 3Ah lead acid battery"" Do you have a link or more concise search string? --Bob Prosperi |
09-21-2018, 04:49 PM
(09-21-2018 04:27 PM)rprosperi Wrote:(09-21-2018 02:45 PM)KimH Wrote: I found this battery on AmazonAmazon reports: This fits the bill (as described in OP) https://www.amazon.de/AGM-Blei-Akku-3-6-...B003UCKFSM |
09-21-2018, 05:15 PM
(This post was last modified: 09-21-2018 05:17 PM by Erwin.)
(09-21-2018 04:49 PM)Zaphod Wrote:(09-21-2018 04:27 PM)rprosperi Wrote: Amazon reports: Hallo, additional: https://www.akkuangebote.de/bleiakku-fue...ie/6-volt/ Others for the 3421A as an example: https://www.blei-akkus.com/AGM-wartungsfrei and here: https://www.akku.net/Akku-Info/1.86.APC....h-12V.html Regards Erwin |
09-21-2018, 05:19 PM
(This post was last modified: 09-21-2018 05:19 PM by Zaphod.)
(09-21-2018 05:15 PM)Erwin Wrote:(09-21-2018 04:49 PM)Zaphod Wrote: This fits the bill (as described in OP) Some of those you’re suggesting are 12volt ! This one from your selection of links is the OP: (6V with 3AH) https://www.akkuangebote.de/ctm-agm-batt...-3-ah.html |
09-21-2018, 05:20 PM
(This post was last modified: 09-21-2018 05:20 PM by Erwin.)
(09-21-2018 05:19 PM)Zaphod Wrote:(09-21-2018 05:15 PM)Erwin Wrote: Hallo, Those are only my sources - you have to filter them for your needs :-) |
09-21-2018, 05:37 PM
(This post was last modified: 09-21-2018 05:37 PM by Zaphod.)
RE: Battery for HP-IL Peripherals | |||
