HP-21 malfunction
11-14-2019, 02:40 PM
(This post was last modified: 11-14-2019 02:41 PM by Moggul.)
HP-21 malfunction
I recently acquired an HP-21 and am trying to resurrect it.
The battery pack was in very bad shape so when connected to the charger the display was erratic, showing a flickering 0 in the rightmost digit. After installing fresh rechargeable batteries the display showed a single strong 0, and now it shows all 0s without any flickering (see pic sequence). This is both when connected to the charger and when powered by the batteries alone. Is the calculator resurrectable or should I go the Panamatik route? Thanks!!! 11C 12C 15C 17BII 18C 19BII 21 25 27S 28S 32E 32S 32SII 33C 33S 34S 35S 38C 39gs 39GII 40gs 41C 41CV 41CX 42S 45 48G+ 48GII 49G 49G+ 50 67 71B 97 |
11-14-2019, 03:10 PM
RE: HP-21 malfunction
This is almost certainly a dead ACT. A PANAMATIK kit is the best solution.
11-14-2019, 03:49 PM
Connecting the charger with a bad battery pack (or no batter pack installed) is one of the quickest way to damage one of the HP-2X (Woodstock) or HP-3X (Spice) series calculators. Many collectors charge the batteries externally (or use non-rechargeable batteries) just to be on the safe side.
11-15-2019, 12:09 PM
PM sent. Ignazio ______________________________________ RPN...What else! |
