Comments and discussion on Valentin's 4th "Then and Now" - Area
01-11-2023, 08:10 AM
(This post was last modified: 01-11-2023 02:01 PM by EdS2.)
This thread is an offering to anyone and everyone who would like a place to discuss or digress on Valentin's latest challenge thread:
[VA] SRC #012d - Then and Now: Area As Valentin does set some splendid challenges but strongly prefers a clean thread for later publication, here's a place where we can discuss our approaches, show any mathematical analysis, use any tools, calculators or computers which might help us to enjoy the challenge. My aim is only to collect those posts which are not within Valentin's rules - please continue to post in the original thread, especially with your solutions as requested over there. I do this in a spirit of friendly collaboration, hoping that one strict thread and one loose thread will be a good combination which can keep everyone happy. As such, please no argumentation about the way Valentin runs his challenges - let's stick to the calculations, the mathematics, the analysis. Links to tangentially related papers, discussions, videos, are all very welcome. |
01-12-2023, 04:27 PM
RE: Comments and discussion on Valentin's 4th "Then and Now" - Area
(01-12-2023 03:06 PM)Albert Chan Wrote: If integrand behave like a polynomial, IBOUND likely over-estimates true error. If integrand is *not* polynomial-like, even with u-transform, anything goes. Plug to my old thread, HP71B IBOUND fooled |
01-19-2023, 06:57 PM
Valentin just post the solution, which did include the area of the tiny speck.
Although I knew of the speck, I thought it were not OP were asking ... I guessed wrong. Anyway, I tried this with HP Prime emulator. integrate() use Adaptive Gaussian Quadrature, switching to Romberg if that failed. For the main area, it work wonderfully, even with singularity inside interval. Adpative part just zeroed in to it automatically, as needed. CAS> s := sqrt(-ln(y*y/30.07+exp(-sin(y)))) :; CAS> f := surd(y+s,3) - surd(y-s,3) :; CAS> int(f, y, 0, 2.82740261413) 2.07662636775 Assuming speck is an ellipse, we already have 5+ digits accuracy. CAS> c := -4.06717950603 // center of speck interval CAS> a, b := 0.017967241585, f(y=c)/2 // major, minor axis CAS> pi*a*b // ellipse area 7.19760850546e−5 The shape is simple, but Adaptive Gaussian Quadrature failed, switched to Romberg. Romberg result (no u-substituion) is worse than above ellipse estimate. CAS> int(f, y, c-a, c+a) [7.19759235247e−5, 7.19761930451e−5] The reason it failed is because the gap (2a), relative to center (c), is just too small. Internally, integrate limit is from -1 to 1, with gaussian quadrature weights and abscissa. When it get mapped to this tight domain, there is just not enough room. (think pigeonhole principle) The inaccurate mapped abscissa generated fuzziness to f value, which mess up the area. All we need is to "push out" f fuzziness. (1e-4 > area of speck) CAS> int(f + 1e-4/(2a), y, c-a, c+a) - 1e-4 7.19761930451e−5 |
01-19-2023, 08:43 PM
(01-19-2023 06:57 PM)Albert Chan Wrote: The inaccurate mapped abscissa generated fuzziness to f value, which mess up the area. Another way is to set epsilon higher (XCas work the same way too). CAS> epsilon := 1e-11 // default was 1e-12 CAS> int(f, y, c-a, c+a) 7.19761930453e−5 |
01-19-2023, 09:23 PM
(This post was last modified: 01-19-2023 09:26 PM by J-F Garnier.)
First of all, thanks to Valentin for this new problem. It kept me busy for long hours.
