TVM solve for interest rate, revisited
06-23-2022, 04:36 PM
RE: TVM solve for interest rate, revisited
(06-11-2022 05:34 PM)Albert Chan Wrote: Rational Halley's modified slope = f' * (1 - (f*f'')/(f')^2/2) = f' - (f''/2)*(f/f') With slope adjustment, (f''/2)*(f/f'), getting bigger in size relative to f', it may turn slope to the wrong direction! Or, worse ... slope of 0! Below example, with i0 = pmt/fv = 1e-9, 1st iteration get worse (turned negative!) True rate = 5.32155425915678; Rate iteration should not go backward. lua> n,pv,pmt,fv = 10, -100, 10, 1e10 lua> loan_rate2(n,pv,pmt,fv)() + 0 -0.08736585216654838 Checking f and its derivative at i=i0, Halley's slope had wrong sign. lua> f0, f1, f2 = 999999995.5, -4500000102.007542, 143515080310.56577 lua> f1 - (f2/2)*(f0/f1) -- bad slope 11446119499.270123 Technically, with guess rate from the edge, this should not happen. The reason is a badly estimated f'', over-estimated almost 9 times! With more precision, this is true f0, f1, f2, at i=i0 lua> f0, f1, f2 = 999999995.5, -4500000038.5, 16499999810.25 lua> f1 - (f2/2)*(f0/f1) -- true halley's slope -2666666750.1851845 lua> 1e-9 - f0/_ -- this should be i1 0.37499998756770886 Instead of special cased at *exactly* i=0, we should widen it. Below code treat eps=i*i, such that 1+eps==1, as special. From above examples, slope is less affected by catastrophic cancellations. But, I fix it anyway for Newton's method too (= Halley's method code, with f''=0) For naming consistency, Newton's = iter_i(), Halley's = iter_i2() Code: function iter_i2(n, pv, pmt, fv, i) lua> n,pv,pmt,fv = 10, -100, 10, 1e10 lua> iter_i(n,pv,pmt,fv)() + 0 -- Newton's method 0.22222222032098768 lua> iter_i2(n,pv,pmt,fv)() + 0 -- Halley's method converge faster 0.3749999875677088 |
06-23-2022, 07:04 PM
(This post was last modified: 07-18-2022 02:20 PM by Albert Chan.)
f = ((pv+fv)/(K-1) + pv)*x + pmt , where K = (1+x)^n
To improve accuracy, we noticed ULP(f) ≥ ULP(pmt) If pv=0, we have ULP(f) = ULP(pmt) We like to make |pv| smaller, if possible, to increase f precision. We can do this with time-symmetry (formula does not care time direction): NPV = NFV / K = NPMT / C K = (1+x)^n C = (x*n)/(1-1/K) = (x*n)/(K-1) * K = (x*n)/(K-1) + n*x NPV(n,i,pv,pmt,fv) = NFV(-n,i,fv,-pmt,pv) NFV(n,i,pv,pmt,fv) = NPV(-n,i,fv,-pmt,pv) NPMT(n,i,pv,pmt,fv) = NPMT(-n,i,fv,-pmt,pv) f = NPMT/n → f(n,i,pv,pmt,fv) = -f(-n,i,fv,-pmt,pv) = f(-n,i,-fv,pmt,-pv) Code: function _find_rate(iter_i, found, n,pv,pmt,fv,i0, verbose) For convenience, I made function fn, that act like Python's lambda. Note: Halley's method for f=0, convergence may not be 1-sided. Code: function find_rate(...) return _find_rate(iter_i, fn'a,b: a*b<=0', ...) end Update, Jul 11,2022: