UFL 1 font...
09-14-2023, 04:51 PM
(This post was last modified: 09-14-2023 05:08 PM by Jonathan Busby.)
UFL 1 font...
I've become interested in the UFL 1 4x6 tiny font after a discussion with a fellow HP48 friend and hacker. I'm in the process of creating a vector TTF for this font. I'm using lines instead of Bezier splines, but I may switch to splines.
As part of this project, I was prompted to render the original UFL 1 font on my 4K UHD display. To that end I've created a small FreeImage library utility function in ISO / ANSI / POSIX C that renders an input string into a properly sized and column wrapped PNG file. Here's an example of the rendered raw UFL 1 4x6 tiny font, although enlarged ( with no interpolation ) by a factor of four : And here's the original ( also attached... ) : ( The small C app is attached... It's also been uploaded to HPcalc.org, but it will probably be a while before Eric updates the site... ) What are your thoughts? Any helpers, recommendations or tips for the TTF font would be welcome. Regards, Jonathan Aeternitas modo est. Longa non est, paene nil. |
09-14-2023, 06:48 PM
RE: UFL 1 font...
(09-14-2023 06:34 PM)Massimo Gnerucci Wrote: Of course you know there is FONTMINI.TTF Didn't know that Thanks for the tip I've looked at said TTF font file and it looks like a quasi-bitmapped font that doesn't use any type of interpolation, such as Bezier splines or lines... So, it can be improved upon... Regards, Jonathan Aeternitas modo est. Longa non est, paene nil. |
09-15-2023, 02:31 PM
RE: UFL 1 font...
In the past I have used FontForge to create some fonts based on bitmapped fonts.
FontForge has a scripting interface so that you can write a e.g. Python program to read a bitmap font and recreate the pixels as vector objects. This is at least a good starting point as creating 256 glyphs is quite some work. Of course this automatic process does not included details like hints. Martin |
09-17-2023, 04:54 PM
RE: UFL 1 font...
(09-15-2023 02:31 PM)Martin Hepperle Wrote: In the past I have used FontForge to create some fonts based on bitmapped fonts. Thanks for the info I'm not quite sure if anyone really wants a UFL 1 minifont based vector TTF, at least from the equivocal poll. But, it's nice to know that there's a scripting interface available -- although I prefer Perl Quote:This is at least a good starting point as creating 256 glyphs is quite some work. Well, in the UFL 1 minifont, a large portion of those 256 bitmaps are blank. Quote:Of course this automatic process does not included details like hints. Yep. The devil's in the proverbial details as they say... Regards, Jonathan P.S. Attached as an updated small C app that renders the UFL 1 minifont but correctly handles newlines... I've also uploaded it to HPcalc.org... Aeternitas modo est. Longa non est, paene nil. |
