ftp.hp.com working again
08-10-2022, 01:01 PM
It seems that "ftp.hp.com/pub/calculators/Prime/" is working again.
(Reminder: Most web browsers no longer support ftp unless you have a plugin. Windows File Explorer works.) |
08-10-2022, 07:42 PM
RE: ftp.hp.com working again
That's great. It has the past few years of firmware for G1, G2 and Virtual. Thanks.
08-10-2022, 07:53 PM
Doesn't work for me, the server directly closes the connection.
08-10-2022, 08:04 PM
(08-10-2022 01:01 PM)Wes Loewer Wrote: It seems that "ftp.hp.com/pub/calculators/Prime/" is working again. Not for me. I'm using Filezilla 3.60.2 and it closes immediately. Tom L Cui bono? |
08-10-2022, 09:36 PM
If having trouble connecting, check whether turning FTP "passive" mode on or off makes a difference.
— Ian Abbott |
08-11-2022, 08:15 AM
(08-10-2022 01:01 PM)Wes Loewer Wrote: It seems that "ftp.hp.com/pub/calculators/Prime/" is working again. That's good news. The data stored there just needs to be brought up to date with what's up on https://www.hpcalc.org/prime/pc/ now. Current daily drivers: HP-41CL, HP-15C, HP-16C |
08-11-2022, 10:42 AM
Windows file explorer doesn't works. The connection is closed.
I tried also ftp explorer built-in in total commander (anonymous user, passive mode) and the result: The IP adress wasn't found. |
08-11-2022, 11:14 AM
It worked with FileZilla yesterday, but today it does not work anymore
08-11-2022, 11:19 AM
5 minutes later… and it works again! Strange.
08-11-2022, 11:57 AM
Works fine for me using File Explorer on Windows.
Thanks for restoring this. --Bob Prosperi |
08-11-2022, 03:21 PM
Don't work here, Nice France
Gérard. |
(This post was last modified: 08-11-2022 07:31 PM by redglyph.)
It's region-enforced. (EDIT: or not...)
I'm in Europe and it won't connect, but if I use a VPN located in the US, it works. Nothing there that can't be found elsewhere though. You can use the very good ProtonVPN, there's a free version that will allow you to do that. Those guys have good privacy solutions. |
08-11-2022, 04:02 PM
I'm in UK, and was able to connect on my android phone using Total Commander. None of the other file managers worked that support ftp worked though.
08-11-2022, 05:43 PM
I can connect directly from Czechia (EU) so I don’t think there’s a regional filter set on the server side. FTR, I’m using lftp running on Linux.
I guess those who can’t connect run into some filter much closer to the client side - a firewall on the PC or their home router. Or maybe their ISP filters it. After all, some consider the protocol obsolete. |
08-11-2022, 07:31 PM
(08-11-2022 05:43 PM)vaklaff Wrote: I guess those who can’t connect run into some filter much closer to the client side - a firewall on the PC or their home router. Or maybe their ISP filters it. After all, some consider the protocol obsolete. That's a possibility, a VPN bypasses a lot of that. To be honest, I would find it strange if they had set a regional filter too. |
08-20-2022, 06:59 PM
(This post was last modified: 08-20-2022 07:08 PM by Liamtoh Resu.)
Are there any configuration settings for a connection to http://ftp.hp.com?
I am able to connect and transfer files from http://ftp.nluug.nl. I am using mxlinux 21.1 kde and double commander as a file transfer program. (The last time I connected successfully to http://ftp.hp.com was in May, 2021 on win 8.1 using filezilla. I could not connect using filezilla today, (Aug 20, 2022).. (The blog program is inserting the 'http" prefix before the ftp addresses) Thanks. |
08-20-2022, 11:39 PM
I’ve tried, just now, connecting to ftp://ftp.hp.com/pub/calculators (from Canada) with FileZilla 3.55.1 on a Mac, and met with success.
08-21-2022, 10:33 AM
Not sure if this is sill being discussed, but for me (in Germany) on Windows 10, it worked both with Windows Explorer and Filezilla via my regular ISP.
08-22-2022, 05:22 AM
Thanks for the ftp check.
With a little persistence and os shuffling I received the prime files with a live kde demo version of mx linux 21.1 and filezilla. There were a lot of 500 illegal port command messages and connection resets. I used double commander and k3b to burn the files to a disc. I put the linux distro on a stick using the exfat version of yumi. Filezilla on win 10 was not connecting at all. Thanks again. |
10-17-2022, 04:04 PM
recently registered a few days ago and wanted to say that the ftp ://ftp.hp.com/pub site is down for good as of early October 2022. tried that site on several of my Windows PCs in Firefox/Chrome/MS Edge and even Filezilla and would never connect.
I even tried that ftp site on my relative's Win10 PC using a different ISP and got the same result - no connection it had been mostly working back in August 2022 and in September 2022, but this October not so much. it seems HP has finally shut down that site |
