emu48 now for android-OS
06-07-2019, 09:55 PM
Post: #81
RE: emu48 now for android-OS
Thanks a lot Régis for your answers - much appreciated. Keep up the good work !
Cheers |
06-07-2019, 10:09 PM
Post: #82
(06-07-2019 09:33 PM)Regis Cosnier Wrote: Emu71 for Android is still a work in progress. I hope to add it when I have the time. I hope that is coming, it will be amazing to have Christoph's EMU71 on an Android tablet. I'll get a new tablet just for that. BTW, what is the minimum Android version these EMUxx apps will run on? --Bob Prosperi |
06-07-2019, 11:28 PM
Post: #83
Why emu48 Android app have the Roms and Emu42 app not?
06-08-2019, 09:12 AM
Post: #84
(06-07-2019 09:33 PM)Regis Cosnier Wrote:(06-05-2019 11:21 AM)Vincent Weber Wrote: ... I found it easier to leave the KML and KMI files unedited, and rename the other files to match the expected case. The files are named consistently within the KML and KMI files. — Ian Abbott |
06-08-2019, 09:18 AM
Post: #85
(06-07-2019 09:33 PM)Regis Cosnier Wrote:(06-06-2019 02:28 PM)ijabbott Wrote: ... Excellent! Thanks a lot. I look forward to trying it out. — Ian Abbott |
06-08-2019, 09:49 AM
Post: #86
RE: emu48 now for android-OS | |||
06-09-2019, 03:16 PM
Post: #87
Hi Regis,
I think I found 2 bugs with Emu42. 1/I was on the 32sii, I left the phone for a while,.when I came back the LCD was blank, as if the calc was turned off, but it was not turned off. The keys continue to register... I switch to a 27s state file and same, blank LCD, but the calc still alive since I could hear beeps... Only killing the app and relaunching it solved the issue. 2/32SII still, coming back to it after a while would have the calculator lag a lot. You press "74" and those figures take seconds to appear in block, all at the same time. The problem disappears by itself after a while playing with the calc. Strange... Thanks and cheers |
06-09-2019, 04:47 PM
Post: #88
There is a simulator of HP 42S on Android called Free42 which haven't any HP code included. I believed HP has liberated the ROMs of HP-42S too.
06-09-2019, 07:26 PM
Post: #89
(06-09-2019 04:47 PM)Anderson Costa Wrote: There is a simulator of HP 42S on Android called Free42 which haven't any HP code included. I believed HP has liberated the ROMs of HP-42S too. That is a SIMULATOR and does NOT have a copy of the Rom in the coding. Believe me, if HP had released the rom for the HP42S everyone here would know it. It would also be available for download somewhere on the internet. |
06-10-2019, 07:02 AM
Post: #90
I'm installing the emu42 into my Android.
I'm a bit confused as to where do the kml & Rom files go? (once I copy them from emu42v) Thanks, Robin |
06-10-2019, 07:46 AM
(This post was last modified: 06-10-2019 07:46 AM by ijabbott.)
Post: #91
(06-10-2019 07:02 AM)zswobbie12 Wrote: I'm installing the emu42 into my Android. I created a folder called Emu42 in the main user home directory (/storage/emulated/0 or /storage/self/primary), but you can call the directory what you want and put the stuff in there. Emu42 asks you where you put them. Be careful of the filenames referenced by the KML and KMI files. Android filesystems are case-sensitive, unlike Windows. You will probably need to either edit the KML and KMI files to fix the referenced filenames, or just rename the referenced files (including the KMI files themselves) to match the names used inside the KML and KMI files. — Ian Abbott |
06-10-2019, 09:41 AM
Post: #92
Thanks, Ian.
I think I've done that correctly. Regards, Robin |
06-11-2019, 04:50 PM
Post: #93
(06-07-2019 10:09 PM)rprosperi Wrote:(06-07-2019 09:33 PM)Regis Cosnier Wrote: Emu71 for Android is still a work in progress. I hope to add it when I have the time. Emu48 need Android 4.4 but if you want to use the custom KML/ROMs (and not the embedded KML/ROMs) you need Android 5.0 because when you [Select a Custom KML script Folder..], you actually give the permission to the application to read any files in this folder. And that feature is only enable since Android 5.0 (API 21)! And because there is no embedded KML/ROMs in Emu42 and Emu71 for Android, you need Android 5.0 too! (06-09-2019 03:16 PM)Vincent Weber Wrote: Hi Regis, Oh, I'm not able to reproduce, but if I can catch those bugs, I will try to fix it. What is you Android version and device model? And actually, after a period of 10 minutes, the HP32SII goes to sleep and tapping the 'on' key wakes it up, but your issue seems more than that... I apologize for not answering all the messages! |
06-11-2019, 08:45 PM
Post: #94
(06-11-2019 04:50 PM)Regis Cosnier Wrote:Hi Regis,(06-07-2019 10:09 PM)rprosperi Wrote: I hope that is coming, it will be amazing to have Christoph's EMU71 on an Android tablet. I'll get a new tablet just for that. Android 9.0, Samsung Galaxy s8. I'm fully aware of the auto-off yet it is not this, on does not turn on the screen again. It only happened once to me so far, not easy to reproduce ... What about the lag issue ? Thanks and cheers |
07-12-2019, 10:38 AM
Post: #95
(06-11-2019 08:45 PM)Vincent Weber Wrote: What about the lag issue ? I think I reproduce one time your lag issue but with Emu48. It is difficult to catch such intermittent issue. If someone has a fully reproducible scenario, I could try to understand and fix it (may be about the timers...). Else, I just update Emu42 to version 1.1 and Emu48 to version 1.5. Both apps share common updates like: * Infrared printer simulator based on the Christoph Giesselink's HP82240B Printer Simulator for Windows. * Add the macro support. * Fix copy/paste string in the stack. * Fix USB keyboard mapping issue. On+D now works for hp49/50 (ROM version 2.10 not 2.15). The next challenges are: * Allow to save the HP49/50 Flash in an external file. * To pinned the LCD when swiping between the two keyboards parts (for clamshell calculators like HP28). * Fix the issues with the options "Hide the status/navigation bar" on some devices. * Fix the intermittent lags |
07-12-2019, 12:33 PM
Post: #96
Thanks a lot Régis, much appreciated !
Re the lag issue, I can't reproduce on demand, unfortunately... There is still the clock issue on Emu48 (auto+off, ON then clock not in synch with Android). Cheers |
07-12-2019, 04:43 PM
Post: #97
There is a strange new issue: on the 28S, the LCD now has what seems to be a scratch - amore or less horizontal line at about one third starting from the top, which colour is lighter than the rest of the LCD !?
07-20-2019, 03:14 PM
Post: #98
(07-12-2019 04:43 PM)Vincent Weber Wrote: There is a strange new issue: on the 28S, the LCD now has what seems to be a scratch - amore or less horizontal line at about one third starting from the top, which colour is lighter than the rest of the LCD !?I'm not able to reproduce. Could you post a snapshot and the KML file, please? |
07-20-2019, 05:10 PM
Post: #99
Hi Regis,
Here we go. I'm using Christoph's real 28S for 1024*768, and here is a snapshot, you see clearly the scratch line... Thanks and cheers |
07-20-2019, 07:16 PM
Post: #100
(07-20-2019 05:10 PM)Vincent Weber Wrote: Hi Regis, What effect does pinch-zooming the calculator have on the scratch? What if you open the underlying REAL28S.BMP file in the Gallery app? (Other picture viewers are available). Is the scratch still present? — Ian Abbott |
