DM41X
02-20-2020, 08:11 PM
Post: #141
RE: DM41X
(02-20-2020 06:25 PM)Dave Britten Wrote:(02-20-2020 01:11 PM)Massimo Gnerucci Wrote: And exactly how could you get such an amount of info on the display, without reengineering the OS? Something SM said will not do. However this has little to do with stack display font, it rather pertains to SI section. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
02-20-2020, 08:14 PM
Post: #142
RE: DM41X
(02-20-2020 07:16 PM)hth Wrote:(02-20-2020 01:11 PM)Massimo Gnerucci Wrote: And exactly how could you get such an amount of info on the display, without reengineering the OS? Something SM said will not do. Ask them, I have no answer. But, rather than hide, I'd use do not disclose. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
02-20-2020, 09:11 PM
Post: #143
RE: DM41X
(02-20-2020 07:16 PM)hth Wrote:(02-20-2020 01:11 PM)Massimo Gnerucci Wrote: And exactly how could you get such an amount of info on the display, without reengineering the OS? Something SM said will not do. The source code of the 41 NUT OS is available and widely known; it has been released under NOMAS conditions since 1983. There are also some useful extensions included in the 41X ROMS compiled/written by Angel Martin - please contact him if you'd like to see those. The source code of the emulation layer is not available, so things that cross the NUT/Emulation boundary will not be feasible for 3rd parties. --Bob Prosperi |
03-13-2020, 02:21 PM
Post: #144
RE: DM41X | |||
03-13-2020, 04:10 PM
Post: #145
RE: DM41X
(03-13-2020 02:21 PM)Olivier de nantes Wrote:(01-29-2020 06:37 PM)charger73 Wrote: NQUEENS: XEQ alpha(blue) FAST alpha(blue) XEQ alpha(blue) SLOW alpha(blue) Better ask on SwissMicros' forum. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
03-13-2020, 04:14 PM
Post: #146
RE: DM41X
(03-13-2020 04:10 PM)Massimo Gnerucci Wrote:(03-13-2020 02:21 PM)Olivier de nantes Wrote: Hello Thank you very much. Since I wrote, I found the link to the DM41x User Manual, so. Have a good day Olivier |
08-25-2020, 02:14 PM
Post: #147
RE: DM41X
I’ve been told that the link to register an interest in buying a DM41X may be buried somewhere in this article - can someone point me to whereabouts please?
Dennis Denny Tuckerman |
08-25-2020, 02:26 PM
Post: #148
RE: DM41X
There are only 10 types of people in this world. Those who understand binary and those who don't. |
11-10-2020, 07:18 PM
Post: #149
RE: DM41X
Hi there
Just ordered a DM41X, currently own DM16, DM16L, I have some questions, perhaps answers in thread sorry if I missed. 1. Are the key markings on the device different than the Voyager clones? I found that the decals started coming off my 16L after a month or so. Disappointing as the devices build is excellent. 2. Any HP module supplied (in software I think I heard)? and is there a source for (.mod) modules that are also available free, I mean a web link repo. Not trying to break copyright here, only free stuff. Thanks and stay safe. Ed HP-28S (1988 US model), DM41X (2020) |
11-10-2020, 09:38 PM
Post: #150
RE: DM41X
Check the swiss micros forum for quick answers to these questions.
