Psion HC 110
06-11-2019, 03:11 PM
Psion HC 110
What language can you program this computer in?
06-11-2019, 03:47 PM
RE: Psion HC 110
(06-11-2019 03:11 PM)MNH Wrote:  What language can you program this computer in?
If it's like the rest of the Psion line, it has its own language called OPL.
https://en.wikipedia.org/wiki/Open_Programming_Language
Tom L
Cui bono?
06-11-2019, 04:52 PM
RE: Psion HC 110
Can the processor be addressed directly, if that's the correct terminology, with assembly language?
06-11-2019, 07:02 PM
RE: Psion HC 110
80C86 16 bit processor
Quote ‘Windows PC-based Integrated Development Environment for OPL language; further Software Development Kits (SDKs) are available for OPL and C; specialist communications and data related SDKs are also available’
Denny Tuckerman
06-11-2019, 08:13 PM
RE: Psion HC 110
(06-11-2019 04:52 PM)MNH Wrote:  Can the processor be addressed directly, if that's the correct terminology, with assembly language?
Hi, you can find the HC programming guide here http://basic.hopto.org/basic/manuales.php
I think than you can also program an app on OPL in any of the other psions pdas in one of the Solid State Disks, mainly series 3 and MX, compile in them and then change the SSD to the HC to run the app. Although I have all this machines, including the HC, never tried.
Calculadoras programables BASIC años 80-90:
06-12-2019, 03:39 PM
RE: Psion HC 110
Thank you all for replying!
06-13-2019, 06:59 PM (This post was last modified: 06-13-2019 07:43 PM by Csaba Tizedes.)
RE: Psion HC 110
Just Googled for PSION HC 110, the first pdf was this:
(I hate Google on phone, it can't copy the link of the downloadable stuffz, but the site is: http://oldcomputer.info/index.htm)
UPDATE: http://oldcomputer.info/others/psion/HC-PG.pdf
You can find there:
CHAPTER 2
WRITING SOFTWARE FOR THE HC
Basic programming choices
Choice of programming language
The two main high-level programming languages for the HC are Opl and C.
I have one somewhere, as I can remember it has a DOS (or something DOS-like) on it, I guess as a shell. I never used it and not really liked.
Btw: good luck!
Csaba
06-14-2019, 04:33 PM
RE: Psion HC 110
As others have stated, it's OPL Smile
I myself have a Psion Series 3a that's in need of repair which I used many years ago, when I was only about 15 years old or so. I have fond memories of programming graphics algorithms in OPL on that little machine when I was on a road trip Smile
Jonathan
Aeternitas modo est. Longa non est, paene nil.
06-14-2019, 04:36 PM
RE: Psion HC 110
(06-11-2019 07:02 PM)Leviset Wrote:  80C86 16 bit processor
Yes -- it's a custom 8086 chip. But, the OS uses preemptive multitasking with message passing IIRC. The OS is Epoch 16 I think.
Jonathan
06-14-2019, 09:23 PM (This post was last modified: 06-14-2019 09:23 PM by MNH.)
RE: Psion HC 110
Thanks all for the additional posts! The HC 110's shape reminds me of the Corvallis-Micro-Technology-MC5GT I used in 1994 on an FDOT project in Palm Beach County, FL. It had an environmental case and an air release valve for those who worked at higher altitudes. I think it was programmable in BASIC. I don't think it ever crashed on me. The attached picture is not the MC5GT I used.
[attachment=7380]
