->HMS doesn't work properly
04-07-2023, 05:19 PM
Hi everyone,
I have a problem with the ->HMS function. My angle is: 1.96834347921E-7 . In excel, when I used the function DEGREES(), the result was 1.1278E-5 . But when I used the ->HMS function on my HP 50g calculator to convert the angle from decimal form to HMS form, the result was 7.08603652516E-8. Can you guys tell me what is the problem? Thank you. |
04-07-2023, 10:56 PM
RE: ->HMS doesn't work properly
RE: HP 50g HMS problem
The given result by HP seems to me perfectly correct (and Excel too). 1 degree (1 hour) —> 3600 s Then, if you have d.dddddd 1.96834347921E-7 you have to multiply it by 3600 to get the number of s: 1.96834347921E-7 × 3600 = 7.08603652516E-4 s And your initial value 1.96834347921E-7 (in degrees d.dddddd) with —>DMS gives precisely 7.08603652516E-8 = 0. 00 0000708603652516, to be read as 0h 00' 0.000708603652516s. However, if your initial angle 1.96834347921E-7 is in radian, then the corresponding value in (decimal) degrees is: 1.96834347921E-7 × 360/(2×pi) = 1.12777773991E-5 (in d. ddddd). Excel given function converts, here, radian (your initial value) to degrees (d.ddddds), whereas HP command —>DMS converts your initial value from d.ddddddd into d.mmsssss. Two different things, all of them correct. Regards |
