Free Textbooks from Springer
06-28-2020, 02:42 PM (This post was last modified: 06-28-2020 02:43 PM by Maximilian Hohmann.)
For those who have not read it elsewhere: Springer/Nature has recently granted free access for download of a wealth of textbooks on variuos topics in science, mathematics and engineeriing:
https://www.springernature.com/gp/librar...u/17855960
It is a two stage process: First you download an Excel spreassheet with a database listing of the titles which then contains the relative download links. The publications themselves are available in .pdf ane .epub format.
There are only two calculator specific books (both about clinical data analysis) but lots and lots about other topics frequently discussed on this forum.
If only I knew where to take the time to read all of those...
Max
06-28-2020, 03:57 PM
RE: Free Textbooks from Springer
Wow !!, 383 PDF Books for FREE, that is a lot!. One question, have you find some specific for HP scientific calculators like HP-25, 67 or 35s? There are so much that is hard to find without opening each of them.
Any book number in the list that calls your attention because a programming list? Thank´s for sharing. Pedro
06-28-2020, 04:07 PM
Thanks a lot, Max!
06-28-2020, 05:34 PM (This post was last modified: 06-28-2020 05:49 PM by rprosperi.)
Thanks for sharing this Max! Big Grin
It seems some/many of the books (6 out of 6 I tried) have free downloads only for the contents and a sample chapter, but there are > 180,000 books in the list so it will take a while to soft through it all to find some good ones.
Update: In the "Filters" section, select the "Only Open Access Books" and the list you create will include only titles which are fully available.
Too excited at the thought of so many free titles... Blush
06-28-2020, 08:29 PM
This was quite fascinating. As Bob said, you have to filter by "Only Open Access Books" to get the ones that can be freely downloaded. But even then, there are well over 1400 books to download.
If you try to download those, some need you to fill out a CAPTCHA to verify you are human. You can identify these in the spreadsheet by the penultimate column, "Open Access", where FALSE in that column means a CAPTCHA is required (yes, this is named confusingly with the "Open Access Books" above but it is independent).
That leaves 1051 of the books are then trivial to download by automated means, which I did. Although the remaining books needed a CAPTCHA, that was surprisingly easy to bypass, so I downloaded all those too.
Now I have 1433 books downloaded in PDF format (most in English, with 75 in German and 3 in both languages), adding up to 13.5 GB.
Thanks for sharing, and for the challenge!
06-29-2020, 05:19 AM
Thank You very much for the information on this Free Educational Textbook.
I have found this book very interesting about Statistic using Poket Calculator.
Name of the book "Statistical Analysis of Clinical Data on a Pocket Calculator"
I have a URL link but not sure if this site allow me to share this.
If interested people can look in it Exel file provided in that web site.
Gamo
06-29-2020, 12:16 PM (This post was last modified: 06-29-2020 12:42 PM by SlideRule.)
(06-29-2020 05:19 AM)Gamo Wrote:  I have found this book very interesting about Statistic using Poket Calculator.
BOOK Review
Statistical Analysis of Clinical Data on a Pocket Calculator: Statistics on a Pocket Calculator
Ton J. Cleophas, Aeilko H. Zwinderman
Springer, 2011, viii + 58 pages, £35.99/€39.95/$59.95, hardcover
ISBN: 978-94-007-1210-2
Table of Contents
1. Introduction                                12. Odds ratio
2. Standard deviations                      13. Log likelihood ratio tests
3. t-Tests                                      14. McNema’s tests
4. Non-parametric tests                    15. Bonferroni t-test
5. Confidence intervals                     16. Variability analysis
6. Equivalence tests                        17. Confounding
7. Power equations                          18. Interaction
8. Sample size                                19. Duplicate standard deviation for reliability
9. Non-inferiority testing                       assessment of continuous data
10. Z-test for cross-tabs                  20. Kappas for reliability assessment for binary data
11. Chi-squared tests for cross-tabs   21. Final remarks
Readership: Students, researchers, and teachers involved with Clinical data analysis.
The authors have used their experience as masters’ and doctorate class teachers of the European
College of Pharmaceutical Medicine (EC Socrates Project) in putting this text together. They
have found, from their experience, that performing statistical analysis on a calculator to be a
useful aid for the students learning and that statistical results can be obtained much quicker than
using a statistical software package.
  For a short book it has a considerable number of chapters, each one being very brief. This
is not a comprehensive statistical book and the reader needs to know when and why they use
the relevant statistical techniques. There are a very small number of exercises for the reader
to test their understanding and in some chapters there are no exercises at all. This book seems
to be aimed at a niche market and does not have a great deal of explanation on the statistical
techniques employed. If a student knows what they are doing, statistically speaking, then it is a
good quick guide.
As well as
Statistical Analysis of Clinical Data on a Pocket Calculator, Part 2:
Statistics on a Pocket Calculator, Part 2
© The Author(s) 2012
Springer ISBN 978-94-007-4703-6; ISBN 978-94-007-4704-3 (eBook)
The small book ‘‘Statistical Analysis of Clinical Data on a Pocket Calculator’’ edited in 2011 presented 20 chapters of cookbook-like step-by-step analyses of clinical data, and was written for clinical investigators and medical students as a basic approach to the understanding and carrying out of medical statistics …
  This book is a logical continuation and reviews additional pocket calculator methods that are important to data analysis …
Followed by
Clinical Data Analysis on a Pocket Calculator: Understanding the Scientific Methods of Statistical Reasoning and Hypothesis Testing
© SPRINGER 2016
ISBN 978 3 319 27103 3; ISBN 978 3 319 27104 0 (eBook)
  It is our experience that a pocket calculator is very helpful for the purpose of studying the basic principles. Also, a number of statistical methods can be performed more easily on a pocket calculator, than using a software program …
  Also, some analytical methods, for example, power calculations and required sample size calculations, are difficult on a statistical software program and easy on a pocket calculator. This book reviews the pocket calculator methods together with practical examples, both hypothesized and real patient data …
BEST!
SlideRule
06-29-2020, 01:01 PM
Great finding Gamo, for future comments I suggest to also include the number in which the book it´s on the list. TYVM. Pedro
06-30-2020, 12:39 AM (This post was last modified: 06-30-2020 12:44 AM by Nad.)
They did it because the books were already on Libgen Smile
Nad
Everything will be alright in the end. If it's not alright, then it's not the end.
06-30-2020, 05:01 AM
The book name: Statistical Analysis of Clinical Data on a Pocket Calculator
Print ISBN 978-94-007-1210-2
Another interesting Book is "The Python Workbook"
A Brife Introduction with Exercises and Solutions
Very nice example of programs that can be adapted to HP programmable calculator while
learning to code in Python language.
Print ISBN 978-3-319-14239-5
Gamo
07-12-2020, 12:52 PM
It looks like the link is now broken. I think I found it again by googling "springer open access books." Then go to the bottom of the page and click the "browse" button.
07-13-2020, 04:14 PM (This post was last modified: 07-13-2020 04:17 PM by Erwin.)
BOOK Review
Table of Contents
good quick guide.
As well as
Followed by
© SPRINGER 2016
BEST!
SlideRule
Thank you very much, but unfortunately the second book are not free. But the first one yes. There exists a second edition from the third one as pdf: https://link.springer.com/content/pdf/10...7104-0.pdf
Regards Erwin
