WP 34S on DM 42 integral fail
04-12-2022, 07:06 PM
When integrating from -2 to 3 the function 1/3Root(x), my WP 34S comes up with 0. The answer should be ~.739. I use an 8 size stack and full precision. My code is LBL ‘F0’, FILL, 3Root(x), (1/x), RTN
04-12-2022, 07:20 PM
RE: WP 34S on DM 42 integral fail
Of course, if I break it into 2 integrals, from (-2 to 0) + from (0 to 3), I come up with the correct result quickly. I am curious as to why the WP 34S could not deal with using the -2 to 3 domain, and if this is unexpected.
04-12-2022, 09:57 PM
I guess it has something to do with the discontinuity between the bounds.
— Ian Abbott |
04-12-2022, 11:35 PM
My TI-30X Pro had no problem with the integration, did not require breaking the integral into two…
04-13-2022, 12:38 AM
My TI-89 and HP Prime (IOS App) provided the correct answer just fine. My Casio fx-991EX and fx-CG50 both gave a Math Error.
04-13-2022, 12:52 AM
From xrom/integrate.wp34s:
Quote:// - the double exponential method relies on the function to be In this specific case you can just integrate from 2 to 3. Also you can skip the FILL command in your program. |
04-13-2022, 03:51 AM
Re Steve…I have been surprised that the CASIO fx-CG50 cannot handle discontinuities where an integration would be a finite result. If the discontinuity is at 0 for example, one is forced to use 1*10^-12 for a starting point. Also surprised that it cannot handle trig or exponential commands with complex numbers, does not calculate prime factors, does not have a product command to complement the summation capability. Still, and excellent calculator. Really shines with graphing, graphing analysis, fantastic labeling of the x and y axis, Great with regressions and distributions! Fast as well.
04-13-2022, 08:55 AM
RE: WP 34S on DM 42 integral fail | |||
04-13-2022, 02:28 PM
Wow! I forgot about this…other nice examples, remedies given as well!
04-13-2022, 04:00 PM
(04-12-2022 11:35 PM)lrdheat Wrote: My TI-30X Pro had no problem with the integration, did not require breaking the integral into two… Maybe it did "break" integral into two (or more pieces), see Adaptive quadrature Example, gaussquad() use adaptive Gaussian quadratures with 15 points. XCas> gaussquad(surd(x,3), x=-2..3.) 1.35517995835 |
04-13-2022, 05:42 PM
I’m integrating the reciprocal of your function…this results in an undefined point at x=0.
This produces, if correct, ~.7379 |
04-13-2022, 07:38 PM
(This post was last modified: 04-17-2022 11:22 AM by Albert Chan.)
XCas> gaussquad(surd(x,-3), x,-2.,3.)
0.739024156625 This work ! But, I would advice split the integral yourself, to be safe. Adaptive scheme may be fooled. (no matter how good it is, it only see sample points) Below is adaptive simpson's scheme to do above integral. Note line 150. It never touched undefined point at x=0 (But, if integral limits changed, say, -2 .. 6, it will hit x=0 dead on) 10 X1=-2 @ X3=3 @ E=.0001 20 T=TIME @ X2=(X3+X1)/2 @ CALL F(X1,F1) @ CALL F(X2,F2) @ CALL F(X3,F3) 30 S=(F1+4*F2+F3)*(X3-X1)/6 40 CALL SIMPSON(X1,X2,X3,F1,F2,F3,32*E,S) @ DISP S,TIME-T @ END 50 SUB F(X,Y) @ Y=SGN(X)*ABS(X)^(-1/3) @ STOP 100 SUB SIMPSON(X1,X3,X5,F1,F3,F5,E,S) 110 H=(X5-X1)/4 @ X2=X1+H @ X4=X5-H 120 CALL F(X2,F2) @ CALL F(X4,F4) 130 H=H/3 @ S1=(F1+4*F2+F3)*H @ S2=(F3+4*F4+F5)*H 140 S3=S1+S2 @ D=S3-S @ H=E/2 150 IF H<1.E-15 OR ABS(D)<H THEN S=S3+D/15 @ STOP 160 CALL SIMPSON(X1,X2,X3,F1,F2,F3,H,S1) 170 CALL SIMPSON(X3,X4,X5,F3,F4,F5,H,S2) 180 S=S1+S2 >RUN .73902427614 18.76 Update: slightly modified SIMPSON() recurse condition, with following: 40 CALL SIMPSON(X1,X2,X3,F1,F2,F3,30*E,S) @ DISP S,TIME-T @ END 150 IF H<15E-15 OR ABS(D)<H THEN S=S3+D/15 @ STOP > RUN .73902420507 15.44 The changes is to compare Sharp BASIC translated HP71B code speed. |