11-11-2020, 01:14 AM
Post: #151
RE: DM41X
(08-25-2020 02:26 PM)grsbanks Wrote: You can register your interest in new models here: No you can't! 404. Tom L Cui bono? |
11-11-2020, 08:53 AM
Post: #152
RE: DM41X
Site was redesigned. Try https://www.swissmicros.com/products
11-14-2020, 08:56 PM
Post: #153
RE: DM41X
I am now a proud owner of a new DM41X. First impressions- Amazing product! Working through the manual, I did have an issue though: How to activate the USB disk on a Mac? I plugged into into the USB port on my Mac then SETUP / FILE> / 5. Activate USB Disk. But I don't see it mounted in the Finder. Perhaps operator error? I'm running macOS Catalina (10.15.7). Thanks, Steve |
11-14-2020, 09:48 PM
Post: #154
RE: DM41X
(11-14-2020 08:56 PM)smartin Wrote: Hello, It could be your USB cable. The port is recessed kind of far into the case, and unless you're using a cable with an especially long connector, you might not be getting a good (or any) connection. If you have a cable with a soft rubber shield on the plug, you can use a small knife to trim it back and allow the plug to go all the way in without the shield hitting the calculator's case. |
11-14-2020, 10:09 PM
Post: #155
RE: DM41X
(11-14-2020 09:48 PM)Dave Britten Wrote:(11-14-2020 08:56 PM)smartin Wrote: Hello, Good call Dave, that was it. I tried another connector with a shorter jacket. Thanks much for the diagnosis! Steve |
11-19-2020, 05:26 PM
Post: #156
RE: DM41X
As I'm putting the DM41X through it's paces, where is the best place to post bugs/issues (so far I've noticed an issue with loading RAW files from the FAT disk)? Is there a support email address, or perhaps I should sign up on the swissmicros forum? I do see a 'Software Issues' forum but I wasn't sure if that was mainly for beta units? I don't want to weight down this forum if there are better reporting channels.
Thanks! Steve |
11-19-2020, 05:42 PM
Post: #157
RE: DM41X
(11-19-2020 05:26 PM)smartin Wrote: As I'm putting the DM41X through it's paces, where is the best place to post bugs/issues (so far I've noticed an issue with loading RAW files from the FAT disk)? Is there a support email address, or perhaps I should sign up on the swissmicros forum? I do see a 'Software Issues' forum but I wasn't sure if that was mainly for beta units? I don't want to weight down this forum if there are better reporting channels. It's best to post them on the SwissMicros Forum in the DM41X Software Issues subforum, here: https://forum.swissmicros.com/viewforum.php?f=26 That area was used for bug discussions during the Beta phase, but now is used for released f/w as well. Thanks --Bob Prosperi |
11-25-2020, 02:49 PM
Post: #158
RE: DM41X
(11-14-2020 09:48 PM)Dave Britten Wrote: It could be your USB cable. The port is recessed kind of far into the case, and unless you're using a cable with an especially long connector, you might not be getting a good (or any) connection. If you have a cable with a soft rubber shield on the plug, you can use a small knife to trim it back and allow the plug to go all the way in without the shield hitting the calculator's case. It would be much more reasonable if a suitable USB cable were included in the scope of delivery. Above all, that would help avoid a lot of frustration and anger on both sides. It is remarkable that the manufacturer has not responded to this problem to date. __________________________________ "Move forward and do what you think is best. If you make a mistake, you’ll learn something. But don’t make the same mistake twice." - Akio Morita |
11-25-2020, 03:39 PM
Post: #159
RE: DM41X
This seems to be a tolerance issue with the board/case assembly.
My DM42 requires a trimmed cable but my DM41X is happy with any cable that I throw at it. My Collection: 55, 67T, 25PLP, 34C, 15C, 16C, 41CV, 41CX, 41-CL, DM41X, DM42, 42S, 48G, 71B, 75C, 95LX, HP-150, Portable+, HP-86, Integral PC. |
11-25-2020, 04:00 PM
Post: #160
RE: DM41X
(11-25-2020 03:39 PM)twoweims Wrote: This seems to be a tolerance issue with the board/case assembly. My DM42 requires a trimmed cable but my DM41X is happy with any cable that I throw at it. Whether it's a tolerance problem or a misconstruction doesn't matter as a cause, the manufacturer has known this for a long time and still has no adequate solution to offer. Compared to the price of the device actually incomprehensible! __________________________________ "Move forward and do what you think is best. If you make a mistake, you’ll learn something. But don’t make the same mistake twice." - Akio Morita |
