HP Prime Integral Simplification
05-31-2021, 03:27 PM
I'm a new user of the HP Prime, coming from an Nspire user. Is there a way to yield an answer on the Prime similar of that of the Nspire in the pictures? It would be nice to see the simplest result. Thanks!
05-31-2021, 03:30 PM
RE: HP Prime Integral Simplification
(05-31-2021 03:27 PM)123jkl123jkl Wrote: I'm a new user of the HP Prime, coming from an Nspire user. Is there a way to yield an answer on the Prime similar of that of the Nspire in the pictures? It would be nice to see the simplest result. Thanks! You could try putting the entire expression in simplify(expression) Tom L Cui bono? |
05-31-2021, 03:35 PM
It yields a more complicated answer. I don't think that works.
05-31-2021, 04:22 PM
You might have Simplify set to Maximum in the CAS settings.
I have it set to Minimum and it gives an answer very similar to the Nspire. |
05-31-2021, 08:38 PM
Alexmaster350 is right, setting Simplification to none in Shift-CAS settings page, give a much more usefull answer :
[attachment=9517] |
05-31-2021, 10:03 PM
Great, that solved it. Thanks for the info guys!