Also the kind request to postpone our results for a few days was an interesting exercise. For now, I will just make a couple of comments purely focusing on the programming aspects: (01-19-2023 05:08 PM)Valentin Albillo Wrote: 1 DESTROY ALL @ DIM U @ H=1/3 @ D=FNROOT(1,1,SQR(FNG(FVAR))-FVAR) 1. You may wonder why Valentin explicitly declared the variable U ("DIM U"), and not the others. Don't remove this DIM statement! Its purpose is related to a HP-71B bug, still present in the latest 2CDCC version and documented here, that I can summarize as: don't create new variables in the functions called by INTEGRAL or FNROOT, but create/declare them before. Matter of fact, my own solution is buggy in that respect, since the X, X1 and X2 variables are created in the FNF function called by INTEGRAL: (01-12-2023 09:34 AM)J-F Garnier Wrote: 280 DEF FNF(Y)During my program development I manually called FNF surely several times before running the INTEGRAL function on it, so it was harmless, still to be safe X, X1 and X2 should be created before, for instance with: 55 REAL X,X1,X2 2. The "1/10^10" expression may look inefficient and be better replaced by 1E-10. The problem is that the HP-71 decompiles this value in standard format as .0000000001 that is difficult to re-read. This is one of the few minor annoyances of the HP-71 BASIC. I used the same 10^n trick for readability in my own solution. J-F |
01-20-2023, 12:07 AM
(This post was last modified: 01-20-2023 12:39 PM by Albert Chan.)
(01-19-2023 06:57 PM)Albert Chan Wrote: Although I knew of the speck, I thought it were not OP were asking ... I guessed wrong. I had already spent my 1 post in VA thread. This update included the speck too. 10 DESTROY ALL @ M=30.07 @ A=.831971149978 @ B=2.82740261413-A @ P=10^(-8) 20 T=1/3 @ DEF FND(Y,S)=SGN(Y+S)*ABS(Y+S)^T-SGN(Y-S)*ABS(Y-S)^T 30 DEF FNF(Y)=FND(Y,SQR(-LN(Y*Y/M+EXP(-SIN(Y))))) 40 B=B*2 @ DEF FNG(Z)=(FNF(A*Z)+FNF(A-A*Z))*A+FNF(A+B*Z)*B 50 SETTIME 0 @ I=INTEGRAL(0,1,P,FNG(.5*IVAR^3)*IVAR^2)*1.5 @ DISP I;"+"; 60 DISP INTEGRAL(-4.08514674762,-4.04921226445,P,FNF(IVAR));"=";I+RES,TIME >run 2.07662636775 + 7.19761930307E-5 = 2.07669834394 1.14 HP17B estimated timing = 1.14*200 = 228 s (≈ 4 minutes) FNF(y) calls: main : speck = 381 : 63 ≈ 6.05 : 1 Time spent : main : speck = .98 : .16 ≈ 6.13 : 1 Update Jan 20,2023: Above hard coded constants are obtained from another section of code. I normally code it this way, to keep core part clean. >list 999,9999 999 END 1000 DEF FNE(Y)=Y*Y/M+EXP(-SIN(Y))-1 1010 DISP "main: 0",FNROOT(.5,1,FNE(FVAR)-EXPM1(-FVAR^2)),FNROOT(2,3,FNE(FVAR)) 1020 DISP "speck:",FNROOT(-4.1,-4.05,FNE(FVAR)),FNROOT(-4.05,-4,FNE(FVAR)) >run 1000 ! integral limits main: 0 .831971149978 2.82740261413 speck: -4.08514674762 -4.04921226445 |
01-20-2023, 01:56 AM
Hi, J-F, (01-19-2023 09:23 PM)J-F Garnier Wrote: First of all, thanks to Valentin for this new problem. It kept me busy for long hours. You're welcome. Glad you liked it. Quote:Also the kind request to postpone our results for a few days was an interesting exercise. Not everyone agreed. Someone posted his solution before the stated time limit, which I'm sure you didn't like at all, though I immediately posted a message to let the person know and he kindly deleted the post. Also, some other person essentially complained that he much preferred to see tentative post after tentative post, refining the solution all the time, and learning from the refining process, which with the delay and the suggestion (not mandatory rule) that people would do best refining their initial solutions before posting them, to reduce the clutter in the thread, essentially prevented that learning process for him. This being so, I'm not sure if the benefits outdo the disadvantages, so perhaps I will reinstate the 2-3 day delay for future problems, or perhaps I won't. What do you think ? Quote:1. You may wonder why Valentin explicitly declared the variable U ("DIM U"), and not the others. Don't remove this DIM statement! Its purpose is related to a HP-71B bug, still present in the latest 2CDCC version and documented here, that I can summarize as: don't create new variables in the functions called by INTEGRAL or FNROOT, but create/declare them before. Correct. I mentioned it in my original solution's post, I quote:
