Rubber for Voyager Feet
05-03-2021, 12:31 PM
I finally got around to replacing worn and missing feet for a few voyagers and I found some excellent material on the Bay.
5x7" sheet - 1/16" thick and cuts smooth. A little piece of double sided tape and done. I thought about a spray adhesive but will keep that in reserve if the tape fails. My wife certainly raised an eyebrow when a mailer from Ruby's Rubbers arrived. ![]() Link: https://www.ebay.com/itm/192212457857 -Bill |
05-03-2021, 12:46 PM
RE: Rubber for Voyager Feet
Did you notice this:
https://www.ebay.com/itm/303908180806?ha...46c256d346 A little more money, a lot less time and work. I've used them, and can happily recommend them. --Bob Prosperi |
05-03-2021, 01:06 PM
Hi Bob,
I did check those sweet feet out and TBH its not really that much work once you have cut one foot for a template. Its amazing the amount of feet that are worn and missing. I am doing about 4 calcs and $4 vs ~ $20 won in my "thrifty" perspective. Thanks and trust me if it was one set I would do the stick it and forget option. BTW I think the CalculatorStore is giving a free set of 41 feet with a 40+ Euro purchase right now. Take Care, Thrifty Bill |
05-03-2021, 01:18 PM
Thanks for the information.
I bought a set of rubber feet and it allowed me to fix 3 voyagers, it's really annoying to try to type things in on a hard desk with a wobble. Thanks again for sharing. |
05-03-2021, 03:12 PM
(05-03-2021 12:46 PM)rprosperi Wrote: https://www.ebay.com/itm/303908180806?ha...46c256d346 I, too, have purchased feet from this seller. As an alternate, Samson Cables also carries feet. http://www.samsoncables.com/catalog/prod...=HP12CPADS See the list of Calculator Parts and Services article under Important Threads for more calculator parts. https://www.hpmuseum.org/forum/forum-14.html |
05-04-2021, 03:54 AM
(This post was last modified: 05-04-2021 03:56 AM by jonese.)
I used the rubber self adhesive material from bicycle tire repair kit (discard the liquid glue tube), cut to size. I 3D printed out a template so that I can cut them reliably with a knife.
Shop around and you'll find the right size and thickness mimic to the original. |
05-06-2021, 04:29 AM
(This post was last modified: 05-17-2021 01:25 AM by derekamos.)
Hi everyone,
Here's my 2-cents, using an old bike tyre innertube, cut out the size to fit the recess, stick on some double sided tape & insert into the footing/slot. I have a card reader with a recessed foot slot, way over 10 years ago the rubber was lost. Since then the rubber innertube insert has worked faultlessly. ![]() DA. |
