(15C) Backward-Forward Sweep Radial Loadflow
09-02-2020, 12:31 AM
(This post was last modified: 09-03-2020 01:42 AM by gerry_in_polo.)
I wrote this program way back in 2014 which computes the voltage profile of a radial electric distribution feeder using the Backward-Forward Sweep Loadflow Method modeling the feeder as a two segment/load node system with one normally closed and normally opened tying disconnect switch. It occupies a mere 123 steps or bytes of memory. The 48G/50g version can model an unlimited number of nodes plus plot the voltage profile.
Three Bus Backward-Forward Sweep Program (GVL) - HP 15C.pdf (Size: 23.22 KB / Downloads: 20) |
09-02-2020, 10:12 PM
RE: (15C) Backward-Forward Sweep Radial Loadflow
I found the 35s version but not the 50G. Do you plan to post it also?
Thibault - not collector but in love with the few HP models I own - Also musician : http://walruspark.co |
09-02-2020, 11:40 PM
RE: (15C) Backward-Forward Sweep Radial Loadflow | |||
