41CL - how to activate 9xxx configurations
03-19-2019, 08:12 AM
(This post was last modified: 03-19-2019 03:03 PM by wok.)
Last week I received my 41CL (V5 incl. time clone) and I am thrilled. I have worked through the available documentation and everything is pretty clear. The system is now updated to the latest rom_versions (21/02/2019) - it took just 20 minutes in CPONLY mode - and everything works as expected.
However, I have problems with loading predefined 9xxx configurations. In order to load i.e. 9MTH I need to have the extreme functions (YFNX) enabled at page 7. Whatever I do to load the 9MTH configuration leads to a configuration error, because the extreme functions are configured twice. Do I have to unprotect YFNX first ? Is there someone who would let me know the easiest way of activating a predefined 9xx configuration after Memory Lost ? |
03-19-2019, 05:24 PM
RE: 41CL - how to activate 9xxx configurations
(03-19-2019 08:12 AM)wok Wrote: Last week I received my 41CL (V5 incl. time clone) and I am thrilled. I have worked through the available documentation and everything is pretty clear. The system is now updated to the latest rom_versions (21/02/2019) - it took just 20 minutes in CPONLY mode - and everything works as expected. From the MEMORY LOST condition: XEQ "MMUCLR" "YFNX" XEQ "PLUGH" "YFNF" XEQ "PLUG1L" XEQ "MMUEN" XEQ "CFGINI" XEQ "PLUG" "9MTH 8" I notice that the display flashes something (perhaps "1Z DC") when the calc is turned off with this configuration. I don't know if it's supposed to do that or not. It doesn't come from YFNX. |
03-19-2019, 06:25 PM
(03-19-2019 05:24 PM)Monte Dalrymple Wrote: From the MEMORY LOST condition: Thank you very much Monte - this works indeed. This way the alternate configurations are initialised from the Plugs by CFGINI so that the extreme functions can recall them later on by number (RCLCFG 4-F). Then you use the Plug function to load the alternate configuration directly using the plug definition. It seems that the flashing message is caused by the Z4DL module. I will now dive into the incredible set of 9MTH modules mainly written and provided by Angel Martin. |
03-19-2019, 11:34 PM
(This post was last modified: 03-19-2019 11:34 PM by cdmackay.)
I was going to ask whether there was any point in trying to come up with a set of alternate configurations that left pages 6 & 7 free.
But perhaps a better idea is to just switch to an emptier config, when I want to print, or save data, via my newly-arrived PIL-box? Cambridge, UK 41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot/C47 Casio, Rockwell 18R |
03-20-2019, 01:15 AM
(03-19-2019 11:34 PM)cdmackay Wrote: I was going to ask whether there was any point in trying to come up with a set of alternate configurations that left pages 6 & 7 free. The "9HIL" configuration has pages 6 and 7 free. But you can't just PLUG it in because YFNX is in a different page for that configuration. So it's a multi-step process. It was a trade-off... |
03-20-2019, 05:59 PM
(03-20-2019 01:15 AM)Monte Dalrymple Wrote: The "9HIL" configuration has pages 6 and 7 free. But you can't just PLUG it in because YFNX is in a different page for that configuration. So it's a multi-step process. It was a trade-off... Yes, I was just being lazy; I need to come up with my own configs. But the suggestions given in the chart for the CFGINI command are a great starting point, thanks! Cambridge, UK 41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot/C47 Casio, Rockwell 18R |
