(49G) OEIS A035327
12-31-2019, 05:50 PM
(This post was last modified: 12-11-2022 05:11 AM by Gerald H.)
(49G) OEIS A035327
Edit 2022-12-11: Programme slightly improved
For integer input N > -1 the programme returns the Nth element in the sequence https://oeis.org/A035327 Not a masterpiece but does use ←A. Code: « Improvements welcome. |
12-31-2019, 09:11 PM
RE: (49G) OEIS A035327
Hi Gerald
Nice to see you posting sequences again. Thanks especially for posting a program using compiled local variables, which still make my head spin. Studying your program may help. While I certainly can't improve on your program, I do have one from a completely different angle, based on the structure of the sequence. Given an integer n, this program returns a list of the first 2^(n+1) terms. So for example, given the number 5 the program will return the first 64 terms. This program also uses the ListExt command LSEQR. Code:
