Printing GROB's on the 82240B printer with HP-50g
05-26-2021, 09:55 PM (This post was last modified: 05-26-2021 09:56 PM by cahlucas.)
Unlike the HP48G/GX, the HP-50g does print GROBs very slowly on the infrared printer. I have compared the system RPL command "PrintGrob" on both machines, but apart from different addresses, they are exactly the same. That's why I made my own program to make the printing of GROBs a lot faster (see listing below). The GROB itself prints properly, but the problem with this program is that it produces noise a few pixels below the bottom of the printed GROB. By noise, I mean random pixels that are printed but do not occur in the GROB, and I cannot find the cause of this. Maybe someone can give me a good tip or hint to neutralize this effect. The program places the GROB to be printed in the graphics display, after which that display is scanned, and the data is stored in a string, which is then printed. If the GROB becomes too wide to print horizontally, the assembly programs tilt the GROB so that it is printed vertically. All in all, partly because of these assembly programs, it has become quite a listing. I hope someone can help me to fix this problem. Sincerely, Karel.
CK1
DUPTYPEGROB?                 // GROB on stack?
NcaseTYPEERR
BINT4
ClrSysFlag
DUPGROBDIM                   //Check GROB not too large
# A0
SWAP
# A0
ANDcase
::                                    // If so, generate a fault message
  DROP
  "Object too large for printing!"
  xMSGBOX
DUP
GROBDIMw                       // Check if GROB is too wide
# A0
IT                                    // IF so, tilt the GROB
  BINT4
  SetSysFlag                     //  Signal GROB is tilted
  FREEINTEMP?_
  ?SKIP
  TOTEMPOB
  CODE
               GOSBVL =SAVPTR
               GOSBVL =DisableIntr
               C=DAT1  A
               C=C+CON  A,5
               D0=C
               A=DAT0  A
               A=A+C  A
               C=C-CON  A,16
               GONC LD98B3
               GOTO  LD993B
  LD98B3  D0=D0+  5
               C=DAT0  A
               ?C=0  A
               GOYES  LD993B
               D=C  A
               D0=D0+  5
               C=DAT0  A
               GOYES  LD993B
               C=C+CON  A,7
               CSRB.F  A
               CSRB.F  A
               CBIT=0  0
               A=A-C  A
               D1=A
               D0=D0+  5
               A=C  A
               ASRB.F  A
               A=A-1  A
               R1=A.F  A
               C=C+C  A
               R0=C.F  A
               DSRB.F  A
               D=D-1  A
               GOC  LD993B
LD9909    C=R1.F  A
               B=C  A
LD9911    A=DAT0  B
               C=DAT1  B
               DAT0=C  B
               DAT1=A  B
               D1=D1+  2
               D0=D0+  2
               B=B-1  A
               GONC  LD9911
               A=R0.F  A
               CD1EX
               C=C-A  A
               D1=C
               D=D-1  A
               GONC  LD9909
LD9903B  GOSBVL  =AllowIntr
               GOVLNG  =GETPTRLOOP
  ENDCODE
  CODE
               GOSBVL  =SAVPTR
               GOSBVL  =DisableIntr
               C=DAT1  A
               D0=C
               D1=C
               D1=D1+  5
               C=DAT1  A
               B=C  A
               D0=D0+  10
               D1=D1+  10
               C=DAT0  A
               A=DAT1  A
               ?C=0  A
               GOYES  LD957B
               ?A=0  A
               GOYES  LD957B
               B=B-CON  A,16
               GONC  LD9585
LD957B    DAT0=A  A
               DAT1=C  A
               GOTO LD977E
LD9585   R0=C.F  A
              R1=A.F  A
              A=A+CON  A,7
              ASRB.F  A
              ASRB.F  A
              ABIT=0  0
              R4=A.F  A
              GOSUBVL  =makegrob
              CD0EX
              C=C-CON  A,16
              C=C-CON  A,4
              B=C  A
              GOSBVL  =D1=DSKTOP
              A=DAT1  A
              C=B  A
              DAT1=C  A
              A=A+CON  A,16
              A=A+CON  A,4
              R2=A.F  A
              D0=C
              D0=D0+  10
              A=DAT0  A
              C=R4.F  A
              B=C  A
              C=C+C  A
              C=C+C A
              C=C-A  A
              P=C  0
              C=P  15
              ST=0  0
              P=  15
              LA(1)  4
              ?C<A  S
              GOYES  LD961A
              C=C-A  S
              ST=1  0
LD961A   C=A-C  S
              C=C-1  S
              D0=D0+  5
              C=DAT0  A
              D0=D0+  5
              AD0EX
              AR3EX.F  A
              C=C+CON  A.7
              CSRB.F  A
              CSRB.F  A
              A=C  A
              CBIT=0  0
              D=C  A
              ?ABIT=1  0
              GOYES  LD9654
