Latest HP41 CL Update ERROR
09-24-2018, 05:45 AM
The latest HP41 CL Update returns an error: iMac:clupdate ~user$ java -jar clupdate-1.1.0.jar --update rom_files_180923.zip /dev/tty.usbserial 4800 07:21:34 --update [fileName: rom_files_180923.zip] [portName: /dev/tty.usbserial] [baudRate: 4800] 07:21:34 File rom_files_180923.zip loading ... Exception: IllegalArgumentException [message: Index for header 'Filename' is 1 but CSVRecord only has 1 values!] I've tried it several times. Re-downloaded the file to no avail. It usually goes smoothly. Not this time. ;-) Anyone else has that issue? Engineer & Senior IT Executive 2x HP41CL, HP41CX, HP48GX, HP50g, 2x82162A Printer, 2x82143A Printer, 2x HP-IL, 2x Card-Readers, PIL-BOX. |
09-24-2018, 06:49 AM
RE: Latest HP41 CL Update ERROR
I get an error as well when validating the rom-files:
Code: java -jar clupdate-1.1.0.jar --validate rom_files_180923.zip ================================================================================ CSV filename: rom_files_180923.zip/mem_ref_v2.txt ================================================================================ Exception: IllegalArgumentException [message: Index for header 'Filename' is 1 but CSVRecord only has 1 values!] Thus I assume that the mentioned file is corrupt. I suggest to contact Monte Dalrymple. HTH Thomas |
09-24-2018, 11:20 AM
Currently at work, I will look at it when I am back home tonight [GMT-4h].
Sylvain |
09-24-2018, 11:34 AM
(09-24-2018 11:20 AM)Sylvain Cote Wrote: Currently at work, I will look at it when I am back home tonight [GMT-4h]. Thanks Engineer & Senior IT Executive 2x HP41CL, HP41CX, HP48GX, HP50g, 2x82162A Printer, 2x82143A Printer, 2x HP-IL, 2x Card-Readers, PIL-BOX. |
09-25-2018, 04:16 AM
Monte has corrected the faulty rom files.
Download the new one (rom_files_180924.zip) and it should work. I have tested it on my side and it works on my CLv5. Sylvain |
09-25-2018, 03:12 PM
Thanks Sylvain
I updated today my CL and I can confirm the 100% functionality. Patrik |