Quote:The "1/10^10" expression may look inefficient and be better replaced by 1E-10. Correct. On the positive side, though entering 1E-10 is decompiled as .0000000001 (which certainly looks ungainly and may cause the line to exceed maximum length,) it has the benefit that it takes 4 less bytes of RAM (my program would get shortened from 244 bytes to just 240 bytes,) and also executes somewhat faster. Albert Chan Wrote:I had already spent my 1 post in VA thread. Let's see. First of all, you posted 3 times to the thread, not 1, which is perfectly Ok by me, and in any case I posted the following:
Don't take my advice if you don't want to and please don't take offence, but I think that your efforts and time would be best spent creting a very good, refined post, properly formatted, for the benefit of the readers if nothing else. Also, in your code above, namely:
20 T=1/3 @ DEF FND(Y,S)=SGN(Y+S)*ABS(Y+S)^T-SGN(Y-S)*ABS(Y-S)^T [...] 60 DISP INTEGRAL(-4.08514674762,-4.04921226445.P,FNF(IVAR));"=";I+RES,TIME" Last, in one of your posts in my main thread you begin your post with this, I quote:
Let s = sqrt(-log(R)) ≥ 0 ((x-d)^3-y)^2 < s^2 y-s < (x-d)^3 < y+s x is real if s is real --> R ≤ 1 --> 0 ≤ y ≤ 2.82740261413 Height, \(\displaystyle f(y) = x_2 - x_1 = \sqrt[3]{y+s} - \sqrt[3]{y-s}\) f slope is infinite when y = s --> R = exp(-y^2) --> y = 0 or 0.831971149978 Let a = 0.831971149978, a+b = a+B/2= 2.82740261413" My honest, well-meaning advice would be: Do not be so eager to spend your time posting message after message, instead do try to refine your solution before posting anything, also don't include constants out of the blue, and last but certainly not least, spend a decent amount of time properly formatting your explanations and improving the understandability of your expressions. Remember, the quality of your posts ultimately depends not only on the quality of your math but equally important, also depends on the quality of the presentation of your results. Hope it helps. Thanks for your interest in my challenges ("Problems") and for your valuable contributions. Regards. V. All My Articles & other Materials here: Valentin Albillo's HP Collection |
01-20-2023, 09:12 AM
(01-20-2023 01:56 AM)Valentin Albillo Wrote:Quote:Also the kind request to postpone our results for a few days was an interesting exercise.... some other person essentially complained that he much preferred to see tentative post after tentative post, refining the solution all the time, and learning from the refining process... There are disadvantages for both. Respecting his delay avoid to prematurely spoil the game. But for difficult problems it's sometime nice to see other's attempts to progress toward a solution. I would say that a 2-3 day delay is fine, it's not excessive, and we can still have the opportunity to share partial results towards a complete solution. Actually, this is what happened here, Fernando and Werner identified the 'tiny area', Albert and I gave the correct 12-digit result (by different ways) of the main area, and I finally merged everything together. Also, we should keep in mind that if some of us are can afford to spent a lot of time on a problem each day, it's not necessary the case for everybody. Quote:I mentioned it in my original solution's post, I quote: Sorry, I missed that comment, anyway it was not bad to insist on this bug that not every HP-71B user may know or remember. J-F |
01-20-2023, 12:30 PM
(01-20-2023 09:12 AM)J-F Garnier Wrote: There are disadvantages for both. Respecting his delay avoid to prematurely spoil the game. I vote for no delay, and less rules, to encourage brainstorming among members. Many times, OT ideas are more interesting than original puzzle! The delay does not avoid spoiling the game ... only delay it. Whoever post solution first, already spoil the game ... but someone has to do it! |
01-21-2023, 12:34 AM