Rate iterators actually returned (i+eps), eps, f In other words, (i,f) is the point, (i+eps) extrapolated value. Final f of only a few ULP's, (i+eps) may not be that good. A reasonable guess is true rate between i and (i+eps). Patched code returned (i+eps/2) = (i+eps) - eps/2 This is patched result: lua> n,pv,pmt,fv = 10, -100, 10, 1e10 lua> find_rate2(n,pv,pmt,fv,nil,true) 0.3749999875677088 999999995.5 0.7951945637769868 161944286.30682382 1.3009220024991999 22940767.56093494 1.9230635724160559 3128383.8915700433 2.694052015186147 422117.19292708224 3.6428250853054216 56675.26724831162 4.70010922758184 7473.075259553417 5.291135425226106 837.9935225675524 5.32155201095865 25.713350899574266 5.321554259156788 0.0018612216055089448 5.321554259156787 -1.2505552149377763e-012 5.321554259156789 2.3874235921539366e-012 5.3215542591567875 true Above verbose output, f value should read as if whole column get shifted up. (i1, f1) = (0.375, 162.e6) (i2, f2) = (0.795, 22.9e6) ... It showed a sign flip when i ends in 788, flipped again when i ends in 787 With f down to few ULP's, correction is worse, with final i ends in 789, outside bracketed rate. Patched code assumed true i ends in middle of (787, 789) Update, Jul 18,2022: fuzz factor for rate found widened, with less false negatives. < return i-eps/2, (i == i-eps*0.01) > return i-eps/2, (i == i-eps*0.001) |
06-23-2022, 10:21 PM
(This post was last modified: 06-27-2024 12:04 PM by Albert Chan.)
(06-23-2022 07:04 PM)Albert Chan Wrote: if abs(pv) > abs(fv) then n,pv,fv = -n,-fv,-pv end An example to show improvement by keeping |pv| small. f = 0 ⇒ -pmt/x = (pv+fv)/expm1(log1p(x)*n) + pv Plus42 TVM, P/YR=1, END mode. Solve for I, then use it to solve back PMT N, PV, PMT, FV = 10, 1E10, 10, -100 I%/YR --> -84.34981140003005709231099197156087 PMT -----> 9.999999999999999999999999899268213 N, PV, PMT, FV = -10, 100, 10, -1E10 I%/YR --> -84.34981140003005709231099197367593 PMT -----> 9.999999999999999999999999999999781 Update 6/27/24 Plus42 PMT changed. Solve for PMT or I%YR prefer small sized PV. Solve for PV or FV prefer negative n. Solve for N prefer small sized FV. I wish Plus42 result does not get affected by time-symmetry. N, PV, PMT, FV = -10, 100, 10, -1E10 I%YR = -84.34981140003005709231099197156087 PMT --> 9.999999999999999999999999899268215 I%YR = -84.34981140003005709231099197367593 PMT --> 9.999999999999999999999999999999791 |
06-25-2022, 01:39 AM
(This post was last modified: 06-28-2022 01:18 PM by Albert Chan.)
