Prime Virtual Calculator Crashing
05-16-2022, 09:48 PM
I have always had problems with the latest Virtual calculator, everytime I let it update, to the 2021 version, it crashes upon startup (Windows 8.1 machine)
Problem signature:
Problem Event Name: BEX
Application Name: HPPrime.exe
Application Version: 0.0.0.0
Application Timestamp: 60c0c888
Fault Module Name: ucrtbase.DLL
Fault Module Version: 10.0.14393.2990
Fault Module Timestamp: 5caeb859
Exception Offset: 000884cb
Exception Code: c0000409
Exception Data: 00000007
OS Version: 6.3.9600.2.0.0.256.48
Locale ID: 2057
Additional Information 1: a8b8
Additional Information 2: a8b88091a275c30c0f71efb244755d6c
Additional Information 3: 6eaf
Additional Information 4: 6eaf114526137d6bfce2ae01ff8ecb05
I know that the virtual calculator worked running the 2018 version, but It didn't have Python, so I decided to give the newer version another try.
I have tried this this evening with the 64 and 32 bit of the Conn Kit, and Virtual Calc, all the latest versions and it always crashes.
Any ideas on how to get it to work? Failing that, is there somewhere that hosts the older version of the virtual Calc?
05-17-2022, 07:20 AM (This post was last modified: 05-17-2022 07:21 AM by StephenG1CMZ.)
RE: Prime Virtual Calculator Crashing
Some users find that the Android app crashes when offline.
Just a thought: Might some of these Windows crashes be because the Internet is off/unreliable?
Stephen Lewkowicz (G1CMZ)
05-17-2022, 10:08 AM
My internet was working fine at the time, this has been the same since I first tried to update the Virtual prime, every time I have tried, since 2021, and I gave up on the new version, using the older version and only now did I want python on the virtual calc, I decided to try to get the new version to work.