Hi, J-F Garnier and Albert Chan, J-F Garnier Wrote:[...] for difficult problems it's sometime nice to see other's attempts to progress toward a solution. I would say that a 2-3 day delay is fine, it's not excessive, and we can still have the opportunity to share partial results towards a complete solution. I see. Thanks for your reasoned opinion, I think that I'll tentatively make do for a 2-day delay and I will see how it works. If most people get used to it, fine. If most people resent it, there will be no delays and thus the earliest bird will catch the worm. J-F Garnier Wrote:Sorry, I missed that comment, anyway it was not bad to insist on this bug that not every HP-71B user may know or remember.[/b] I agree. I said "well-known" but on second thought it might not actually be the case. Besides DIM U, you can also use U=0, say, the important bit being that variable U is created outside of the UDF. Albert Chan Wrote:I vote for no delay, [...] Of course you do. Your vote is duly noted. Albert Chan Wrote:[...] and less rules [...] Oh really ! And which rules would you want to see eliminated ? Perhaps NO XCAS, MATHEMATICA, MAPLE, EXCEL, C/C++/C#, PYTHON, LUA, etc., or may be NO LENGTHY MATH SESSIONS ? Albert Chan Wrote:Many times, OT ideas are more interesting than original puzzle! Is that so ? My, my ... . Well, feel free to stop participating in my less interesting puzzles and post instead your own creations, surely you'll find them interesting enough. Albert Chan Wrote:Whoever post solution first, already spoil the game ... but someone has to do it! That much is obvious. But silly truisms aside, the delay is useful for the purpose I intend, which is to give interested but currently busy people a 2-day window of opportunity to try and work on their own solutions with no spoilers on sight. Anyway, Albert Chan, I did notice that you didn't reply to my post but to J-F Garnier's, and matter of fact you didn't even deign to reply to any of the points and well-meant advice I gave you re your posts, so rest assured that in the future I won't offer again any further comments or advice to you re your productions. V. All My Articles & other Materials here: Valentin Albillo's HP Collection |
01-21-2023, 01:25 AM
(01-21-2023 12:34 AM)Valentin Albillo Wrote:Albert Chan Wrote:Many times, OT ideas are more interesting than original puzzle! Please don't take it the wrong way. I did not meant your puzzles. They are always great. In fact, I joined HP forum just to join in the math discussion. My very first post here, dated July 20, 2018, for [VA] SRC#001 - Spiky Integral Quote:Anyway, Albert Chan, I did notice that you didn't reply to my post ... I believe action is better than words. I had already updated the post regarding the "magic constants" issues. Thanks for the advice. I'll try to improve presentation of my posts in the future. |
01-21-2023, 09:19 AM
I rather hope that the next Valentin challenge will come with a cross-linked comments-and-discussion thread like this - the two of us can coordinate.
And my hope is very much that we have both good things: a thread for the business of the challenge, and a thread for related business. And then we don't have to worry so much about what we post, only about where we post it. It remains impossible, I'm sure, to please everyone by choosing a precise time interval between the posting of the challenge and the encouraging of sharing of solutions. Any time interval will be too short for some and too long for others. But still we must choose something, zero or more days, and indeed it's Valentin who gets to choose. What I would recommend is to try to accommodate people who don't visit too often, and particularly I'd recommend posting the challenge in one week, allowing a weekend to pass, and allowing the free discussion the following week. This could be as short an interval as Friday evening through to Monday morning, in some timezone. I think it would help if the posted challenge includes the date and time for the thread to open for submissions and contributions. |
01-21-2023, 10:15 AM
(This post was last modified: 01-21-2023 10:28 AM by J-F Garnier.)
