Solwant to solve a 2nd ving a partial differential equation with textbook solution
09-15-2023, 08:56 AM
First I managed to solve a 2nd order ode using the symbolic letters as in:
desolve(∂(∂u/∂x)∂x+3*∂u/∂x=0,x,y)
Now want to solve a 2nd order partial differential equation, pde
My Reference for a textbook solution is from the book "Advanced Mathematics For Engineering Students", page 131.
In the textbook
The 2nd order pde is
∂2u/(∂x∂y) = 2x - y.
The general solution is:
u = x^2*y - 1/2*x*y^2 + F(x) + G(y)
Where:
F(x) = 2* sin(x) and
G(y) = 3*y^4- 5
Entering the pde in the Prime [/b][/align]n CAS mode:
b]desolve(∂(∂u/∂y)∂x+y-2*x=0,x,y,u)[/b]
The answer is
[1/2*y]
It was not the textbook's answer.
Question: why didn't the output from the prime match the textbook answer?[b]
Thank you,
Anthony, Sydney
09-15-2023, 12:18 PM
RE: partial differential equation with textbook solution
(09-15-2023 08:56 AM)Anthony The Koala Wrote:  In the textbook
Where:
G(y) = 3*y^4- 5
F(x) and G(y) can be any expression, that particular set is just for illustration.
diff(u, y, x), both F(x) and G(y) goes away, leaving just (2x - y)
From XCas manual, desolve(de, <x, y>), where x is variable, y is unknown.
desolve may not be able to handle more variables. (it has other limits, see manual)
We do this in steps (1 variable, 1 unknown). let w = diff(u,y)
Cas> desolve(diff(w, x) = (2*x - y), x, w)
-x*y + x^2 + G_0
Cas> desolve(diff(u, y) = (-x*y + x^2), y, u)
Cas> expand(Ans)
-1/2*x*y^2 + x^2*y + G_0
Or, we simplify integrate twice, to get u
Cas> int(int((2*x - y), x), y)
-1/2*x*y^2 + x^2*y
u = x^2*y - 1/2*x*y^2 + F(x) + G(y), same as textbook answer
09-16-2023, 01:56 AM
RE: Solwant to solve a 2nd ving a partial differential equation with textbook solution
Dear Mr Chan,
Thank you for the reply. It is a learning experience of the limitations of the Prime not being able to handle PDEs.
I tried your two-stage solution and it works.
I wanted to go deeper by breaking down the statement
and do
The display said
[diff(w,x)=2*x-y x w] [0=2*x-y x w]
I tried
b]diff(w, x) = (2*x - y))[/b]
The display said
[diff(w,x)=2*x-y] [0=2*x-y]
I know desolve solves an ode but need further idea of what the Ans within the desolve does with
[diff(w,x)=2*x-y x w] [0=2*x-y x w] ?
[/b]
Ref for the int command
http://www.wiki4hp.com/doku.php?id=prime...s_commands
Other question please
Obviously there are many ways to solve a PDE including taking Laplace transforms and converting them to an ODE.
Could the two-step method used in the original question be used to solve any kind of PDE and the need to specify the initial and boundary conditions?
Thank you
Anthony, Sydney[/i]
