HP 48GII USB / Serial Pinout
01-22-2022, 11:30 PM
The 48GII is unique in that is has a MiniUSB Port that exposes the serial UART connections (as opposed to being like a normal USB connection like the 49G+ and 50G).
To connect a 48GII to a computer, you'll need a USB to UART adapter with 3.3V outputs (the Samsung CPU uses 3.3V I/O) and a MiniUSB cable cut open. Connections: MiniUSB Cable | UART Ground (Black) | Ground D+ (White) | RX D- (Green) | TX You'll need to select the correct COM Port from the Connectivity Kit and choose 115200 Baud |