(06-10-2022 08:25 PM)Albert Chan Wrote: Proof: f is either concave-up, or concave-down (f'' have same sign) Previous proof showed g'' > 0 In order to do that, it also have to show g above x=0 tangent line. I had wrongly assumed second part true, for my first proof attempt. This proof is more direct, by showing g'' has no roots. As long as g'' has the same sign, f'' also have same sign throughout. f = (pv+fv)/n*g + pv*x + pmt f' = (pv+fv)/n*g' + pv f'' = (pv+fv)/n*g'' XCAS> g := x*n/((1+x)^n-1) XCAS> g := g(x=x-1); // shifted. Now, domain is x > 0 XCAS> h := normal(n/g) (x^n-1) / (x-1) // = x^(n-1) + x^(n-2) + ... + x + 1 > 1, if n>1 h is a polynomial, so does all its derivatives. g'' = n*(h^-1)'' (h^-1)'' = (-h^-2 * h')' = (-h^-2 * h'' + 2*h^-3 * h'^2) (h^-1)'' * h^3 = 2*h'^2 - h*h'' RHS looks promising to be positive; it is Halley's correction denominator. But, all we needed is to show RHS never touch 0. XCAS> m := factor(simplify(2*h'^2 - h*h'')) \(\displaystyle \frac {n\;x^{n-2} \cdot \left[ (n\!-\!1)\; x^{n+1} \;-\; (n\!+\!1)\; x^{n} \;+\; (n\!+\!1)\; x \;-\; (n\!-\!1) \right]}{\left(x-1\right)^{3}}\) Above expression touched up a bit, to show polynomial sign changes. For n>1, numerator has 3 sign changes, thus 1 or 3 positive roots. Denominator had factor (x-1)^3, cancelled all numerator roots. For n>1, m has no roots ⇒ g'' has no roots ⇒ f'' has no roots. QED --- Not needed for the proof, but we might as well get sign(g'') XCAS> factor(limit(m, x=1)) // (n>1) ⇒ (m>0) ⇒ (g''>0) n^2*(n+1)*(n-1)/6 Or, we just imagine x ≫ n > 1, sign(m) = + / + = + |
06-28-2022, 12:55 PM
(06-25-2022 01:39 AM)Albert Chan Wrote: h is a polynomial, so does all its derivatives. Direct way is to expand RHS polynomial, and make sure no negative coefficients. Example, say n=5 h = 1 + x + x^2 + x^3 + x^4 h' = 1 + 2 x + 3 x^2 + 4 x^3 h'' = 2 + 6 x + 12 x^2 kth column = kth term coefs. (polynomial with increasing power). Code: 1 2 3 4 = h' h' has (n-1) terms ⇒ (2*h'^2) has 2*(n-1)-1 = (2n-3) terms. For k ≤ (n-1), (2*h'^2) k-th coeff = 2*sum(j*(k+1-j), j=1..k) = 2*comb(k+2,3) Code: 1*2 2*3 3*4 = h'' For k ≤ (n-2), (h*h'') k-th coeff = sum(j*(j+1), j=1..k) = 2*comb(k+2,3) 2 sides coefs matched, (n-2) terms, from the front. Lets flip the order, and check differences from the back, (2n-3) - (n-2) = (n-1) terms. (2*h'^2 - h*h''), k-th coeff, from the back = sum(2*(n-j)*(n-(k+1-j)) - (n-j)*(n-(j+1)), j=1..k) = sum(n^2 - n*(1+2*(k-j)) + (2*j*(k+1-j) - j*(j+1)), j=1..k) = n^2*k - n*(k^2) + 0 = n*k*(n-k) With k = 1 .. n-1, RHS coeffs all positive; other coeffs all zero. With no sign changes, RHS have no positive roots. QED Just to confirm, with bigger n XCAS> h := (x^n - 1)/(x - 1) XCAS> n := 10 XCAS> e2r(2*h'^2 - h*h'') [90, 160, 210, 240, 250, 240, 210, 160, 90, 0, 0, 0, 0, 0, 0, 0, 0] XCAS> makelist(k -> n*k*(n-k), 1, n-1) [90, 160, 210, 240, 250, 240, 210, 160, 90] |
06-29-2022, 07:26 PM
(This post was last modified: 06-30-2022 12:16 PM by Albert Chan.)
