Inverse Laplace Transform
05-26-2023, 04:23 PM
Can anybody please explain why the calculator is unable to find the inverse Laplace transform?
05-27-2023, 03:36 AM
(This post was last modified: 05-27-2023 03:38 AM by Archanus.)
RE: Inverse Laplace Transform
(05-26-2023 04:23 PM)omer Wrote: Can anybody please explain why the calculator is unable to find the inverse Laplace transform? Hello dear friend I suggest you to use fractions instead of decimals. With fractions, you “help” the Integral Transforms (Laplace, Fourier and Z) to give you a fast and accurate results. I remember when I took Math 5 course (Complex Variable and Transforms), that I “built” the numerator and denominator with fractions and templates (for example Sine, Cosine, Exponential) to only apply the Inverse Laplace Transforms and get a result. |
05-27-2023, 03:35 PM
You can convert approx numbers in an expression to exact values by calling exact().