              C=C-1  A
LD9654   C=C-1  A
              A=0  A
LD9658   RSTK=C
              C=R2.F  A
              R0=C.F  A
              C=R3.F  A
              R1=C.F  A
              C=B  A
              ?ST=0  0
              GOYES  LD967B
              C=C-1  A
LD967B   C=C-CON  A,2
              GOC  LD96F9
LD9684   RSTK=C
              C=R0.F  A
              D0=C
              C=R1.F  A
              D1=C
              P=  3
              A=DAT0  P
              P=  2
LD96A0   AD0EX
              A=A+B  A
              AD0EX
              A=DAT0  P
              P=P-1
              GONC  LD96A0
              P=  0
              GOSUB  LD978C
              P=  3
              DAT1=C  P
              P=  2
LD96BF   CD1EX
              C=C+D  A
              CD1EX
              DAT1=C  P
              P=P-1
              GONC  LD96BF
              CR0EX.F  A
              C=C+1  A
              CR0EX.F  A
              AR1EX.F  A
              C=D  A
              C=C+C  A
              C=C+C  A
              A=A+C  A
              AR1EX.F  A
              C=RSTK
              C=C-1  A
              GONC  LD9684
LD96F9   C=R0.F  A
              D0=C
              C=R1.F  A
              D1=C
              P=  3
              A=DAT0  P
              P=  2
LD9713   AD0EX
              A=A+B  A
              AD0EX
              A=DAT0  P
              P=P-1
              GONC  LD9713
              P=  0
              GOSUB  LD978C
              A=C  S
              P=  3
              DAT1=C  P
              A=A-1  S
              GOC  LD974F
              P=  2
LD973B   CD1EX
              C=C+D  A
              CD1EX
              DAT1=C  P
              P=P-1
              A=A-1  S
              GONC   LD973B
LD974F   CR3EX.F  A
              C=C+1  A
              CR3EX.F  A
              AR2EX.F  A
              C=B  A
              C=C+C  A
              C=C+C  A
              A=A+C  A
              AR2EX.F  A
              C=RSTK
              C=C-1  A
              GOC  LD9658
LD977C   P=  0
LD977E   GOSBVL  =AllowIntr
              GOVLNG  =GETPTRLOOP
LD978C   C=0  A
              ?A=0  A
              RTNYES
              LC(4)  #1248
              C=C&A  A
              ABIT=0  0
              GOYES  LD7A9
              CBIT=1  15
LD97A9   ?ABIT=0  1
              GOYES  LD97B5
              CBIT=1  11
LD97B5   ?ABIT=0  2
              GOYES  LD97C1
              CBIT=1  7
LD97C1   ?ABIT=0  4
              GOYES  LD97CD
              CBIT=1  14
LD97CD   ?ABIT=0  5
               GOYES  LD97D9
               CBIT=1  10
LD97D9   ?ABIT=0  7
               GOYES  LD97E5
               CBIT=1  2
LD97E5    ?ABIT=0  8
               GOYES  LD97F1
               CBIT=1  13
LD97F1   ?ABIT=0  10
              GOYES  LD97FD
              CBIT=1  5
LD97FD   ?ABIT=0  11
              GOYES  LD9809
              CBIT=1  1
LD9809   ?ABIT=0  13
              GOYES  LD9815
              CBIT=1  8
LD9815   ?ABIT=0  14
              GOYES  LD9821
              CBIT=1  4
LD9821   ?ABIT=0  15
              RTNYES
              CBIT=1  0
              RTNSC
ENDCODE                       //  End of tilting
BINT0
ZEROZERO
GBUFF                           // Safe old graphic picture
TOTEMPOB
  NULLLAM
  NULLLAM
  NULLLAM
  NULLLAM
BIND                            // Create local variables
DOERASE
DUPGROBDIM
3PUTLAM
2PUTLAM
GROB>GDISP              // Put the GROB to print in the graphics screen
2GETLAM
ZERO_DO
INDEX@
4PUTLAM
"*"                              // Pay attention!!!  Character is 27 CHR!!!
BINT4
TestSysFlag
ITE                              //  Test if GROB has tilt
  # A0                         //  Put the GROB in the middle of the paper
  3GETLAM
  #-#2/
  "\00\00\00\00..."       //80 x 0 CHR!!!
  BINT1
  ROT
  SUB$
  DUPLEN$
  3GETLAM
  #>CHR
::                                // If no tilt, add GROB width to string
  3GETLAM
  #>CHR
  >T$
3GETLAM                     // Begin to scan the graphic picture
ZERO_DO
BINT0
BINT8
ZERO_DO
  JINDEX@
  4GETLAM
  INDEX@
  #+DUP
  2GETLAM
  case2DROP
  PIXON3?
  NOT?SEMI
  {                                 // Calculate character ASCII code
    BINT1
    BINT2
    BINT4
    BINT8
    BINT16
    BINT32
    SIXTYFOUR
    BINT128
  INDEX@
  #1+
  NTHCOMPDROP
LOOP
#>CHR
>T$                               // Add character to string
LOOP
PTR 2F127                     // Print string to IR printer
DROP
BINT8
+LOOP
DOCR
DOCR
1GETABND                     // Get saved graphic picture
BINT4
ClrSysFlag
DUPGROBDIM
ZEROSWAP
BINT0
XYZ>ZXY
OR                                // Test saved picture is not empty
ITE
  DROP
  DOERASE
GROB>GDISP                // If not empty, store picture in graphic screen
GARBAGE                      //  Clean up the mess
I use HP-16C, WP-34S emulator, HP-35s, HP-48GX, HP-50g, and HP Prime G2.