This solved TVM calculations, 5 variables, 1 unknown
Code: function tvm(n,i,pv,pmt,fv) lua> n,pv,pmt,fv = 36, 30000, -550, -15000 lua> tvm(n,nil,pv,pmt,fv) -- i 0.005805072819420131 lua> i = _ lua> tvm(nil,i,pv,pmt,fv) -- n 36 lua> tvm(n,i,nil,pmt,fv) -- pv 30000 lua> tvm(n,i,pv,nil,fv) -- pmt -550 lua> tvm(n,i,pv,pmt,nil) -- fv -15000.000000000002 |
07-11-2022, 09:08 PM
(06-23-2022 07:04 PM)Albert Chan Wrote: NPV = NFV / K = NPMT / C I just realized there is no financial function called NPMT (we do have NPV, NFV) We can define NPMT as a TVM function that work the same way, if time direction reversed. NPMT = C*pv + C(n=-n)*fv + n*pmt NPMT tends to be more "straight" than (NPV, NFV), with values inside (NPV, NFV) Thus, f = NPMT/n = 0 is great for solving rate x, using Newton's method. But, with extreme compounding effect, f might still be too curvy. Below is using Halley's method. Newton's method will be twice as long! (06-23-2022 07:04 PM)Albert Chan Wrote: lua> n,pv,pmt,fv = 10, -100, 10, 1e10 In this situation, we can use log version, from TVM formula to solve for n (*) (06-29-2022 07:26 PM)Albert Chan Wrote: If n ≠ -(pv+fv)/pmt, n has the form logab → n*ln(a) - ln(b) = 0 We have to use a guess better than edge rate, otherwise ln(b) → NaN Let's use first iteration of Halley's method (from small edge) as rate guess lua> D = require'dual'.D lua> function L(x) return n*D.log1p(x) - D.log1p(-(pv+fv)/(pmt/x+pv)) end lua> n,pv,pmt,fv = D.new(10), D.new(-100), D.new(10), D.new(1e10) lua> x = D.new(0.375,1) lua> for i=1,7 do print(D.newton(x,L(x))) end 2.2611317877571713 -15.546298358404194 4.413843278673193 -6.645171069338584 5.25277183822195 -1.5540048931122605 5.321177493828256 -0.10965326382959262 5.321554247893293 -0.0005973748729495298 5.3215542591567875 -1.7858138079418495e-008 5.3215542591567875 0 Note: outputs are (extrapolated x, L(x)); Shift up 2nd column to get points (x, L(x)) (*) Another way is simply get a better guess. For above example, we may ignore pmt, and directly solve for rate. pv*(1+x)^n + fv = 0 → x = expm1(log(-fv/pv)/n) We have x = 5.310, which is a great starting guess. |
07-13-2022, 03:34 PM
Code: D.__index = D I updated above code to dual number, for object oriented, functional style. Newton's method returned extrapolated x, without updated it back to x. "D.__index = D" allowed we write D.log1p(x) as x:log1p() With formula not tied to D, it can be used for other types. add/sub/mul/div/rcp code are to allow constants also not tied to type. --- (07-11-2022 09:08 PM)Albert Chan Wrote: If n ≠ -(pv+fv)/pmt, n has the form logab → n*ln(a) - ln(b) = 0 L(x) = n*log1p(x) - ln(b) b = 1 - (pv+fv)/(pmt/x+pv) = (pmt - fv*x) / (pmt + pv*x) L(0) = n*log1p(0) - ln(pmt/pmt) = 0 - 0 = 0 L(x) introduced extra root at x=0, thus required pv+fv+n*pmt ≠ 0 check. Bad guess might leads to this, with next iteration turns NaN, wasting time and effort. Also, if rate guess is close to edge, ln(b) blows up, turning L(x) very curvy. For Newton's method, better formula is to place ln(b) as denominator: M(x) := log1p(x) / log1p(-(pv+fv)/(pmt/x+pv)) - 1/n This also removed L "false" root of 0; M roots now matched f roots. lua> D = require'dual'.D -- with above updated code lua> function L(x) return x:log1p():mul(n) - x:rcp(pmt):add(pv):rcp(-(pv+fv)):log1p() end lua> function M(x) return (x:log1p() / x:rcp(pmt):add(pv):rcp(-(pv+fv)):log1p()):sub(1/n) end lua> n,pv,pmt,fv = 10, -100, 10, 1e10 -- constants are just numbers! lua> a, b = pmt/fv, pmt/-pv -- rate edges lua> a, b 1e-009 0.1 lua> require'fun'() lua> eps = 1e-6 lua> x = D.new(b+eps, 1) lua> zip(iter(D.newton,L,x), iter(D.newton,M,x)) :take(8) :each(print) Code: 0.1000299805316535 0.10091091761367948 Except for the hole [a,b], M shape seems continuous. Newton's method for M=0, we can even use the wrong edge! Actually, this is even better guess than from the correct edge! lua> x = D.new(a-eps, 1) lua> zip(iter(D.newton,L,x), iter(D.newton,M,x)) :take(8) :each(print) Code: 5.90875527827794e-006 0.80756269309747 |
