HP-19C Batteries
02-14-2023, 12:09 AM
HP-19C Batteries
Just wondering what type of battery is being used these days and whether the low battery indicator is still of any use. cheers Tony |
02-14-2023, 12:41 AM
RE: HP-19C Batteries
Vintage Calculators sell 3D printed battery packs for these with 1000mAh Tenergy Nickel-Cadmium batteries.
I'm currently using 4 x standard AA batteries. I assume the existing low battery circuitry will work with at least the NiCad batteries? (02-14-2023 12:09 AM)teenix Wrote: Hi all, Calculator Clique on YouTube |
02-15-2023, 08:55 AM
Hello Tony,
I have a solution my working 19Cs that I have described previously and repeat it here since I think it works so well. https://www.hpmuseum.org/forum/thread-17716.html Each kit I have is bought at Amazon and includes an USB charger such that the battery pack can be easily removed and safely charged outside the calculator. The kits are fairly inexpensive, about 140SEK, see for example https://www.amazon.se/gp/product/B085WVH...UTF8&psc=1 A connector is needed to be acquired and soldered to the battery pack, and these are sold in bundles (the connector polarities red/black may not correspond those of the battery pack). This ensures safe charging, even relatively safe inside the calculator (but why risk it). The low power indication works as well for this battery pack. Best regards Jonas |
02-15-2023, 10:02 AM
Thanks for the info :-)
Attached is the prototype 19C replacement CPU and Printer boards, almost ready to get made up. I might add adjustable low battery detect. cheers Tony |
02-15-2023, 10:55 AM
These do look very exciting Tony.
I will be one of the customers in line when they are ready. Best regards Jonas |
02-15-2023, 01:50 PM
This is the great news for year 2023.
HP19C is my favorite HP classic calculator. HP35 HP45 HP55 HP65 HP67 HP21 HP25 HP29C HP19C HP97 HP10C HP11C HP12C HP15C HP16C HP31E HP32E HP33E HP33C HP34C HP37E HP38E HP38C HP41 |
