The calculator I always wanted
03-14-2021, 11:16 PM
Post: #41
RE: The calculator I always wanted
Since the limitations are with Symja, I'll readjust my expectations.
I'll play with this some more and see if I can come up with better ideas on how to make it work. |
03-25-2021, 02:11 PM
(This post was last modified: 03-25-2021 02:12 PM by vanLudwig.)
Post: #42
I released a new beta today.
03-30-2021, 07:52 PM
Post: #43
There is still a problem with 1.3.0 that causes a lot of weird crashes. To the best of my knowledge, if you turn off Alternate Answers in 2nd -> MODE it will avoid the crash in all of these scenarios. I'll fix it before final release.
03-31-2021, 12:13 AM
Post: #44
(03-25-2021 02:11 PM)vanLudwig Wrote: I released a new beta today.I want to examine korean translation. How can I do that? S.Korean / HP-50G | fx-570EX | fx-570CW | HP-200LX |
03-31-2021, 12:24 AM
Post: #45
It uses the locale settings from Android. On my phone, that's Settings -> System -> Languages & input -> Language.
03-31-2021, 01:32 AM
Post: #46
I installed beta Acron Calculator, There is some typo I found on first screen.
30 일 무료 평가판 -> 30일 무료 평가판 구성 구독로 이동하여 -> 구성 구독으로 이동하여 ..I think I have to fix so many typos.. S.Korean / HP-50G | fx-570EX | fx-570CW | HP-200LX |
03-31-2021, 07:21 PM
Post: #47
If you're legitimately interested in doing the Korean translation, modifying the resx file is the best way to do it. It's just a simple xml file; you can edit it in any text editor.
I gave Demosthenes lifetime subscriptions for up to 5 people for doing the German translation. I would gladly do the same for you. |
03-31-2021, 11:51 PM
Post: #48
One question, where is ModePage_ComplexLabel? I got into 2nd - MODE and I can't find any complex mode.
There is also bug that crashes app, first set approx mode and press 2 + 3 2nd 9 ENTER. Click answer 2+i*3 DEG->DMS. It crashes. |
04-01-2021, 12:17 AM
Post: #49
I haven't gotten around to implementing polar complex numbers (I think there's also strings for polar vectors in ModePage). I suppressed them in the UI until I decide to implement the functionality.
I don't see a crash doing deg->dms in Approx. I'm assuming you have your device in Korean? Does that use a period or a comma as the decimal? |
04-01-2021, 12:31 AM
Post: #50
(04-01-2021 12:17 AM)vanLudwig Wrote: I haven't gotten around to implementing polar complex numbers (I think there's also strings for polar vectors in ModePage). I suppressed them in the UI until I decide to implement the functionality.Set Decimal Format digit beyond 15, (ex. 21 digits) and enter 2+3i deg->dms. It stopped. It doesn't crash when Decimal Format digit is below 15. S.Korean / HP-50G | fx-570EX | fx-570CW | HP-200LX |
04-01-2021, 02:36 PM
Post: #51
Yep, decimal precision > 15 digits is the key. I'll add it to my todo list.
04-07-2021, 06:10 PM
Post: #52
Version 1.3 was released to the general public yesterday.
04-12-2021, 07:02 AM
Post: #53
I forgot about translation long day before. I have to start again, so I upload current progress of korean translation. I think it is 40% done.
04-13-2021, 11:11 PM
Post: #54
Looks good so far. Here's some screenshots with your changes in place.