07-16-2022, 02:58 PM
(07-11-2022 09:08 PM)Albert Chan Wrote: (*) Another way is simply get a better guess. Had we put back pmt term, we get: newx = function(x) return expm1(log1p(-(pv+fv)/(pmt/x+pv))/n) end newx(x = ±Inf) reduced to quoted pmt=0 approximation. x ← newx(x) work well for huge x; it is almost as good as Newton's method. x - (newx - x) / (newx - x)' ≈ x - (newx - x) / (0 - 1) = newx lua> require'fun'() lua> genx = function(f,x) f=f(x); return f, f, f-x end lua> n,pv,pmt,fv = 10, -100, 10, 1e10 lua> iter(genx,newx,Inf) :take(8) :each(print) Code: 5.309573444801933 -Inf Some references, for how Lua iterator work https://luafun.github.io/under_the_hood.html#iterators http://lua-users.org/wiki/IteratorsTutorial https://www.lua.org/pil/7.1.html |
11-28-2023, 05:43 AM
tvm program assumed END mode. Here is tvm wrapper for BEGIN mode.
Code: function tvm_begin(n,i,pv,pmt,fv) > tvm_begin(n,i,360, .05/12, 100e3, nil, 0) -534.5941473979808 |
06-09-2024, 04:07 PM
(This post was last modified: 06-25-2024 05:12 PM by Albert Chan.)
I made some fixes, and changes to the interface, here is the update
1. _find_rate() does not do time-symmetry anymore. tvm() already does. 2. _iter_i() updated with cleaner code 3. _iter_i2() removed. Halley's method may have trouble with tiny rate 4. edge_rate(n,i,pv,pmt,fv) can now return big edge, if i = false Code: function EFF(i,n,div) i=div and i/n or i; return expm1(log1p(i)*n) end (06-23-2022 07:04 PM)Albert Chan Wrote: f value should read as if whole column get shifted up. Now it is easier to read, verbose show (i, f(i)), without shifting column It also show initial guess rate (previously hidden) lua> tvm_begin(40, nil, 900, 1000, -1000, true) Code: -0.5 -4.547473508864641e-11 Now, we can also supply rate guess (not recommeded for general use) Code assumed user guess is bad, might overshoot, and use next one as initial guess. lua> tvm_begin(40, 0, 900, 1000, -1000, true) Code: 0 997.5 Update 6/16/2024 Now, it can use big edge if i=false, small edge if i = nil lua> tvm_begin(40, false, 900, 1000, -1000, true) Code: -0.5263157894736842 -52.63157894737378 I am unsured when to use special branch (from f(0),f'(0),f''(0)) for iter_i(). Because of quadratic fit, it does not work well with huge compounding effect. When rate is tiny, general branch (using f(i) formula) does not work. For now, I think a compromise may be best: 1+n*i*i == 1 Update 6/25/24 patch is making more sense now, because below 2 are equivalent: NPMT(n, i, pv, pmt, fv) == NPMT(n/2, i*(i+2), pv, pmt*(i+2), fv) RHS rate = (1+i)^2-1 = i*(i+2) --> number of payments cut in half. n → n/2 --> payments about doubled, pmt → pmt*(1+i) + pmt = pmt*(2+i) LHS==RHS, we cannot base only on rate to decide when to switch. We need to get rough invariant. If i is small, (n/2) * (i*(i+2)) ≈ (n*i) |
06-09-2024, 04:46 PM
I did* translate your code into R for use with the (R)mpfr library (in a very clunky manual way - it was only to serve the basic purpose of getting more precise results than the DM42/Plus42 can output).
