HP Prime undef for Limes. Maybe a Bug?
10-10-2018, 08:58 PM
Hello
I try to calculate the limit for a certain expression.
Unfortunately i dont get a result with the prime.
It should be -0.285
See here: https://www.symbolab.com/solver/limit-ca...D%5Cright)
Do i have to set some settings?
Or what can i do to solve the problem?
Thank you
10-10-2018, 09:32 PM
RE: HP Prime undef for Limes. Maybe a Bug?
Indeed, if you type:
limit((5-2*x)/(2*x^2-3*x-5),x,25/10)
you get the correct answer, but if you type:
limit((5-2*x)/(2*x^2-3*x-5),x,2.5)
you get undef.
-road
10-11-2018, 06:47 AM
THank you so much!
I never thought that decimal numbers could be a problem.
Is there an obvious reason to not allow decimal numbers or to force the user to enter it as a fraction?
Just for others: you can also use exact(2.5) instead of 25/10.
It should not be very hard for the HP-Team to implement the usage of the exact function behind the lim operation.
Anyway thank you very much Smile
Now i can do the excercises from our math lessons...
10-11-2018, 07:01 AM
Of course there is a reason:-)
The reason is that limit requires exact input to make simplifications (this is required here otherwise you get 0.0/0.0 or 0/0), with approx input, you could have rounding errors.
10-11-2018, 07:05 AM
Ok i see Smile
I also understand the requirement for exact inputs.
But sometimes, 2.5 is already exact as possible ^^
Here i would be happy if the HP would automatically convert the input to an exact fraction by themself.
10-11-2018, 08:39 AM
I got an answer in the oficcial HP Forum.
There is also an even simpler way to do this.
You first enter the "unexact" form of the lim with 2.5
Then press enter.
You get the undef answer
Now click on the lim in the history once and then press the a b/c key.
Now you see a converted version of the expression.
Click the converted expression and press enter twice.
Now you see the correct result.
10-11-2018, 10:22 AM (This post was last modified: 10-11-2018 10:24 AM by Tim Wessman.)
Glad my answer over there was helpful. Wink
Really is more just a way to quickly get to "exact" forms when you have decimals to ensure the cas behaves nicely when decimals are involved.
TW
10-12-2018, 06:17 AM
(10-11-2018 07:05 AM)blevita Wrote:  Ok i see Smile
This is dangerous. I added automatic conversion of floating points that look like integers (I mean for example 2.0, that looks like the integer 2 especially in Home), but 2.5 is *never* considered to be exact in the CAS, it might represent any real in a small interval around 2.5. If 2.5 is exact in your problem, you must enter it as 5/2.
10-12-2018, 03:11 PM
You can always make a CAS program to do that, such as:
#cas
limit_exact(a,b,c,d):=
BEGIN
 c:=exact(c);
 retrun subst(limit(a,b,c,d),b=c);
END;
#end
limit_exact(((5-2*x)/(2*x^2-3*x-5)),x,2.5,0)
will return -2/7.
-road
10-12-2018, 08:08 PM
(10-12-2018 03:11 PM)roadrunner Wrote:  You can always make a CAS program to do that, such as:
#cas
BEGIN
 c:=exact(c);
END;
#end
will return -2/7.
-road
It works only if I subst
retrun
with
return
VPN
10-13-2018, 07:04 PM
Hi, roadrunner
On your limit_exact(), why is subst(...) needed ?
Also, I think limit_exact() had a bug:
f(x) := ((5-2x) + sin(5-2x)) / (2x^2 - 3x - 5)
limit(f(x), x, 5/2, 0) ==> -4/7
limit_exact(f(x), x, 2.5, 0) ==> undef
limit_exact(f(x), x, 5/2, 0) ==> undef
BTW, exact(...) may not always return exactly what you wanted.
Returned rationals were an approximation (based on config epsilon setting) of float.
Example, with epsilon = 1e-6, exact(500000.5) return 500001
10-14-2018, 12:18 AM
Hi Albert,
You are right. It's not working for your function, f(x). The call to limit in the function seems to be getting the second parameter incorrectly. I'm not sure why; it seems to be getting a "b" instead an "x"
I thought using the subst command fixed that, but apparently not in all cases.
-road
10-14-2018, 01:42 AM (This post was last modified: 10-14-2018 02:46 AM by Albert Chan.)
This work, but first argument had to be function of 1 argument ...
limit_exact(f, v, d) :=
begin
    local x;
    assume(x, symbol);
    return limit(f(x), x, exact(v), d);
end;
10-14-2018, 02:17 PM
Check out this version:
#cas
BEGIN
 local x;
 assume(x,symbol);
 limit(subst(a,b=x),x,exact(c),d);
END;
#end
Now,
limit_exact(f(x), x, 2.5, 0) returns -4/7
limit_exact(f(t), t, 2.5, 0) also returns -4/7
It should work with any independent variable.
-road
10-14-2018, 04:29 PM
(10-14-2018 02:17 PM)roadrunner Wrote:  Check out this version:
#cas
BEGIN
 local x;
 assume(x,symbol);
END;
#end
Now,
-road
Great! - No coyote can catch you!
10-14-2018, 04:58 PM
Hi, roadrunner
I suggest not using x for the symbolic local variable.
Preferably some name that will never be used ...
limit_exact(x + y, x, 1, 0) ==> y+1, OK
limit_exact(x + y, y, 1, 0) ==> 2, BAD
10-15-2018, 12:04 PM
(10-14-2018 04:58 PM)Albert Chan Wrote:  I suggest not using x for the symbolic local variable.
That's also true for the variables a, b, c, and d. I have run into that issue before with CAS programs.
-road
10-16-2018, 09:35 PM
(10-14-2018 04:58 PM)Albert Chan Wrote:  Hi, roadrunner
#cas
exact_limit(Expr,Var,Val,Dir):=
BEGIN
  LOCAL ¬x;
  assume(¬x,symbol);
  limit(subst(Expr,Var=¬x),¬x,exact(Val),Dir);
END;
#end
Try that with any example.
CHAR(172) is that "hook" character.
