Some of Python's linalg commands in HP Prime
05-08-2021, 01:49 PM
Matrix Format [ [ row ], [ row ], … [ row ] ]
linspace(start, stop, number of points desired + 1)
arange(start, stop, step size); default step size: 1; returns a 1 row array from start to stop using step size
identity(n): returns an identity matrix as n x n
transpose(matrix): transpose of a matrix
inv(matrix): inverse of a matrix
shape(matrix): returns the dimensions of the matrix in an ordered pair (row, columns)
rref(matrix): row reduced echelon form of a matrix
det(matrix): determinant of a square matrix
peval(array of coefficients, x): polynomial evaluation (order is from high to low), can take complex arguments
horner(array of coefficients, x): polynomial evaluation using Horner’s method
pceoff(array of roots): returns an array representing a polynomial’s coefficients, can take complex arguments
proot(array of coefficients): returns an array of roots, can take complex arguments
add(array, array) or add(matrix, matrix): addition element by element
sub(array, array) or sub(matrix, matrix): subtraction element by element
dot(array, array): dot product
cross(array, array): cross product
imag(complex number): imaginary part – works on arrays and matrices
real(complex number): real part – works on arrays and matrices
I believe that fft and ifft have to do with fast fourier transforms.
05-08-2021, 11:00 PM
RE: Some of Python's linalg commands in HP Prime
thanks Eddie.
(05-08-2021 01:49 PM)Eddie W. Shore Wrote:  I believe that fft and ifft have to do with fast fourier transforms.
yup; the integrated Help has a few examples…
Cambridge, UK
Casio, Rockwell 18R
05-09-2021, 05:36 PM
Those sound like the function names from the Prime CAS and the 50g.
BTW, pcoeff is misspelled. Smile
05-09-2021, 05:58 PM
(05-09-2021 05:36 PM)John Keith Wrote:  Those sound like the function names from the Prime CAS and the 50g.
Sorry. Good catch!
05-11-2021, 06:47 PM
oops, sorry, my comment re Help of course refers to the CAS commands, whereas this thread is about Python… I need more coffee.
Cambridge, UK
Casio, Rockwell 18R
09-08-2021, 10:10 PM
(05-08-2021 01:49 PM)Eddie W. Shore Wrote:  Matrix Format [ [ row ], [ row ], … [ row ] ]
Hi, I found it difficult to transpose a matrix with PYTHON. For instance:
transpose ([[1,2,3], [4,5,6]]) gives me this result: [[1,4], [3,2], [5,6]]
The correct result is: [[1,4], [2,5], [3,6]].
Is there a bag perhaps?
09-10-2021, 04:55 AM
There is indeed a bug in transpose for non square matrices.
09-11-2021, 09:13 AM
(09-10-2021 04:55 AM)parisse Wrote:  There is indeed a bug in transpose for non square matrices.
Thanks for the answer, Parisse. Since I had to use the "transpose" command in my Python program, I had to write a subroutine to transpose the arrays:
from linalg import *
def transposeRr(matriceRr):
    L=shape(matriceRr);
    r=L[0];
    c=L[1];
    matricezero=zeros(c,r);
    for u in range(0,r):
        for uu in range (0,c):
            matricezero[uu][u]=matriceRr[u][uu];
    return matricezero;
09-11-2021, 10:36 AM
(09-11-2021 09:13 AM)robmio Wrote:  Since I had to use the "transpose" command in my Python program, I had to write a subroutine to transpose the arrays ...
Is matrix simply list of list ? If yes, we can transpose with a 1-liner.
>>> transpose = lambda a: [list(r) for r in zip(*a)]
>>> transpose([[1,2,3], [4,5,6]])
[[1, 4], [2, 5], [3, 6]]
09-11-2021, 11:17 AM
Congratulations! This short solution you proposed works very well in my program
10-27-2022, 07:43 PM (This post was last modified: 10-27-2022 07:55 PM by Ioncubekh.)
matrix() doesn't follow rules of matrix dot product. Possible bug related to post#7
M1= matrix([ [1,2,3], [10,100,1000] ])
# Sum of rows of any Matrix
EachRowSum= dot( M1, ones( len(M1[0]), 1 ) )
# Sum of columns of any Matrix ... NOT WORKING
EachColSum= dot( ones( 1, len(M1) ), M1 )
HP Prime G1
Python via Android Termux...
11-02-2022, 02:20 AM
In the absence of multi-dimensional arrays (numpy) following commands using native zip(), map(), lambda, list constructions ...can be used to have similar effect while considering dimensions as well.
Few array examples & their equivalents
# x + b21 * k1 + b32 * k2
# where x, k1 & k2 are numpy arrays while b21 & b32 is some scalar value
[sum(i) for i in zip(x, [b21*i for i in k1], [b32*i for i in k2] )]
# r  / ( q*( abs(x)+abs(k1) ) )
# where r, x & k1 are equal shaped arrays & q is scalar value
[ (r[i] / ( q*( abs(x[i]) + abs(k1[i]) ) ) ) for i in range(len(x) ) ]
HP Prime G1