But just for fun, here is it with the problem above, initial guess of 10%, solving with 1000 bits of precision: Code: iter i f f0 eps With i as: Code: 1 'mpfr' number of precision 1000 bits * probably before your changes above, though I don't think you've changed the algorithm of the newton method? |
06-09-2024, 05:17 PM
(06-09-2024 04:46 PM)dm319 Wrote: But just for fun, here is it with the problem above, initial guess of 10%, solving with 1000 bits of precision ... It is the same Newton's method, f(i) = npmt(n,i,pv,pmt,fv) But now {i, f(i)} is on the same row, for easy reading. lua> tvm_begin(40, 0.1, 900, 1000, -1000, true) Code: 0.1 1189.774058558563 Last rate is really i - (f/f')/2, to reduce error radius. Since f=0, there is no correction, last = previous |
06-09-2024, 05:48 PM
RE: TVM solve for interest rate, revisited | |||
06-09-2024, 06:42 PM
Another bit of fun, this is for problem 4, which switches to the secant method as it hits zero.
Code: iter i f f0 eps type I'm not quite sure why it seems to do an extra few rounds in the secant loop. It might be that the high precision can't be represented using the doubles here. I converted to double so that dealing with dataframes and graphs was familiar. |
06-10-2024, 01:33 AM
(06-09-2024 06:42 PM)dm319 Wrote: Another bit of fun, this is for problem 4, which switches to the secant method as it hits zero. When rate is really tiny, there is almost no compounding effect. We can treat curve as linear, perhaps quadratic. iter_i() top branch does exactly that, f(ε) ≈ f(0) + f'(0)*ε + f''(0)/2!*ε² Problem 4: lua> n, pv, fv = 480, 1e5, 0 lua> pmt = -pv/n -- assumed 0% interest lua> pmt -208.33333333333334 C*pv + n*pmt = 0 C = -n*pmt / pv C-1 = (n*pmt+pv) / -pv = (n+1)/2*i + (n^2-1)/12*i² + ... Even if we use full precision, in binary or decimal, pmt has some error. (C-1 ≠ 0) Assume C-1 as linear is good enough. Solving Quadratic give same rate. lua> C1 = fma(n,pmt,pv) / -pv lua> C1 4.5474735088646414e-17 lua> i = C1 / ((n+1)/2) lua> i 1.8908413758272938e-19 |
06-10-2024, 08:57 AM
Thanks Albert. Yes, this was the reason I switched over to your solver for the TVM - it was failing at i = 0 to converge on 0 using the built-in solver. (PS do you know how the built-in solver works?).
I thought it was neat to see it switch over to the top branch halfway through solving this. I don't quite understand why if there is little/no compounding effect the Newton solver doesn't quite home in properly. What would be the equation to view the curve? I'm not quite understanding how if the curve is straight that would be a problem for Newton? PS - also you mentioned in another thread that one of Rob's examples had pointed out a bug in the Plus42 code - I'm now realising you must have come across the example and bug a while ago, and this isn't a recent thing? I was saying that I experienced the bug in my code, but it turns out I had set it to 'end' rather than 'begin', and the code was running fine. |
06-10-2024, 03:27 PM
(This post was last modified: 06-10-2024 07:51 PM by Albert Chan.)
