HP50G SIMPLEX Version14b Max Min Pivot Algorithm, multiple/unbounded, unfeasible sol
01-26-2023, 03:20 PM
(This post was last modified: 01-26-2023 03:22 PM by Gil.)
RE: HP49-50G VERSION 12.hp SIMPLEX Max Min Pivot Algorithm, multiple/unbounded solutions
Version 12
- In some very special cases, the program could be sometimes "stuck" at the end and chose the wrong row, returning then the second solution — but possibly an unfeasible one. A special "artificial" test was duly included in subprogram CHECK. 2SOL to fix up that issue. - The NOTE Var was changed : explanations now only regarding the "pivoting" (outside the program) & no more explanations relative to roundings. - Lines of explanations in —>PIVOT¦&COL.ROW subprogram suppressed for speed purpose. |
01-26-2023, 03:28 PM
(This post was last modified: 01-29-2023 03:04 PM by Gil.)
New Version 12
- In some very special cases, the program could be sometimes "stuck" at the end and chose the wrong row, returning then the second solution — but possibly an unfeasible one. A special "artificial" test was duly included in subprogram CHECK.2SOL to fix up that issue. - The NOTE Var was changed : explanations now only regarding the "pivoting" (outside the program) & no more explanations relative to roundings. - Lines of explanations in —>PIVOT¦&COL.ROW subprogram suppressed for speed purpose. |
01-29-2023, 02:54 PM
(This post was last modified: 02-01-2023 02:10 PM by Gil.)
RE: HP49-50G VERSION 13d.hp SIMPLEX Max Min Pivot Algorithm, multiple/unbounded solutions
Version 13d
Handling of "unfeasible" problem. For visual outlook, deletion of no more used SAME.SOL. Just look at the following problem (input Matrix) : [[ 1 1 'L' 5 ]* [ 0 1 'G' 8 ]** [ 6 4 0 'Max' ]] According to usual SIMPLEX convention (in this program), if nothing is said about xi (here x1 and x2), it is assumed to be >=0. If x2 >= 8 according to **, then * cannot be <0 as said in *, unless breaking the above rule and accepting that x1 might be <= 0 (x1=-3). Put [[ 1 1 'L' 5] [ 0 1 'G' 8 ] [ 6 4 0 'Max' ]] on the stack and launch —>GO. You get then, with the new version 13d: { Var 2¦Steps 4 Time1¦s : Z-Max: 14 :x1: -3 :x2: 8 : Sign { x1 } not allowed: UNFEASIBLE.problem}. Then, pressing afterwards the variable S.1-N, you get also the reminder: :Unfeasible problem Sign incompatibility of { x1 }, [x1 x2... ]: [ -3 8 ] Of course, if you specify that x1 is <= 0 [[ 1 1 'L' 5 ] [ 1 0 'L' 0 ] [ 0 1 'G' 8 ] [ 6 4 0 'Max' ]] and launch —>GO with the new above Matrix, you will get: { Var 2¦Steps 5 Time1¦s : Z-Max: 14 :x1: -3 :x2: 8 }, with no special message. The same applies to [[ 1 1 'L' 5 ] [ 1 0 'F' 0 ] [ 0 1 'G' 8 ] [ 6 4 0 'Max' ]], supposing x1 Free (of unknown sign). |
02-01-2023, 02:08 PM
(This post was last modified: 02-07-2023 09:02 AM by Gil.)
RE: HP50G SIMPLEX Version14 Max Min Pivot Algorithm, multiple/unbounded, unfeasible sol
Version 14
- Linear Combination of xi in prior versions supposed all xi to be >= 0 (default case), or free. Now, in the linear combination of the xi, besides the free case of xi being free, the default case respects the real signs of the xi. - Programs variables S.1N, S.LIN & d.LIN, when called, give more details about the solution (multiple/unbounded/unfeasible solution). |
02-07-2023, 09:02 AM
New Version 14b
Slight change in output for RESULT¦Ci.rows in case of unfeasible problem. |
