New Appoach for Random Number Generation???
03-21-2019, 12:06 PM (This post was last modified: 03-21-2019 11:50 PM by Namir.)
Hi All!
I thought of a new class of random numbers! Pick two different approximations of the same function, call them f1(x) and f2(x). Perform the following:
Using a seed of X in [0,1].
Calculate f1(x) and f2(x).
Calculate D = Abs(f1(x) – f2(x))
Calculate L = fix(log10(Diff)) to remove factional part
Calculate x = Diff / 10 ^ L
Calculate x = Frac(10000 * x)
Functions f1(x) and f2(x) should NOT return extremely small or ig values for argumens in [0, 1]. The last calculation step above obtains some numerical noise suitable as random values.
Here is sample code in Excel VBA using two approximations for the Normal CDF:
Option Explicit
Function Frac(ByVal x As Double) As Double
  Frac = x - Fix(x)
End Function
Function phi3(ByVal x As Double) As Double
' Page 1977
  Dim y As Double, Pi As Double
  Dim K As Double
  Pi = 4 * Atn(1)
  K = Sqr(2 / Pi)
  y = K * x * (1 + 0.44715 * x * x)
  phi3 = 0.5 * (1 + WorksheetFunction.Tanh(y))
End Function
Function phi4(ByVal x As Double) As Double
' Hammaker 1978
  Dim K As Double
  Pi = 4 * Atn(1)
  K = Sqr(2 / Pi)
  y = 0.806 * x * (1 - 0.018 * x)
  phi4 = 0.5 * (1 + -Sqr(1 - Exp(-y * y)))
End Function
Function Rand34(ByVal x As Double) As Double
  Dim Diff As Double
  Dim L As Integer
  Diff = Abs(phi3(x) - phi4(x))
  L = Fix(Log(Diff) / Log(10))
  x = Diff / 10 ^ L
  x = Frac(10000 * x)
  Rand34 = x
End Function
Sub go()
  Const max = 10000
  Dim x As Double
  Dim I As Integer
  Randomize Timer
  x = Rnd(1)
  For I = 1 To max
    DoEvents
    If x = 0 Then x = Frac(Log(4 * Atn(1) + I) / Log(10))
    x = Rand34(x)
    Cells(I, 1) = x
  Next I
End Sub
The resulting numbers have a mean close to 0.5 and standard deviation close to 0.28.
You can use simpler approximations for the Normal or other functions. Ultimately, your choices for f1(x) and f2(x) are HUGE!!!
Namir
03-21-2019, 12:47 PM
RE: New Appoach for Random Number Generation???
I think (though it needs some analysis) that numeric noise is rather predictable. Given any two input floating point numbers, the roundoff error is easily obtainable. Knuth has a pretty good analysis in Volume 2.
03-21-2019, 01:53 PM
(03-21-2019 12:06 PM)Namir Wrote:  your choices for f1(x) and f2(x) are HUGE!!!
Letting user pick f1 and f2, without any statistical analysis, is probably a bad idea.
With above setup, it is conceivable that for some seed, the period is low, possibly even 1.
Also, I think you mean L = floor(log10(Diff)), x = FRAC( Diff / 10^(L-4) )
In other words, replacing 5 sig. digits of Diff, with a decimal point.
03-21-2019, 03:14 PM (This post was last modified: 03-21-2019 03:15 PM by Namir.)
Selecting the functions f1 and f2 (and they should be appomixations to the same target function) should be done along with testing them of course. The selection is an open wide field and can be a proverbial mine field if the choices ae not made wisely and tested. In other words, with freedom comes responsibility.
In calculating L, I used two seperate statements for the sake of clarity.
03-21-2019, 07:17 PM
With seed = 0.123, I created million "random" bytes = int(256*(x = rand34(x)))
Test the bytes with ent.exe, it failed the Chi-Square test.
Quote: If the percentage is greater than 99% or less than 1%, the sequence is almost certainly not random.
Entropy = 7.999695 bits per byte.
Optimum compression would reduce the size
of this 1000000 byte file by 0 percent.
Chi square distribution for 1000000 samples is 422.05, and randomly
would exceed this value less than 0.01 percent of the times.
Arithmetic mean value of data bytes is 127.3923 (127.5 = random).
Monte Carlo value for Pi is 3.140892564 (error 0.02 percent).
Serial correlation coefficient is 0.000456 (totally uncorrelated = 0.0).
BTW, rand34() *crashed* with seed of 0.0, due to log10() domain error.
03-21-2019, 07:51 PM (This post was last modified: 03-21-2019 07:52 PM by Namir.)
Here is another example, this time using two Calculator-oriented PRNGs! This is somewhat ironic :-)
Option Explicit
  Frac = x - Fix(x)
End Function
Function Rnd1(ByVal x As Double) As Double
  Rnd1 = Frac(997 * x)
End Function
Function Rnd2(ByVal x As Double) As Double
  Dim Pi As Double
  Pi = 4 * Atn(1)
  Rnd2 = Frac(Pi + x) ^ 3
End Function
Function Rand12(ByVal x As Double) As Double
  Dim Diff As Double
  Dim L As Integer
  Diff = Abs(Rnd1(x) - Rnd2(x))
  x = Diff / 10 ^ L
  x = Frac(10000 * x)
  Rand12 = x
End Function
Sub go()
  Const max = 10000
  Dim x As Double
  Dim I As Integer
  Randomize Timer
  x = Rnd(1)
  For I = 1 To max
    DoEvents
    x = Rand12(x)
    Cells(I, 1) = x
  Next I
End Sub
Again, the ideas is to get the numerical noise out of low decimal places.
Namir
Heretic Math Hobbyist
03-21-2019, 11:52 PM
(03-21-2019 07:17 PM)Albert Chan Wrote:  With seed = 0.123, I created million "random" bytes = int(256*(x = rand34(x)))
I updated the SUB go in the first message to handle zero random numbers.
03-23-2019, 02:34 AM
You could sample the last bit or byte of two separate computations and combine them by adding or differincing mod 2 or mod 256. These should be in floating point numbers where some things get discarded. There's no reason to use the same computation. I don't know how good it would be but one could pick off the last few bits of the some numbers being used in a matrix computation (which uses lots of floating point); then add them mod 2^k with k bits. The last few bits should be almost independent and adding several of them smooths out the distribution. Note that using the most significant bits or bytes doesn't work because of Benford's law (discovered by Simon Newcomb).