(06-10-2024 08:57 AM)dm319 Wrote: I don't quite understand why if there is little/no compounding effect the Newton solver doesn't quite home in properly. Because f(ε) is hard to compute accurately. Even worse for f'(ε) ... Suggestions welcome! This is why top branch is needed, for tiny rate. Let's try Problem 4 with tvm, but tiny rate top branch disabled. Code: < if 1+n*i*i==1 then lua> tvm(n,nil,pv,pmt,fv, true) 0.0020833333333333333 121.44489395195453 0.0002491081681869074 12.7294855996644 4.760073393189775e-06 0.2385901432158164 1.8075046870790729e-09 9.056352914171839e-05 2.6088558403073705e-16 1.3073986337985843e-11 -4.488825652889797e-19 0 -4.488825652889797e-19 f(ε) is bad ... f'(ε) not shown, but likely worse. Lets make bottom branch more accurate, with log1p_sub / expm1_sub More specifically, we wanted accurate y = D-1, where D = n / USFV(i,n) Let x = log1p_sub(i) = log1p(i) - i y ← (1+i)^n - 1 - n*i = expm1(n*log1p(i)) - n*i = expm1(n*(x+i)) - n*i = expm1_sub(n*(x+i)*n) + n*(x+i) - n*i = expm1_sub((x+i)*n) + n*x y ← -y / (y+n*i) -- = D-1 old Wrote:local x = i/expm1(n*log1p(i)) new Wrote:local x = log1p_sub(i) lua> tvm(n,nil,pv,pmt,fv, true) 0.0020833333333333333 121.44489395195444 0.0002491081681869104 12.72948559966454 4.7600733931911846e-06 0.23859014321589925 1.8075046869901344e-09 9.056352914562415e-05 2.6102777224213185e-16 1.3096744612389123e-11 -3.625568200933119e-19 -4.837592392112496e-14 1.201966826538812e-19 (log1p_sub / expm1_sub / fma) still does not help f with tiny rate! I am not too concern with actual rate. Getting to 0% really depends on luck. The issue is with bad Newton correction, it might mess up convergence. Code don't require quadratic convergence, but must be one-sided! Unanticipated overshoot might cause code to quit too early. Quote:What would be the equation to view the curve? {f(0), f'(0), f''(0)} evaluated symbolically using limit. lua> f0 = fma(n,pmt,pv+fv) / n lua> f1 = (pv-fv + (pv+fv)/n)/2 lua> f2 = (pv+fv)/n * (n*n-1)/6 lua> f0, f1, f2 -9.473903143468002e-15 50104.166666666664 7999965.277777779 f(i) ≈ p(i) = f0 + f1*i + f2/2*i² lua> i = -f0/f1 lua> i 1.8908413758272935e-19 lua> i = -(f0 + f2/2*i*i)/f1 lua> i 1.8908413758272935e-19 Note: top branch does not actually use f(i). It only use quadratic p(i) Quote:PS - also you mentioned in another thread that one of Rob's examples had pointed out a bug in the Plus42 code - I'm now realising you must have come across the example and bug a while ago, and this isn't a recent thing? It was a recent thing. Example 5 solved i ≈ 3.17e-9, 1+i*i==1 goes to top-branch. (Plus42 binary version) But it also have huge compounding effect, quadratic fit simply does not cut it. I then changed it to 1+i==1, but now tiny i numerical issue switched to general branch. As a compromise, for now, I use 1+n*i*i==1 to switch to tiny rate branch (1+i)^n = (1+APR/PYR) ^ (N*PYR) n*i = N*APR, likely not crazy sized number |
06-13-2024, 01:05 PM
(This post was last modified: 06-15-2024 12:02 AM by Albert Chan.)
I recently discovered split loan method. Is this new?