I want to discuss here one aspect of the challenge, computing the integral:
(01-19-2023 05:08 PM)Valentin Albillo Wrote: The integral for the big island, however, has two singularities, one at y = 0 (which doesn't cause any problems as this is the ymin extreme and the Width function being integrated is never evaluated there by INTEGRAL,) and another inside the range [ymin, ymax], which causes INTEGRAL to be at least 400% slower and even so it can only produce a value accurate to at most 7-8 digits, not 12. My observations showed me that the singularities do harm actually, both in execution time and accuracy. To illustrate the effect of the singularity at y=0, let's consider this simpler integral: I=INTEGRAL(0,1,E,IVAR^(1/6)) that reproduces the behaviour of Valentin's integral near y=0. The exact value of this integral is 6/7 = 0.857142857143 Here is what happens when trying to evaluate this integral with the 71B with increasing target accuracies: >FOR N=6 to 12 @ I=INTEGRAL(0,1,10^(-N),IVAR^(1/6)) @ DISP N;I;IBOUND;ABS(I-6/7) @ NEXT N N INTEGRAL IBOUND ERROR 6 .857143021890 8.57147612555E-7 .000000164747 7 .857142864063 8.57143170419E-8 .000000006920 8 .857142858515 8.57142936872E-9 .000000001372 9 .857142857195 8.57142862245E-10 .000000000052 10 .857142857151 8.57142858410E-11 .000000000008 11 .857142857127 8.57142857257E-12 .000000000016 12 .857142857127 -8.57142857257E-13 .000000000016 The accuracy is not improved beyond 1E-10, even if IBOUND seems to indicate better accuracy. At 1E-12, the negative IBOUND indicates that convergence is not detected within the limit of 32768 samples. The same occurs with Free42 for this example, where the effective accuracy is limited to about 1E-14, far from the 34-digit limit of the arithmetic. I solved the issue by splitting the main integral into 4 pieces in my solution. In that way, it is possible to concentrate the samples in the regions that need them, and avoid wasting time with useless samples in the other regions. J-F |
01-21-2023, 03:53 PM
(01-21-2023 10:15 AM)J-F Garnier Wrote: I solved the issue by splitting the main integral into 4 pieces in my solution. This is what HP Prime integrate does, by zeroed-in to the region that need them. However, this adaptive routine does not work well with fuzzy numbers. (see here) (01-11-2023 10:17 PM)Albert Chan Wrote: Let a = 0.831971149978, a+b = a+B/2 = 2.82740261413 My approach was by folding back to 1 integrand, with really bad region to the left. It has the advantage of flattening the curve, and possibly cancelled out singularities a bit. Except the ends, folded curve look like a straight line, with dowward slope: ◜◝◟ = ◜ + ◜ + ◟ ≈ ╲ We can even estimate size of main area by 1 g(z) evaluation >FNG(0.25) * 0.5 2.07508490846 BTW, a+b = a+B/2 = 2.82740261413 meant b = 2.82740261413-a, B = 2*b Better: (b,B) such that the relation is true ... sometimes it is hard to isolate variable. Thanks to JFG analysis, we have: f(ε) ≈ 2 * 6√(ε) Based from plots, I have the other: f(a ± ε) ≈ f(a) - 7/8 * 3√(±ε) → g(ε) ≈ f(a)*(a+B) + (2a) 6√(ε) - (B-a)*(7/8) 3√(ε) ≈ 5.715 + 1.664 6√(ε) - 2.764 3√(ε) Note that sign of ε terms are opposite, cancelling each other somewhat. g(ε) started curving downward when ε > 0.0000207 |
01-21-2023, 04:16 PM
(01-21-2023 03:53 PM)Albert Chan Wrote:(01-21-2023 10:15 AM)J-F Garnier Wrote: In that way, it is possible to concentrate the samples in the regions that need them, and avoid wasting time with useless samples in the other regions.This is what HP Prime integrate does, by zeroed-in to the region that need them. I had the idea that it may be possible to write an adaptive integration code on the 71B by first analysing the integrand behaviour, actually I'm surprised not to find anything like that in the forum or various 71B code archives (I didn't do a extensive search though). Maybe is it just too complex, or just with no real usage. (01-11-2023 10:17 PM)Albert Chan Wrote: Let a = 0.831971149978, a+b = a+B/2 = 2.82740261413 I read this part of your posts, but honestly didn't understand how you devised the RHS expression from f(y). I guess this is classic math, but after all Valentin's challenges have always been the right place to learn something, so if you could explain it a bit, it would be appreciated. J-F |
