Plot equation in Home view (e.g Function plot) using result from CAS view
07-19-2019, 07:37 AM
In many cases, I have got analysis result in CAS view with x (lower-case x) as a variable. I then need to draw the graph of this equation in Home view. However, in Home view, it accepts X (upper-case x) as a variable. What I'm doing is to change from x to X manually.
Is there any better way to allow me to have result from CAS to plot in Home view directly without manually changing it.
07-19-2019, 02:11 PM (This post was last modified: 07-19-2019 02:14 PM by toshk.)
RE: Plot equation in Home view (e.g Function plot) using result from CAS view
Make sure you are on Function App.
On cas screen type F1(x):=your cas equation
Or
Just use cas function. plotfunc()
07-19-2019, 02:13 PM
(07-19-2019 07:37 AM)teerasak Wrote:  In many cases, I have got analysis result in CAS view with x (lower-case x) as a variable. I then need to draw the graph of this equation in Home view. However, in Home view, it accepts X (upper-case x) as a variable. What I'm doing is to change from x to X manually.
F0 through F9 are the global variables for functions to be plotted. You can use these within the CAS environment and define, for example, F1 to be a function to plot. In CAS view, functions take the form similar to: (x)->(x^2+2*x-3). So you can do something like:
F1:=x->x^2-4;
Notice that the calculator will automatically convert to upper case and return: (X)->(X^2-4). Since the variables of functions are just placeholders, you could really use whatever variable you want. However, the system variables F0 through F9 only accept X as their placeholder variable (hence the auto-conversion).
Here's a short example of how you can use this in your calculations:
g1:=x^3-4*x^2+2*x-1;
g2:=diff(g1,x);
F1:=unapply(g2,x);
In this example, diff() computes the derivative, and unapply() turns the expression (in this case, g2) into a function whose placeholder variable is 'x'. Since we are saving the result into F1, it will auto-convert for us.
Graph 3D | QPI | SolveSys
07-19-2019, 09:38 PM
F1:=x->x^2-4;
g2:=diff(g1,x);
F1:=unapply(g2,x);
I was making a script for my control systems class and needed to plot some resulting expressions in the function app using "F1:=...". It works perfectly from the CAS environment, but doing it in a #cas function simply attributes the name of the variable that contained the expression to F1 in my case.
An example:
#cas
test(myPoly):=
BEGIN
LOCAL fcn;
fcn:=poly2symb(myPoly,x);
F1:=unapply(fcn,x);
RETURN fcn;
END;
#end
Am I doing something wrong?
07-20-2019, 12:25 AM (This post was last modified: 07-20-2019 12:41 AM by toshk.)
Try this;
#cas
test(myPoly):=
BEGIN
L0:=myPoly //myPoly pass straight up to my Poly2symb cause your error; but saving it to L0 forces it to list
STARTAPP(Function); //F1 is not only reserved Var for Function App but also Spreadsheet
F1:=unapply(poly2symb(L0,x),x);
RETURN F1(x);
END;
#end
Also Function App can straight up take some built in function:
F1 type in poly2symb({1,2,3},X)
07-21-2019, 03:27 PM
Thank you all for your help. That works!
