hp 39gii calculator programming
02-18-2020, 04:05 PM
hi, I do not find the programming to be able to calculate the derivative as that present on the hp 39gs calculator.
The derivative must appear in Y1 as in the attachment, would it be possible to obtain this program? Thanks so much. |
02-19-2020, 09:19 PM
RE: hp 39gii calculator programming
It's not a program that you can download or type in - it's because the 39gii and 39gs are fundamentally different machines.
You can obtain a copy of the 39gii manual here and there is a (very) brief description of the differential function on page 160. However, it should be enough to let you evaluate your example. |
02-20-2020, 01:48 PM
Are there any multilingual manuals for 39gii somewhere?
Hardware: Hp48S - Hp50g (5x black + 1 blue) - HP39gII - Hp27s - Casio fx-CG50 |
02-20-2020, 03:26 PM
(02-20-2020 01:48 PM)franz.b Wrote: Are there any multilingual manuals for 39gii somewhere? Apparently HP have removed the user guides from their sites. Google search gave me a few more user guides for Spanish and this one here that looks like German: https://www.google.com/url?sa=t&source=w...abKurplgPe Jose Mesquita RadioMuseum.org member |
02-20-2020, 10:36 PM
(02-20-2020 03:26 PM)jebem Wrote:(02-20-2020 01:48 PM)franz.b Wrote: Are there any multilingual manuals for 39gii somewhere? thanks! but... actually I need the Italian version... with which keywords did you search on google? I can't find anything Hardware: Hp48S - Hp50g (5x black + 1 blue) - HP39gII - Hp27s - Casio fx-CG50 |
02-21-2020, 07:22 AM
(02-20-2020 01:48 PM)franz.b Wrote: Are there any multilingual manuals for 39gii somewhere? If you install the 39gII Virtual Calculator located here, you'll find in the "\Program Files (x86)\Hewlett-Packard\HP 39gII Virtual Calculator" directory the following manuals: -a---- 10/1/2013 6:06 PM 3079561 Users_Guide_CHS.pdf -a---- 10/1/2013 6:06 PM 3255753 Users_Guide_DEU.pdf -a---- 10/1/2013 6:06 PM 1839395 Users_Guide_EN.pdf -a---- 10/1/2013 6:06 PM 3176786 Users_Guide_ESP.pdf -a---- 10/1/2013 6:06 PM 3867589 Users_Guide_FRA.pdf -a---- 10/1/2013 6:06 PM 3157864 Users_Guide_ITA.pdf -a---- 10/1/2013 6:06 PM 3141563 Users_Guide_NLD.pdf You can open the Users Guide directly from the 39gII Virtual Calculator in the Help menu. The one corresponding to the language selected for the Virtual Calculator (in the Calculator menu) will be opened. |
02-21-2020, 07:44 AM
(02-21-2020 07:22 AM)Didier Lachieze Wrote:(02-20-2020 01:48 PM)franz.b Wrote: Are there any multilingual manuals for 39gii somewhere? Thank you that has been useful |
02-21-2020, 08:00 AM
GREAT!
Thanks a lot! Hardware: Hp48S - Hp50g (5x black + 1 blue) - HP39gII - Hp27s - Casio fx-CG50 |