01-21-2023, 04:41 PM
(01-21-2023 04:16 PM)J-F Garnier Wrote:Thanks J-F for making me feel a bit less stupid, as I couldn’t figure that one out either!(01-11-2023 10:17 PM)Albert Chan Wrote: Let a = 0.831971149978, a+b = a+B/2 = 2.82740261413 Cheers, Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
01-21-2023, 05:07 PM
First we write as 3 mini-integrals, with bad region move to the left (lower limit)
\(\displaystyle\quad\int_0^{a+b} = \int_0^{a/2} - \int_{a}^{a/2} + \int_a^{a+b}\) Second, let y = c1+c2*z, dy = c2 dz, so that integrand limits matched. We could use any limits. I picked 0 .. 0.5, thus needed B = 2b. \(\quad\,\int_0^{a/2} f(y)\;dy = \int_0^{1/2} f(a\,z)\, (a\,dz)\) \(-\int_{a}^{a/2} f(y)\;dy = \int_0^{1/2} -f(a-a\,z)\, (-a\,dz)\) \(\int_{a}^{a+\frac{B}{2}} f(y)\;dy = \int_0^{1/2} f(a+B\,z)\, (B\,dz)\) Add it all up, we have: \(\displaystyle \int_0^{a+b} f(y)\;dy = \int_0^{1/2} \Big[\big(f(a\,z) + f(a- a\,z)\big)·a \;+\; f(a+B\,z)·B\Big] \,dz \) |
01-21-2023, 08:06 PM
(01-21-2023 04:41 PM)Werner Wrote:(01-21-2023 04:16 PM)J-F Garnier Wrote: I read this part of your posts, but honestly didn't understand how you devised the RHS expression from f(y).Thanks J-F for making me feel a bit less stupid, as I couldn’t figure that one out either! Sorry about this. My original draft spelled out the steps, but I was not sure about breaking LENGTHY MATH SESSION rule. (You may have noticed my recent math posts are getting very short ... sometimes too short) I had also considered breaking up main area into more natural 2 pieces, and apply u-transformation. \(\displaystyle \int_a^{a+b} = \int_0^a + \int_a^{a+b} \) Code is more readable, because this does not involve "back folding". But, I may need math to explain how u-substitution work, and why I need it here. INTEGRAL built-in u-sub is not enough. (that's why JFG sum main area from 4 pieces) To keep post short, I gave up on that idea. The code for getting integral limits were also in the draft. (*) I trimmed that too. Wrong move (*) the code is in this thread |
01-21-2023, 11:16 PM
(01-21-2023 04:16 PM)J-F Garnier Wrote: I had the idea that it may be possible to write an adaptive integration code on the 71B by first analysing the integrand behaviour, actually I'm surprised not to find anything like that in the forum or various 71B code archives (I didn't do a extensive search though). Maybe is it just too complex, or just with no real usage. I did Adaptive Simpson HP71B code a few months ago. With that loaded in memory, we update function, limits, and eps. >10 X1=0 @ X3=2.82740261413 @ E=10^(-8) >50 SUB F(X,Y) @ S=SQR(-LN(X*X/30.07+EXP(-SIN(X)))) >60 Y=SGN(X+S)*ABS(X+S)^(1/3)-SGN(X-S)*ABS(X-S)^(1/3) @ STOP >run 2.07662636771 8.96 ! @200x, about 30 minutes for HP71B SIMPSON can't see user defined function, so I coded with slower CALL F(X,Y) Based on timings alone, I guessed F(X,Y) called about 3000 times. I don't know how to count F(X,Y) calls. Variables inside F turned local. Any ideas? |
01-22-2023, 06:54 AM
(This post was last modified: 01-22-2023 07:01 AM by C.Ret.)
Hello Albert Chan,
Simply add the counter variable C to the list of call indices: SUB SIMPSON(X1,X3,X5,F1,F3,F5,E,S,C) and increment C in Simpson's procedure each time it calls the function F. Alternatively, add the counter in the definition of F and its calls CALL F(X,Y,C) but I'm afraid that will slow down the process further. Have a nice sunday. |