![]() If loan split correctly, we can get a good guess rate, and formula to iterate for true rate. (06-08-2024 11:47 PM)Albert Chan Wrote: Solve with split loan method Here is one with huge true rate (see post #22, #27, #28, #29) lua> n, pv, pmt, fv = 10, -100, 10, 1e10 lua> tvm(n,nil,pv,pmt,fv, true) Code: 1e-09 999999995.5 tvm() picked time-reversed setup (x=0), edge = pmt/fv = 1e-9 The other edge (also x=0) is just as bad, edge = pmt/-pv = 0.1 Convergence is slow, because huge rate caused f(i) to be curvy. (07-16-2022 02:58 PM)Albert Chan Wrote: newx = function(x) return expm1(log1p(-(pv+fv)/(pmt/x+pv))/n) end Above is from post#29, I just realize this can be easily explained as a split loan! If we replace log1p(z) = ln(1+z), ln argument is: -(pv+fv) / (pmt/x+pv) + 1 = -(fv-pmt/x) / (pv+pmt/x) We might as well simplify this, with y = pmt/x Code: Loan: n pv pmt fv We don't have to use the setup to solve rate. Guess i when y=0 is already good. lua> y = 0 lua> i = EFF(-(pv+fv)/(y+pv), 1/n) -- guess lua> tvm(n,i,pv,pmt,fv, true) 5.30957344513139 9.999999722758162 5.321456835153608 0.08065988603186725 5.321554252697288 5.347635692487529e-06 5.321554259156789 -1.3642420526593924e-12 5.321554259156788 Here is another way to split loan. (any more ways?) Code: Loan: n pv pmt fv Sign checks: #1: sgn(pv+z) = sgn(-fv) #2: sgn(z) = sgn(n*pmt), because NPMT is time-symmetrical, f=NPMT/n is not lua> for loop=1,7 do i=APR(-fv/(pv+z)-1,n); z=pmt*-EFF(i,-n)/i; print(i,z) end 5.309573444801933 1.8833904463248339 5.321581577921809 1.8791405816968803 5.321554197006327 1.879150250410811 5.321554259298183 1.8791502284142771 5.321554259156466 1.8791502284643202 5.321554259156789 1.879150228464206 5.3215542591567875 1.8791502284642068 I don't know how to name this ... any idea? EFF(i,n) = (1+i)^n - 1 APR(i,n) = (1+i)^(1/n) - 1 But google search effective rate formula, it was normally defined with mul/div. To me this is less useful, so I added a third argument, in case true EFF, APR needed. EFF(i,n,true) = EFF(i/n,n) APR(i,n,true) = APR(i,n)*n lua> EFF(0.12, 12, true) 0.12682503013196972 lua> APR(_, 12, true) 0.12 |
06-14-2024, 03:29 PM
Code: Loan: n pv pmt fv We are not done with split loan yet ... Lets scale PV column to -1 Code: #1: n -1 i 1 , where i = pmt/(x-pv) (1+i)^n = 1+i2 → sgn(i2) = sgn(n*i) (*) i2 / i = -(pv+fv) / (pmt/i+pv) / i = -(pv+fv) / (pmt+pv*i) sgn(-(pv+fv)/n) = sgn(pmt+pv*i) = sgn(pmt-fv*i) // RHS from time-symmetry Or, rewrite to show edge rate (note: ∞ is not an edge ... we might not have 2 edges) sgn(-(pv+fv)/n) = sgn(pv*(i - pmt/-pv)) = sgn(-fv*(i - pmt/fv)) Based on signs, there is no reason to start from wrong side of edge rate. It still work, but would converge slower than starting guess from edge. OTTH, rate better than edge may overshoot ... and we don't know where! (*) Let Kn = (1+x)^n > 0 // integer n, x = (-1, ∞) Let Sn = Kn - 1, we want to show sgn(Sn) = sgn(n*x) Sa+b = (Sa+1)*(Sb+1) - 1 = Sa*(1+Sb) + Sb = Sa*Kb + Sb S1 = (1+x) - 1 = x S2/S1 = (x*(1+x) + x)/x = (x+2) > 1 S3/S2 = (x*K2 + S2)/S2 = K2/(S2/S1) + 1 > 1 S4/S3 = (x*K3 + S3)/S3 = K3/(S3/S1) + 1 > 1 ... 0 = Sn-n = S-n Kn + Sn (Sn≥1 / x ≥ 1) and (Sn / S-n = -Kn < 0) ⇒ sgn(Sn) = sgn(n*x) QED In other words, APY and APR have same sign, even if n is negative. This perhaps is more elegant proof. Bonus: it covered real n too! log1p(x)' = 1/(x+1) > 0 expm1(x)' = exp(x) > exp(-1) > 0 Both are increasing function. (we don't care the shape, only signs) expm1(0) = log1p(0) = 0 --> sgn(expm1(x)) = sgn(log1p(x)) = sgn(x) Sn = expm1(n*log1p(x)) log1p(Sn) = n*log1p(x) sgn(Sn) = sgn(n*x) QED |
