Finding the number of digits on the iPhone Calculator
11-22-2019, 04:06 PM
I'm trying to figure out the number of internal digits used in the iPhone standard Calculator App but I'm not sure I'm doing it right. By calculating 1/3 and removing all the visible digits I start seeing weird results after the 20th digit or so. I guess it's an artifact caused by the binary representation? Is there a way to infer the exact number of binary digits used? I guess it's 64 bits but I want to be able to test my guess. Any help appreciated! Thanks! Software Failure: Guru Meditation -- Antonio IU2KIY |
11-22-2019, 05:47 PM
(This post was last modified: 11-22-2019 08:22 PM by Albert Chan.)
RE: Finding the number of digits on the iPhone Calculator
Try to find eps, such that eps + 1 - 1 = 0
For example, my ipad Sci:Pro Calc apps has 128 bits precision Code: 2 ^ -127 + 1 - 1 = Update: it is safer to double check around found eps, since 1+eps is a half-way case. 3e-39 + 1 - 1 → 5.877471754111438e-39 2e-39 + 1 - 1 → 0 |
11-22-2019, 06:36 PM
nice trick, thank you!
Using this method it turns out it's 64 bit precision Software Failure: Guru Meditation -- Antonio IU2KIY |
