(49g 50g) Number of Trailing Zeros in N!
06-02-2022, 08:51 PM
(This post was last modified: 07-23-2022 07:32 PM by John Keith.)
Inspired by this program and others by member GeraldH, this program will return A027868(n), the number of trailing zeros in n!.
Using ListExt 1.3, it is reasonably small and very fast, even for numbers with over 100 digits. The program is based on the third comment in the OEIS link above. Code:
06-03-2022, 02:03 AM
RE: (49g 50g) Number of Trailing Zeros in N!
We can also use the recurrence:
a(n) = floor(n/5) + a(floor(n/5)); This program is for the HP-42S but should work with most other models as well: Code: 00 { 14-Byte Prgm } This program is for the HP-48: Code: \<< 0 Example \( \begin{align} n &= 7392 \\ \\ a(n) &= 1478 + 295 + 59 + 11 + 2 \\ &= 1845 \\ \end{align} \) References Quote:Gardner, M. "Factorial Oddities." Ch. 4 in Mathematical Magic Show: More Puzzles, Games, Diversions, Illusions and Other Mathematical Sleight-of-Mind from Scientific American. New York: Vintage, pp. 50-65, 1978 Thank you for reminding me of this book. I got the German translation "Mathematische Hexereien" as a teenager. |
06-03-2022, 02:05 PM
Thanks for posting this, Thomas. Your program is certainly simpler, although it is limited to numbers < 10^12.
The reason for my rather brute-force approach is to allow number sizes limited only by the calculator's memory while avoiding the slowness of the HP50 IQUOT function. I am working on a revised version that should allow numbers with several thousand digits (that is the number n itself, not n!). As shown in this paper from the OEIS link above, this method can be extended to numbers with arbitrary base. Doing so is not entirely straightforward because the details seem to depend on whether the base b is a prime, semiprime, prime power, etc. As they say, further research is needed. ![]() |
06-03-2022, 03:19 PM
In the same chapter Martin Gardner talks about printing a factorial as a tree.
This Python program produces one of the examples: Code: from math import factorial 5 119 90692 7755879 266003615 25819185379 7984360677298 470133958906714 46011174633964398 5839112233165772956 548496166254935516795 14565079522588677608012 6423489045662147453126349 825790036437158643266482002 88113505694916924243929121639 7995123320680205388149829536720 697546589338105120020005674705145 28641409978978956631664608452253922 2182139322091260889711710217500934598 659546487929459214735007200769105667735 54074289548655659977226200540160335058131 8365384235510714071491098835812736588922795 511456461421254773804907853073384484888784090 75030962875912509521999525292598359880846423952 3931204111818280979213544777644751538435208774603 088477116032223651164439419220002073567325180151958 35354728897604905269289015307797618984464654042934912 7882733479825616955531216107050271401259459875249508169 440013327395316887000833911764483284987619075088343797786 47371945157918046252226969546616811434035461815792968273198 2545625613705049834238544557702694536385292145346080336071424 289160111720849018903249047529128422886467764267877861568498090 42964480000000000000000000000000000000000000000000000000000000000 0000000000000000000000000000000000000000000000000000000000000000000 Also he mentions: Quote:If someone had predicted fifty years ago that before the century And now, another 50 years later, we can do this with our smartphones. Mathematical Magic Show |
06-03-2022, 08:52 PM
That's pretty neat, especially considering the year that book was published. Very few people at that time had access to computers that could calculate and print such a large number.
Here is an experimental program that hits both points in my previous post. It works with very large numbers, and calculates the number of zeros in almost any base. The "almost" is the issue here- in particular, the base cannot be a prime power or a composite number whose largest prime factor occurs more than once. For example, bases 4, 8, 9, 16, 18 etc. will not return correct answers. To use the program, first enter the number n. Note: n must be greater than the square of the base or the program will quit with an error. Then for the base, enter the largest prime factor for q. For example, q = 5 will return the correct answer for base 5, 10, 15 and 20 but not 25. Code:
Some notes about the program: The ListExt command SLST-> is a modified version of OBJ-> for lists which effectively applies NEWOB to every element of the list. The heart of the program is the phrase q * 1 + which generates successive q-integers (partial sums of the powers of q). This obviates the need to maintain a large list of large integers on the stack. This program is just as fast as the previous one but still takes over a minute on the physical calculator for 10^1000. EMU48 is your friend here- about 1.5 seconds on my phone. |
06-04-2022, 06:53 PM
(This post was last modified: 06-04-2022 06:54 PM by John Keith.)
Just for laughs, a couple of programs to print large integers as triangles. They are most useful on a PC-based emulator where the resulting string can be pasted into a text file and printed.
The first program makes a triangle where row n has 2n-1 digits, similar to Thomas' Python program if not as elegant. Input is an integer, output is a string centered at the 40th column. Maximum integer size is 1521 digits (39 rows). If the number of digits is not a square, the last row will be incomplete. Code:
The next version makes a triangle where row n has n digits (like Pascal's triangle). The string is left justified. There is no maximum size but very large integers will make rows longer than 80 characters. If the number of digits is not a triangular number, the last row will be incomplete. Code:
As an example, this is 570!: 1 19 647 5758 26679 992521 3150971 60611198 503056621 9007683399 48400991237 661587270341 8103894782133 53453090699254 154454320719614 5487509118626349 08696686820305004 379306247797103488 6790434213832213245 94841498332690282044 085187027223617659230 9518428094945979214940 56709685270263887874435 753547709167084262926620 3332741387705148411462271 23095175757304448772093194 373279490301207089965787664 8575127566724513575715482702 70788565544870146828024429021 833502813292623326287501458026 9161119577367392188068125282549 20234801893594111768456673065490 279986528074506746792875128696146 7862034450599336508683729157632623 68712749711136718818742496831196746 909912133660990822097617434066349471 5222497263330885513955829086147220454 59821787316263806805289352977171927611 915931808505004008935038815697112288240 3089565859840019822465218311419147832147 74003130942944407137531510505316475042841 159819848160593032726584717409062104550132 5700007860560251989608104718347968735642475 43983373049782988651222694742053310200491418 863588405480343023964791498461218898945580264 8406113303807150001581953263761718561315680021 38450168036268440168979166079893774258519311891 845963565722703706788257300598498708086057505863 1759757312000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000 |
