"jumping" between menus
10-06-2018, 10:37 AM
1) assuming that I am in APPS - EQuation Library - equation x - SOLVER: how to "jump" one level higher, so out of solver menu into the menu with equation on the screen?
2) assuming that i am in "right shift - LIB" menu and then I press :0: where I have several menus, one of them is 96 MENU. I named it STATm. if i press STATm I get 6 options in a row at the bottom of the display.
My question is, how to get out of this situation one level higher, so into situation where I will again see STATm at the bottom of the display? Thanks.
10-06-2018, 10:43 AM
RE: "jumping" between menus
I don't know any "up" method but you can jump to the previous menu via LS_L (press and hold left-shift, press "PREV"). LS L (left-shift without holding = PREV) is like NXT, just in the other direction.
10-06-2018, 12:18 PM
you have pretty much answered my question, thanks. Holding left shift is a thing which works exactly like I wished in many cases.
Most probably that is what I wanted to know ... I need some time to see if I am happy now. Thanks again.
10-06-2018, 05:19 PM
little request. Always specify the device you are using for later users that search for the same help. I presume you are talking about the hp 50g.
10-06-2018, 07:05 PM
The HLP49 documentation app for the 50g has a section on these simultaneous key combinations, that aren't marked on the keyboard.
Cambridge, UK
Casio, Rockwell 18R
10-06-2018, 07:30 PM
Quote:little request. Always specify the device you are using for later users that search for the same help. I presume you are talking about the hp 50g.
yes, it is 50g, sorry.
Quote:The HLP49 documentation app for the 50g has a section on these simultaneous key combinations, that aren't marked on the keyboard.
thanks, I will search it.
10-06-2018, 08:38 PM
see A Few Basics - Basic Shortcut Keys, which itself then links to Shortcut Keys.
the author uses + and - to differentiate between simultaneous and sequential key presses respectively, e.g:
LS-Nxt means LS then Nxt, which gives Prev, as marked on the key
LS+Nxt means LS and Nxt, which moves up in the menu hierarchy
Cambridge, UK
Casio, Rockwell 18R
10-07-2018, 03:08 AM
(10-06-2018 07:05 PM)cdmackay Wrote:  The HLP49 documentation app for the 50g has a section on these simultaneous key combinations, that aren't marked on the keyboard.
If you'd like a complete list of all HP 50g keyboard shortcuts, they can be found in Appendix G of the HP 50g Advanced User's Reference Manual.
<0|ΙΈ|0>
-Joe-
10-07-2018, 06:37 AM
cdmackay, joe, thanks for your hints.
