Conversion to Binary and IEEE-754 Binary
06-27-2020, 01:35 PM
Converting to Binary
The program BASE2 can convert any real number in Base 10 to Base 2. This extends on the built in base conversions, which works on integers only. BASE2 returns a string with precision up to 23 bits. Negative numbers will have the negative sign instead of a 2's compliment. HP Prime Program BASE2 Code: EXPORT BASE2(s) Examples: BASE2(18.675) returns "10010.101011001100110011" BASE2(-4.3825) returns "-100.01100001111010111000" BASE2(π) returns "11.001001000011111101101" Converting to IEEE-754 Format The program IEEE754 converts any real number in decimal base to binary in IEEE-754 floating point format. A binary number in this format consists of a string of 32 bits: Bit 1 is the sign bit: 1 for negative numbers, 0 for positive numbers The next eight bits is the exponent bit: The exponent bit has a bias of 127. When converting to binary, 127 must be added to the exponent. (Example: 17 * 2^3. The exponent bit is 127 + 3 = 130). When converting to decimal, subtract 127 from the exponent word. The last 23 bits consist of the mantissa. The function returns a string with spaces between the sign, exponent, and mantissa sections for readability. HP Prime Program IEEE754 Code: EXPORT IEEE754(s) Example: IEEE754(2100) returns "0 10001010 100000110100000000000000" 2100 -> 100000110100_2 -> 1.00000110100_2 * (2_10) ^ (11_10) "moving the decimal point left 11 spaces" Exponent bit: 127 + 11 = 138 (138_10 -> 10001010_2) IEEE754(28.725) returns "0 10000011 11100101110011001100110" IEEE754(-19.5) returns "1 10000011 10011100000000000000000" Source: Sivaraman, Abishalini. "Decimal to IEEE 754 Floating Pont Representation" YouTube Video Published December 4, 2016 https://www.youtube.com/watch?v=8afbTaA-...4_mdWQE84q Petryk, Steve. "HOW TO: Convert Decimal to IEEE-754 Single-Precision Binary" YouTube Video. Published October 25, 2015. https://www.youtube.com/watch?v=tx-M_rqhuUA Blog link: http://edspi31415.blogspot.com/2020/06/h...-ieee.html |
06-27-2020, 08:37 PM
(This post was last modified: 06-29-2020 12:12 PM by Albert Chan.)
RE: Conversion to Binary and IEEE-754 Binary
(06-27-2020 01:35 PM)Eddie W. Shore Wrote: BASE2 returns a string with precision up to 23 bits. IEEE-754 single precision has 24-bits precision, not 23. To complement IEEE754(), may be a good idea to match it. BASE2(π) → 11.001001 00001111 11011011 IEEE754(π) → 01000000 01001001 00001111 11011011 Quote:IEEE754(2100) returns "0 10001010 100000110100000000000000" All 3 examples were wrong. Using online float-converter, you should get this instead: IEEE754( 2100 ) = 01000101 00000011 01000000 00000000 IEEE754(28.725) = 01000001 11100101 11001100 11001101 IEEE754(-19.5 ) = 11000001 10011100 00000000 00000000 (06-27-2020 01:35 PM)Eddie W. Shore Wrote: Sivaraman, Abishalini. "Decimal to IEEE 754 Floating Pont Representation" YouTube Video Published December 4, 2016 https://www.youtube.com/watch?v=8afbTaA-...4_mdWQE84q Both videos does not take into account of rounding-to-nearest, for the last bit. Using Steve example, for x = 45.45 gcc:1> float x = 45.45f /* suffix f required, otherwise value implicitly converted to double, back to float */ gcc:2> X(*(unsigned*) &x) 0x4235cccd Repeating bits 0xcccc ... should rounded-up to 0xcccd --- If conversions were done in binary, there is also a possibility of double-rounding errors. >>> import gmpy2 >>> x = gmpy2.mpfr('0.50000020861625671') >>> print format(x,'a') # rounded 53 bits 0x8.000038p-4 Converting to double precision, x = 0x0.8000037fffffffb8... , got rounded-up. This happens to be half-way case for single-precision, which got rounded-up again. >>> b = 2**(53-24)-1 >>> print format(x+b-b,'a') # rounded 24 bits 0x8.00004p-4 Many online float converters got this one wrong: 0x0.800004 Above converter work very well, and got it right: 0x0.800003 Doing by hand, just scale the number to 24 bits: 0.5000002086162567 = 8388611.4999999997673472 / 2^24 Round-to-nearest, we have 8388611/2^24 = 0x800003p-24 = 0x0.800003 Or, you can try the decimal/binary converter 0.5000002086162567 = 0b0. 10000000 00000000 00000011 01111111... |
06-29-2020, 01:33 PM
(06-27-2020 01:35 PM)Eddie W. Shore Wrote: Bit 1 is the sign bit: 1 for negative numbers, 0 for positive numbers Another interpretation is to think of exponents field and the mantissa overlapped on the imply bit. For IEEE single, instead of bias of 127, do offset 126 Example: x = 2100 = 1.025390625 * 2^11 = 0b1.000001101 * 2^(0b10001001 - 126) Code: sign = 0 This has the advantage of extending conversion to sub-normal, without special treatment. (i.e. when mantissa cannot converted to pattern 1.xxx ..., with bexp already reached 0) Example: x = 1e-40f ≈ 71362.38 / 2^149. Since 71362 < 2^24, bexp = 0 → bits = 71362 = 0b 00000000 00000001 00010110 11000010 gcc:1> unsigned u = 71362 gcc:2> G(*(float*) &u) 9.9999461011147596e-041 gcc:3> G(1e-40f) /* confirm */ 9.9999461011147596e-041 |
06-29-2020, 01:58 PM
Albert,
I reverted the post to draft status (the entry is not live on my blog), I am going to take a look at the code again. Thank you for bringing this to my attention. Eddie |
08-02-2020, 02:51 PM
(This post was last modified: 08-02-2020 02:52 PM by Eddie W. Shore.)
Here is my second attempt at it, except I just concentrated at the conversion to binary, with a user-given precision level.
To help with rounding the number, I first round the number to the nearest 1/2^n, then convert the result to binary. I have not retried the IEEE-754 yet. The program RBIN converts any real number in base 10 to base 2, including non-integers and negative numbers. The result is displayed as a string. RBIN will need two arguments: the number to be converted and the precision level. For the precision level: 1 rounds the number to the nearest 1/2 before conversion. 2 rounds the number to the nearest 1/4 before conversion. 3 rounds the number to the nearest 1/8 before conversion. 4 rounds the number to the nearest 1/16 before conversion. and so on. HP Prime Program: RBIN Code: EXPORT RBIN(x,p) Examples: RBIN(-0.985,3) returns "-1" RBIN(-0.985,6) returns "-.111111" RBIN(-0.985,9) returns "-.111111000" RBIN(860.63,3) returns "1101011100.101" RBIN(860.63,6) returns "1101011100.101000" RBIN(860.63,9) returns "1101011100.101000011" Link: http://edspi31415.blogspot.com/2020/08/h...sions.html |
